sanyo DP32648 tv will not turn on
  • CR Designs
    • Dec 2012
    • 430
    Have a sanyo DP32648 tv will not turn on. The guy I got the TV from said they were watching it and it turned off and could ever get it to turn on.
    Large cab 165 volts
    5v yes
    12v no
    24v no
    F1 fuse good
    volts at ac board 121v. can you help?
  • johnboy1313
    • Nov 2012
    • 1959
    Re: sanyo DP32648 tv will not turn on
    Does it respond to the power button in any way? Is there an indicator LED on when the set is plugged in? Does the connector plug on the top right corner of your first pic runs to the inverter boards? If so, could you post a pic of the connector on the inverter board? You may be able to force the PSU and inverters on. If I can see the pin callouts, I may be able to help you. If I can't someone here more than likely can.
    • CR Designs
      • Dec 2012
      • 430
      Does not respond to power button,no LED. I will have to take the back off the set to get you pictures you want Also caps all look good
      • johnboy1313
        • Nov 2012
        • 1959
        In my limited experience, no reponse to the power button, along with no LED was due to a bad main board. I had the same symptoms on a 42" Vizio and a 47" Sharp. Forcing the PSU on will allow you to see if the 12V and 24V rails show proper voltage.
        • CR Designs
          • Dec 2012
          • 430
          Walk me though it. I have not done that.
          • johnboy1313
            • Nov 2012
            • 1959
            Well, you basically use two 1k ohm resistors. One jumpers from 5V to PS_ON (power supply on) and the other from 5V to BL_ON (back light on) or whatever this set calls it. When you plug the set on, the PSU should kick on, if it's working, and turn your backlights on, if they're working. Let me see if I can dig up a link to show you.
            • johnboy1313
              • Nov 2012
              • 1959
              https://www.badcaps.net/forum/showthread.php?t=24878
              the description starts down in post #6. Scroll down for more instructions.
              • johnboy1313
                • Nov 2012
                • 1959
                http://www.shopjimmy.com/lg-6632l-04...t-inverter.htm
                If your inverter looks like this, it looks like you need to use the resistor to jumper 5V to pin 12 on the inverter, ON/OFF.
                • CR Designs
                  • Dec 2012
                  • 430
                  Here's the inverter
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    Well, I wanna say it's the furthest pin to the right, I can't read it in your pic. I think it says BEL or something like that but I'm not certain. You might have to wait until someone with a little more knowledge chimes in.
                    • CR Designs
                      • Dec 2012
                      • 430
                      Here's the connector on my board
                      • CR Designs
                        • Dec 2012
                        • 430
                        Here's connector on inverter board
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          That connector in the PSU pic goes to the main board though, does it not? Does the connector opposite of that one go to the inverter board?
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Does the other end of the plug that goes into CN902 on the PSU unplug from the main? If so, with the tv unplugged, unplug the inverter board at the inverter board and the main at the main. Run a 1kohm resitor from the hole in the plug for one of the 5V pins to the hole that runs to PS_ON. Plug the tv in and see if you have voltage at 12V and 24V, if so, see if you have voltage at the VINs in the inverter plug. Maybe this set doesn't have a back light on pin.
                            • CR Designs
                              • Dec 2012
                              • 430
                              here's connector going to inverter
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                OK, so if you jumper to PS_ON, see if you have 24V at pins 1-5 on CN903.
                                Have you seen this?
                                http://www.coppelltvrepair.com/p/189...repair-service
                                Apparently, I could be wrong about the issue being the main.
                                • CR Designs
                                  • Dec 2012
                                  • 430
                                  I don't have a 1k ohm resistor will have to get one
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    You may be able to use 2 (3V) or 3 (4.5V) AAA batteries to PS_ON.
                                    • CR Designs
                                      • Dec 2012
                                      • 430
                                      Would like to have budm chime in on this if you don't mind
                                      • CR Designs
                                        • Dec 2012
                                        • 430
                                        Did resister test it is dead ,don't have the 5 volts now
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • u666sa
                                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                          by u666sa
                                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                          Platform: ipa32 la-m024p rev 1b
                                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                          I found a short on the other side:
                                          10-04-2025, 05:03 PM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
