Panasonic sc tnpa5081 rebuild
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic sc tnpa5081 rebuild
    Originally posted by Stryff
    Also, I'm getting a ~65 ohm reading on collector to emitter on Q702. I will check my buffer boards when I get home.
    That's bad, in cct mine rises until it gets to 2.7k ohms. I would remove from cct and confirm and also re measure the pads on the board minus q702. Shorted Q702 is expected.
    This photo is playing up in the earlier post.
    • tw2005
      • Oct 2011
      • 6458
      Hey guys, slight thread bump... this is the best source of info for this board that I was able to find. My TC-P54G25 just bit the dust, pretty much 3 years on the nose from when I bought it! Got the 10 blink code, so I disconnected the ribbon & power to the SC board and it went to 6. My first question is, is the damage usually isolated to the SC board or do the SD & SU boards get fried too? Thanks to this thread I was able to find some components that were bad. I'm an amateur when it comes to troubleshooting, I work with electronics as my job but we're far more into the replacement industry if you know what I mean. So far here is my list of dead components (checked when removed from circuit):
      D482
      Q452
      Q401
      Q402
      Q403
      Q421
      Q422
      Q423
      Q660
      Q661
      R452
      R551
      Is it assumed the FET drivers always go on these(IC501, IC521)? Also, what's the best way to check those double transistors? (Q551, Q521, Q501, Q531) I don't have the board in front of me right now but no pins were shorted except where the bases connect obviously. One other thing I found was a 13 ohm reading across the 5V reg. from common to output (IC771). I took it out of circuit and the resistance is still there. The reg. itself is showing about 5.6k now if I remember correct.
      (Q551, Q521, Q501, Q531)CPH5524PNP / NPN Epitaxial Planar Silicon Transistors -High-Current
      These are not easy to find either, Mouser shows nil until mid November, Digikey min order qty3000!
      I purchased a very cheap SS board to salvage these from, also produces some other handy bits.
      I think it was only my last cooked board that needed these, you may since R452,D482, Q452 are in the bad list
      Q551 in cct.
      3-5 0.7 ohms
      3-4 3.5meg
      4-5 3.5meg
      1-2 jumps around > 150k
      1-5 3.6meg
      1-4 47k
      2-3 3.5meg
      2-4 similar as 1-2 >150k goes over 200k and slows.
      This is what I've had to replace in that area, but not all boards mainly the last one after too many failed powerups. generally just the FET driver
      D16451 B0ECKP000055 DIODE 1 ROHM , RF101L4S 400V 1A SHORT
      D16482 B0FACP000003 DIODE 1 RFN25TM4SWSHORT
      Q16452 B1JAEP000012 TRANSISTOR 1 GT45G128SHORT
      IC16521 C0ZBZ0001708 IC 1 M81737FP
      Q16521 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
      Q16551 B1HFPFA00001 TRANSISTOR 1 CPH5524-TL-E
      R16452 D0GF5R6JA047 M 5.6 OHM,J, 1/3W
      R16521 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
      R16522 ERJ6GEYJ101V M 100 OHM,J,1/8W 1
      R16551 D0GD100JA059 M 10 OHM,J,1/4W 1
        If you can get the datasheet for those devices acceptable subs can probably be found.
        • Stryff
          • Oct 2013
          • 16
          Q702 now removed, definitely bad... I am now seeing the 2.7k across the pads. Big 7805 checks out ok. I'm getting a lot of 47k to 52k readings across various pins of Q551. The surrounding R521 & R522 are right on the dot 100 ohms, D451 survived reading a good .488V drop. I'll post more findings later!
          • tw2005
            • Oct 2011
            • 6458
            I've misplaced my fine probes ,hard to get on it, you'll have to be more specific with Q551. I guess Q452 D482 are definitely shorted?
            • Stryff
              • Oct 2013
              • 16
              Yes those two are shorted. Here's my Q551 readings:
              1-2: 100k
              1-3: 54k
              1-4: 52.5k
              2-3: 47.3k
              2-4: 46.8k
              3-4: 543ohms <--interesting.
              • tw2005
                • Oct 2011
                • 6458
                1-2: 100k
                1-3: 54k
                1-4: 52.5k
                2-3: 47.3k
                2-4: 46.8k
                This is definitely not good, 1-5 & 2-3 should be in Mohms. I put an old diagram I've posted before. The figures are ballpark but around the 2.9-3.5meg.
