Panasonic sc tnpa5081 rebuild
Re: Panasonic sc tnpa5081 rebuild
Hey guys, slight thread bump... this is the best source of info for this board that I was able to find. My TC-P54G25 just bit the dust, pretty much 3 years on the nose from when I bought it! Got the 10 blink code, so I disconnected the ribbon & power to the SC board and it went to 6. My first question is, is the damage usually isolated to the SC board or do the SD & SU boards get fried too? Thanks to this thread I was able to find some components that were bad. I'm an amateur when it comes to troubleshooting, I work with electronics as my job but we're far more into the replacement industry if you know what I mean. So far here is my list of dead components (checked when removed from circuit):
D482
Q452
Q401
Q402
Q403
Q421
Q422
Q423
Q660
Q661
R452
R551
Is it assumed the FET drivers always go on these(IC501, IC521)? Also, what's the best way to check those double transistors? (Q551, Q521, Q501, Q531) I don't have the board in front of me right now but no pins were shorted except where the bases connect obviously. One other thing I found was a 13 ohm reading across the 5V reg. from common to output (IC771). I took it out of circuit and the resistance is still there. The reg. itself is showing about 5.6k now if I remember correct.
These are not easy to find either, Mouser shows nil until mid November, Digikey min order qty3000!
I purchased a very cheap SS board to salvage these from, also produces some other handy bits.
I think it was only my last cooked board that needed these, you may since R452,D482, Q452 are in the bad list
Q551 in cct.
3-5 0.7 ohms
3-4 3.5meg
4-5 3.5meg
1-2 jumps around > 150k
1-5 3.6meg
1-4 47k
2-3 3.5meg
2-4 similar as 1-2 >150k goes over 200k and slows.
This is what I've had to replace in that area, but not all boards mainly the last one after too many failed powerups. generally just the FET driver
D16451 B0ECKP000055 DIODE 1 ROHM , RF101L4S 400V 1A SHORT
D16482 B0FACP000003 DIODE 1 RFN25TM4SWSHORT
Q16452 B1JAEP000012 TRANSISTOR 1 GT45G128SHORT
IC16521 C0ZBZ0001708 IC 1 M81737FP
Q16521 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
Q16551 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
R16452 D0GF5R6JA047 M 5.6 OHM,J, 1/3W
R16521 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
R16522 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
R16551 D0GD100JA059 M 10 OHM,J,1/4W 1Last edited by tw2005; 10-23-2013, 05:40 AM.Comment
If you can get the datasheet for those devices acceptable subs can probably be found.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Q702 now removed, definitely bad... I am now seeing the 2.7k across the pads. Big 7805 checks out ok. I'm getting a lot of 47k to 52k readings across various pins of Q551. The surrounding R521 & R522 are right on the dot 100 ohms, D451 survived reading a good .488V drop. I'll post more findings later!Comment
I was afraid these may be dead.(just realised R551 10ohm is listed, so yeah fried I say)
What's happening with the others, primarily Q501?
have you developed a strategy on how you're going to obtain these parts?
I've placed red dots on the items you've reported bad. Q660 is bugging me, it's shorted too is it?Last edited by tw2005; 10-23-2013, 05:56 PM.Comment
Q660 has indeed seen better days. Here's the readings from Q521:
1-2: 2.66k (charges up)
1-3: 2.86k (charges up)
1-4: 49k
2-3: 277ohms
2-4: 47k
3-4: 53k
Haven't checked online for parts yet, if I have to wait for Nov for the dual transistors that's fine. Also, the smaller 5V reg (IC771) is showing 5.6k across Vout & gnd when removed from circuit... I'm guessing that's shot?Comment
1-4: 49k
2-3: 277ohms
2-4: 47k
3-4: 53k
1-4: 49k
2-3: 277ohms
2-4: 47k
3-4: 53k
That one's stuffed too, basically 1-5 , 3meg, 2-3 2.9megComment
? 28meg
On brand new STM 78L05 I have 4.2k Vout-gnd, 8.8Meg on Vin one polarity, 3meg the other. If you get that high a resistance I'd think it's no good, safer to just replace it if in doubt.
There's a 60" SS board in kentucky $10 USD free std delivery, that will yield
1 FET driver
5 npn/pnp (5pin)
gate resistors
A Fast recovery diode for D482, small switching diode for inverter cct if needed.
The FET driver alone is $4 from china from memory.
So none of the 30F125 IGBTs are gone on this?Last edited by tw2005; 10-24-2013, 08:41 AM.Comment
Ok I'll check out the SS board thanks for the heads up. I have 78L05 SMDs at work come to think of it. Q622 & Q621 seem to be ok, the only lower resistance I see is 47k across emitter to insulated gate, which looks like it should read be with R763 being there.Comment
There's a few cheapies, I was between a rock and a hard place for those sanyo transistors so this option was actually the easiest and cheapest but if you did need some 30F125 there's some of them on there and also the tiny C541 buffer ic which also i needed and impossible to get .
AT least you could order from sears if you really had to for OEM but can be expensive.
Good, just definitely justifies replacing the FET driver.Comment
I still don't like Q521, if that was correct I'd be seeing that in cct , not worth it. Compare the same to one of the others.Comment
by tranquilityHello,
i want to repair an Onkyo TX-NR809 receiver.
symptoms:
on power on, display appears and i hear one click. enue functions is given.
- no hdmi output
- audio output not tested, but i think it is not there
- usb sticks are not recognized
if i read out the chips with display+standby button + tone+
both dts show only ????
chip is D830K013BZKB4
things i have done:
- reflow of the dts chip without taking off and reballing
- changed the aluminium caps without the big one with 25v because i dont...-
08-25-2025, 01:04 AM -
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπ€?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting π.
...1 Photo11-20-2024, 08:52 PM -
by zenHi all
Issue with this set is that after a few minutes of working , the remote control & on board functions stop working .
Current software version is 1267-10402 , which i assume is the latest available , as i cannot get set to take an upgrade.
Managed to obtain a working main board , which has same software version .
Transplanted the TSOP 48 NAND chip , IC8900 ( 29F4G08ABADA ) from the working board into the faulty board , which now is working .
This proved NAND chip is the problem , in the form of corrupt data.... -
by sohail5307I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
Two nand are using :
Tsb4226(128gb)
Tsb4226(128gb) -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
- Loading...
