panasonic TX-P42X20B flashing red
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    • uk
    #61
    Re: panasonic TX-P42X20B flashing red
    let me know what to do and ill have all three in the morning
      You need to wire them from STBY 5V to the power on signals: PANEL MAIN ON, TV SUB ON. And one from POWER OFF to 0V (GND). The rails should switch on.
      • karlpowell
        badcaps.net
        • Feb 2013
        • 104
        • uk
        #63
        cool , i will do this tomorrow and get back to you
          Oh, and the connector should be disconnected from the A board before doing this.
          • karlpowell
            badcaps.net
            • Feb 2013
            • 104
            • uk
            #65
            OK , just to double check i have this 100% correct before i attack it the with 200 ohm resistors.
            on P7
            stnby 5v(pin 8) to panel main on (pin 7)
            stnby 5v(pin8) to TV sub on (pin5)
            all off (pin11) to GND 0v .. where is the best place to pick up 0v GND ?
              GND would have to go to a screw or the chassis -- for now leave it off and see if it works without.
              • karlpowell
                badcaps.net
                • Feb 2013
                • 104
                • uk
                #67
                it didnt work without the ground, to all off , ill add this and try again this afternoon
                • karlpowell
                  badcaps.net
                  • Feb 2013
                  • 104
                  • uk
                  #68
                  0volts on all pins on P6
                  P7 has changed and is now as below
                  pin1 (standby 5v) = 0v
                  pin3 (s0) = 0v
                  pin4 (s1) = 0v
                  pin7 (panel main on) = +5v
                  pin5 (tv sub on) = +5v
                  pin11 (all off) = 0v
                  pin8 (stb-5v 0n) = +5v
                  pin9 (sos p4) = 0v
                  pin12 (main-sw) = +5v
                  pin14 (main sw) = 0v
                  • karlpowell
                    badcaps.net
                    • Feb 2013
                    • 104
                    • uk
                    #69
                    Should pin 14(main switch 1) and pin 12 (main switch2) not be conected as well ?
                      Yes. Forgot about those.
                      • karlpowell
                        badcaps.net
                        • Feb 2013
                        • 104
                        • uk
                        #71
                        do i need to put the 200 ohm resistor between pin 14(main switch 1) and pin 12 (main switch2) as well ?
                        • karlpowell
                          badcaps.net
                          • Feb 2013
                          • 104
                          • uk
                          #72
                          I need a little help confirming i have put 5v to the right places Tom .. HAVE I GOT THIS CORRECT ?
                          As you can see i have wires
                          pin1 (stby5v) to pin7 (panelmain on) with 200 ohm resistor
                          pin1 (stby5v) to pin5 (TV sub on) with 200 ohm resisitor
                          pin11(all_off) to GND with a 200 ohm resistor
                          pin12 and pin14 (main switch 1 and 2) short out
                          I still hear the relay click over then click back and the P board looks to behave the same way as without the resistors in place and the only change in voltages are the now 5V on pin5 and pin7 we have conected to 5V stnby
                            That looks correct.
                            You should get sound +15.8V, do you?
                            • karlpowell
                              badcaps.net
                              • Feb 2013
                              • 104
                              • uk
                              #74
                              NO I dont, Here is what i get on P6 with the above in place..
                              pin1 (sound +15v) = 0v
                              pin2 (sound +15v) = 0v
                              pin3 (p+15v) = 0v
                              pin7 (F+15v) = +15.8v
                              pin9 (F+15v) = +15.8v
                              This is the same as before the resisitors where put in place.
                                OK. P board is definitely looking bad. Final check. Unplug PSU, wait 30 seconds, plug it in. Do you get some clicks from the relay?
                                • karlpowell
                                  badcaps.net
                                  • Feb 2013
                                  • 104
                                  • uk
                                  #76
                                  yes we do , i hear it click then a second click after about 3 seconds , OK i have ordered a new P board , should be here early next week
                                  • karlpowell
                                    badcaps.net
                                    • Feb 2013
                                    • 104
                                    • uk
                                    #77
                                    Aaaaaaaarrrr Damn it ... power supply swapped and still 10 red flashes looks like ill need to source a A board .
                                      Darn. Did the supplier you ordered from offer a returns policy?
                                      • karlpowell
                                        badcaps.net
                                        • Feb 2013
                                        • 104
                                        • uk
                                        #79
                                        no i got it from ebay .... i can re sell it on ebay so im not bothered
                                        • craig417
                                          • Feb 2013
                                          • 21
                                          • scotland
                                          #80
                                          Any one know what might need changed on the a board to repair it or where to get the data from a 42" a board to change it on my 37" a board.
                                          Or even how to change the resolution to enable full picture.
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • learnmore
                                            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                            by learnmore
                                            Hello Community!
                                            CASE DETAILS
                                            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                            Tried inserting firmware on USB and left it in for a few hours, but no change
                                            03-03-2024, 09:49 AM
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
