panasonic TX-P42X20B flashing red
    Re: panasonic TX-P42X20B flashing red
    let me know what to do and ill have all three in the morning
      You need to wire them from STBY 5V to the power on signals: PANEL MAIN ON, TV SUB ON. And one from POWER OFF to 0V (GND). The rails should switch on.
        cool , i will do this tomorrow and get back to you
          Oh, and the connector should be disconnected from the A board before doing this.
            OK , just to double check i have this 100% correct before i attack it the with 200 ohm resistors.
            on P7
            stnby 5v(pin 8) to panel main on (pin 7)
            stnby 5v(pin8) to TV sub on (pin5)
            all off (pin11) to GND 0v .. where is the best place to pick up 0v GND ?
              GND would have to go to a screw or the chassis -- for now leave it off and see if it works without.
                it didnt work without the ground, to all off , ill add this and try again this afternoon
                  0volts on all pins on P6
                  P7 has changed and is now as below
                  pin1 (standby 5v) = 0v
                  pin3 (s0) = 0v
                  pin4 (s1) = 0v
                  pin7 (panel main on) = +5v
                  pin5 (tv sub on) = +5v
                  pin11 (all off) = 0v
                  pin8 (stb-5v 0n) = +5v
                  pin9 (sos p4) = 0v
                  pin12 (main-sw) = +5v
                  pin14 (main sw) = 0v
                    Should pin 14(main switch 1) and pin 12 (main switch2) not be conected as well ?
                      Yes. Forgot about those.
                        do i need to put the 200 ohm resistor between pin 14(main switch 1) and pin 12 (main switch2) as well ?
                          I need a little help confirming i have put 5v to the right places Tom .. HAVE I GOT THIS CORRECT ?
                          As you can see i have wires
                          pin1 (stby5v) to pin7 (panelmain on) with 200 ohm resistor
                          pin1 (stby5v) to pin5 (TV sub on) with 200 ohm resisitor
                          pin11(all_off) to GND with a 200 ohm resistor
                          pin12 and pin14 (main switch 1 and 2) short out
                          I still hear the relay click over then click back and the P board looks to behave the same way as without the resistors in place and the only change in voltages are the now 5V on pin5 and pin7 we have conected to 5V stnby
                            That looks correct.
                            You should get sound +15.8V, do you?
                              NO I dont, Here is what i get on P6 with the above in place..
                              pin1 (sound +15v) = 0v
                              pin2 (sound +15v) = 0v
                              pin3 (p+15v) = 0v
                              pin7 (F+15v) = +15.8v
                              pin9 (F+15v) = +15.8v
                              This is the same as before the resisitors where put in place.
                                OK. P board is definitely looking bad. Final check. Unplug PSU, wait 30 seconds, plug it in. Do you get some clicks from the relay?
                                  yes we do , i hear it click then a second click after about 3 seconds , OK i have ordered a new P board , should be here early next week
                                    Aaaaaaaarrrr Damn it ... power supply swapped and still 10 red flashes looks like ill need to source a A board .
                                      Darn. Did the supplier you ordered from offer a returns policy?
                                        no i got it from ebay .... i can re sell it on ebay so im not bothered
                                          Any one know what might need changed on the a board to repair it or where to get the data from a 42" a board to change it on my 37" a board.
                                          Or even how to change the resolution to enable full picture.
