Need a2159 128gb nand bin file
  • sohail5307
    • Jul 2015
    • 35
    • india
    I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
    Two nand are using :
    Tsb4226(128gb)
    Tsb4226(128gb)
  • meineiid
    • Jan 2019
    • 9
    Hi, im also searching for the two Nand files. In JC repair are only 256Gb and 512GB available. Pls can someone help?
    • anhbanxoi
      • Sep 2021
      • 179
      • VN
      If you have JC P13 then inside the software there is function to program NAND of macbooks.
      • meineiid
        • Jan 2019
        • 9
        Yes, but my board has only 2 Nands on it. In Jc Software are only configs for 4 Nands. Im not sure, are there boards with only 2 Nands or someone has soldered down here maybe 2 Nands? because have seen that someone has already worked on it.
        but sohail5307 is also searching for only 2 nand files so there should be boards with 2 nands
        So i think i also have the board with 2 128gb chips
        • anhbanxoi
          • Sep 2021
          • 179
          • VN
          Pick Macbook Air 2018 from the list and write data for 2 NANDs.
          • meineiid
            • Jan 2019
            • 9
            thank you very much! it worked!
