Vizio 60" E601I-A3 no display have sound
  • ecking767
    • Oct 2009
    • 492
    I came across a Vizio 60” LED HDTV that doesn’t display a picture. The TV turn on fine, meaning backlight turns on, and the TV stay power on. But no picture, I was able to get sound using one of the HDMI input.
    So I will say the main-board is functioning. So I move to the T-CON board and check the fuse, it check out to be good. I measure +12 volts coming in and out and it measure zero ohm. I started checking the caps on the T-CON board for voltages and got none. I also check for voltage on what I thought to be voltage regulators, I only found +12 volts on the tabs of the regulators.
    The +12v stop at the tabs of the two regulators, nothing on the outer pins.
    need help identifying these regulators OR part type
    smd marking are: B2 Y219
  • selldoor
    Slow Learner
    • 7870
    Re: Vizio 60" E601I-A3 no display have sound
    Hi can you list the part numbers for the other similar components.
    • retiredcaps
      • Apr 2010
      • 9271
      What is the part number of the two circled red components?
      --- begin sig file ---
      --- end sig file ---
      • ecking767
        • Oct 2009
        • 492
        IC Chip p/n: S24C12
        8C3VK8
        The other is a AO4854 dual N channel FET
        There is a Maxim chip, MAX9684 I can't find any datasheet for it,
        I'm wondering if those aren't regulator, maybe FETS? Im going to remove the
        two chips B1 and B2 and see what my multi-meter can tell me.
        I uploaded a close up picture
        • retiredcaps
          • Apr 2010
          • 9271
          Originally posted by ecking767
          IC Chip p/n: S24C12
          I believe the 24xxx chips are eeproms.
          • retiredcaps
            • Apr 2010
            • 9271
            What is the part number of IC301?
              The Maxim IC's likely a custom gamma IC, something like this:
              http://www.maximintegrated.com/datas...ex.mvp/id/5757
              • ecking767
                • Oct 2009
                • 492
                another Maxim = 17140E
                TL213
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Hmm, none of these turn up a datasheet and they seem like proprietary ICs. If true, you may not have any option but to purchase a replacement t-con?
                  If a replacement t-con is around $40, it might be worth the gamble for a 60 inch TV?
                  • ecking767
                    • Oct 2009
                    • 492
                    If the T-CON board was available for less then $80.00 I will have made a purchase, but there isn't any available on eBay, Shopjimmy or on any other TVs parts website.
                    I see some crack screen Vizio 60" E601I-A3 and A seller on eBay offering to fix this T-CON board but the price is a little high.
                    • seanxp
                      • Mar 2013
                      • CN
                      It looks like about power circuit,the power ic MAX17140 may shut down the whole T-con power supple because of self-protection maybe.
                      Did you measure the volts with FFC connection or without?
                      • ecking767
                        • Oct 2009
                        • 492
                        Yes, the circuit is dead, only +12volts on the tab of B1 transistor. I'm not sure what is the function of MAX17140, can't find any datasheet. Im doing some circuit tracing to better understand what going on
                        • dzooem
                          • Oct 2010
                          • 3
                          I found software for MAX9684 ! "MAX9684 EVKIT Software" http://www.maximintegrated.com/desig...cfm?EVKit=1017
                          • DULLTV
                            • May 2012
                            • 9
                            • usa
                            Did you get it working ?
                            • shameem
                              • May 2013
                              • 8
                              IC Chip p/n: S24C12
                              8C3VK8
                              I am in the exact same boat.....
                              MAX9684 is a microcontroller it seems - http://www.xeltek.com/device_lists/MAXIM/MAX9684/
                              None of the chips are getting 5v power supply -
                              MAX17140 seems to be a power management module - http://www.mouser.com/ProductDetail/...XvsAjpSw%3d%3d
                              But all the chips need a 5v Vcc to operate and i cant find which regulator is responsible for the 5v bus.
                                MAX9864 is most likely to be a gamma voltage reference
                                • shameem
                                  • May 2013
                                  • 8
                                  I have attached a picture of a regulator that may be suspect - I see 12v on one pin and gnd on tab - but the output pin (noted in blue) also shows 12v.
                                  The regulator is marked as X7W 16 (16 is printed sideways). Anyone know what that is?
                                    Not a regulator:
                                    https://cdn.badcaps-static.com/pdfs/...97c81ee60b.pdf
                                    • shameem
                                      • May 2013
                                      • 8
                                      Thanks!
                                      And please - Would you be able to identify the following components -
                                      COXA 16(sideways)
                                      XOW 11(sideways)
                                      B1 Y225
                                      B2 Y234
                                      C403 233
                                      • shameem
                                        • May 2013
                                        • 8
                                        Could anyone figure out what these components are? Diodes?
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • rblack711
                                          Vizio D55un-E1 COF Lifting Tabs - Not!
                                          by rblack711
                                          Relatively new to TV repair - as you will see. Rescued this TV from the curb. No backlights, but I could see an image on LCD with flashlight, so suspected bad LED strips. When I got to the part of lifting the LCD off the frame, it was stuck a little bit from some tape used to hold down a thin layer of foam around the frame. I saw 8 tabs on each side of the LCD that I haven't seen on any of the 3 TVs that I have taken apart before. I immediately thought, wow the engineers that designed this were thinking about the serviceman when they put these lift tabs on here - good for them. So I started yanking...
                                          08-24-2022, 12:52 PM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
