37" Vizio VX37L Keeps Turning off
+ More Options
Posts
  • rustytierod
    • Sep 2014
    • 81
    Re: 37" Vizio VX37L Keeps Turning off
    I checked all the service manuals and they seem to skip right over that number...
      Originally posted by rustytierod
      Can anybody tell be the spec for C223 on the slave board?
      Can we at least see the pictures of the cap in question?
      • rustytierod
        • Sep 2014
        • 81
        It is a smd one. Got burned up pretty bad so here's a pic I found of it.
        • rustytierod
          • Sep 2014
          • 81
          • rustytierod
            • Sep 2014
            • 81
            Sorry for double post the photobucket looks like they are hosting hotlinks again?
            • rustytierod
              • Sep 2014
              • 81
              Anybody??
              • steven m
                • Sep 2021
                • India
                #27
                ey guys, last week my elder brother also encounter this of issue on his Vizio (Model Number - E500i-b1) tv . His tv kept on showing black screen. He tried soft reset but that doesn't work for him, later. he called me and I started searching for fixes after a while I found a website where we got the solution to fix this issue. We followed the reset method step by step and that fixes our problem as well as our tv also, so if you also want to fix your tv too then try to reset your tv and if that doesnt work for you then you should check out there website, I am leaving the link of their website here
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • pedromvu
                  Vizio M65-E0 not turning on
                  by pedromvu
                  Hi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
                  The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
                  Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
                  The voltages from Power to Main board are as follows:
                  NC = 0
                  A = 0
                  BL_on/off = (Some millivolts, probably considered 0)...
                  11-18-2022, 12:28 PM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • howardc64
                  Vizio SmartCast TV software bug that looks like hardware
                  by howardc64
                  Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                  It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                  11-16-2024, 05:17 PM
