panasonic TX-P42X20B flashing red
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    • uk
    Hi folks
    I have a plasma Panasonic TX-P42x20b set with a fault ....I only see 10 red flashing lights, I Have had a quick look at the Caps on the power supply board but they all look to be OK .
    When I first press the power button I hear a click then a few seconds later another click and the light starts to flash.
    any help here would be great ...
    PS great forum
    Karl
  • martyparish
    • Dec 2012
    • 313
    Re: panasonic TX-P42X20B flashing red
    Be sure to check out Tom66's Plasma Troubleshooting Guide
      That isn't particularly applicable for this set, it's more designed for LG, Samsung and Fujitsu-Hitachi plasmas. On this set, 10 blinks is likely a failed ceramic capacitor on the PSU board.
      Training manual for your TV:
      http://www.tgohome.com/ServiceManual...&Search=Submit
      • karlpowell
        badcaps.net
        • Feb 2013
        • 104
        • uk
        thank you very much for your both replies, tom please can you give a little more info on which ceramic capacitor im looking for ?
          A picture of your power board, the large centre one, would be very helpful in this instance. I have a feeling this is different from the common 10 blink problem due to a different PSU.
          • karlpowell
            badcaps.net
            • Feb 2013
            • 104
            • uk
            here you go http://img43.*************/img43/8352/p1221543.jpg
              Yeah... it's a different PSU.
              10 blinks is a Sub 3.3V, 5V, 9V or tuner power SOS.
              It can be P, SC, SS or A board.
              To diagnose:
              Unplug SC/SS. These are the two large boards on the sides of the plasma panel. Both the power (thick blue/white) and data (thin ribbon) should be unplugged. It can be left installed in the chassis. If the blink code then turns to 6, 7 or 8 blinks the problem is with the SC or SS. If not it is P or A.
              • karlpowell
                badcaps.net
                • Feb 2013
                • 104
                • uk
                the code stays at 10 , I wont be able to reply to any messages now for a few hours as i have to take the kids to a disco
                • karlpowell
                  badcaps.net
                  • Feb 2013
                  • 104
                  • uk
                  since the code stays at 10 blinks with both the white and blue cables to each board at the sides and the ribbon cable unplugged from the left board , I still get 10 flashes from the red light , could this be a PSU fault ?
                    Did you unplug the other cable on the SS (right) board? Picture in case it is different would help.
                    • karlpowell
                      badcaps.net
                      • Feb 2013
                      • 104
                      • uk
                      there is no ribbon cable going to the right board
                      http://img248.*************/img248/9007/p1221545.jpg
                        Can you unplug all but the connectors going to the plasma panel?
                        • karlpowell
                          badcaps.net
                          • Feb 2013
                          • 104
                          • uk
                          Are these the 2 ribbon cables on the bottom board ? if so then when removed I still get 10 flashes ...
                            The righthand board, the SS (Sustain board.)
                            • karlpowell
                              badcaps.net
                              • Feb 2013
                              • 104
                              • uk
                              OK I have disconnected the 2 orange ribbon cables from the SS board and still get 10 flashes :0
                                Those are the panel ribbons, you can leave those connected. They go to the plasma panel itself. We are looking for any connectors other than those.
                                • karlpowell
                                  badcaps.net
                                  • Feb 2013
                                  • 104
                                  • uk
                                  OK tom with all the connectors removed from that board we still get 10 flashes
                                  http://img534.*************/img534/5017/p1231547.jpg
                                    OK so it is on the P or A board. Got to go now, will post more later (bump this post if I forget.)
                                    • karlpowell
                                      badcaps.net
                                      • Feb 2013
                                      • 104
                                      • uk
                                      with a bit of luck it will just be the power supply board , I don't mind replacing components ,I cannot see any scorch marks or anything looking burnt out on this this board.
                                      • karlpowell
                                        badcaps.net
                                        • Feb 2013
                                        • 104
                                        • uk
                                        if you need any more pictures let me know
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
                                        • H34TO
                                          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                          by H34TO
                                          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                          06-17-2025, 07:17 AM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