                I was afraid these may be dead.(just realised R551 10ohm is listed, so yeah fried I say)
                What's happening with the others, primarily Q501?
                have you developed a strategy on how you're going to obtain these parts?
                I've placed red dots on the items you've reported bad. Q660 is bugging me, it's shorted too is it?
                • tw2005
                  • Oct 2011
                  • 6458
                  I meant Q521?
                  • tw2005
                    • Oct 2011
                    • 6458
                    looking at the cct a bit more and what's fried, replace IC521
                    • Stryff
                      • Oct 2013
                      • 16
                      Q660 has indeed seen better days. Here's the readings from Q521:
                      1-2: 2.66k (charges up)
                      1-3: 2.86k (charges up)
                      1-4: 49k
                      2-3: 277ohms
                      2-4: 47k
                      3-4: 53k
                      Haven't checked online for parts yet, if I have to wait for Nov for the dual transistors that's fine. Also, the smaller 5V reg (IC771) is showing 5.6k across Vout & gnd when removed from circuit... I'm guessing that's shot?
                      • tw2005
                        • Oct 2011
                        • 6458
                        IC771, what's Vin - gnd? The same?
                        • tw2005
                          • Oct 2011
                          • 6458
                          I do have a suggestion for you if you're into recycling parts if you're interested.
                          • tw2005
                            • Oct 2011
                            • 6458
                            1-4: 49k
                            2-3: 277ohms
                            2-4: 47k
                            3-4: 53k
                            1-2: same as P15V in if you look at the schematic,reverse the probes and you'll see the 1.5k you reported
                            1-4: 49k
                            2-3: 277ohms
                            2-4: 47k
                            3-4: 53k
                            That one's stuffed too, basically 1-5 , 3meg, 2-3 2.9meg
                            • Stryff
                              • Oct 2013
                              • 16
                              I'm open to any ideas.
                              Vin to gnd is about 28meg.
                              • tw2005
                                • Oct 2011
                                • 6458
                                ? 28meg
                                On brand new STM 78L05 I have 4.2k Vout-gnd, 8.8Meg on Vin one polarity, 3meg the other. If you get that high a resistance I'd think it's no good, safer to just replace it if in doubt.
                                There's a 60" SS board in kentucky $10 USD free std delivery, that will yield
                                1 FET driver
                                5 npn/pnp (5pin)
                                gate resistors
                                A Fast recovery diode for D482, small switching diode for inverter cct if needed.
                                The FET driver alone is $4 from china from memory.
                                So none of the 30F125 IGBTs are gone on this?
                                • Stryff
                                  • Oct 2013
                                  • 16
                                  Ok I'll check out the SS board thanks for the heads up. I have 78L05 SMDs at work come to think of it. Q622 & Q621 seem to be ok, the only lower resistance I see is 47k across emitter to insulated gate, which looks like it should read be with R763 being there.
                                  • Stryff
                                    • Oct 2013
                                    • 16
                                    Well Q551 is toast, seeing 500 ohms across pin 4 to 5 emitter junction when out of circuit. Pulled Q521 actually seems ok out of circuit, the 2 to 3 pads are still seeing 277ohms...
                                    • Stryff
                                      • Oct 2013
                                      • 16
                                      Ah I see where the resistance is coming from, I should've checked the schematic first. The FET driver IC521 has that resistance when I removed it from circuit.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        http://www.ebay.com.au/itm/PANASONIC...item485b769fc7
                                        There's a few cheapies, I was between a rock and a hard place for those sanyo transistors so this option was actually the easiest and cheapest but if you did need some 30F125 there's some of them on there and also the tiny C541 buffer ic which also i needed and impossible to get .
                                        AT least you could order from sears if you really had to for OEM but can be expensive.
                                        Good, just definitely justifies replacing the FET driver.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          I still don't like Q521, if that was correct I'd be seeing that in cct , not worth it. Compare the same to one of the others.
                                          • tranquility
                                            Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                            by tranquility
                                            i want to repair an Onkyo TX-NR809 receiver.
                                            symptoms:
                                            on power on, display appears and i hear one click. enue functions is given.
                                            - no hdmi output
                                            - audio output not tested, but i think it is not there
                                            - usb sticks are not recognized
                                            if i read out the chips with display+standby button + tone+
                                            both dts show only ????
                                            chip is D830K013BZKB4
                                            things i have done:
                                            - reflow of the dts chip without taking off and reballing
                                            - changed the aluminium caps without the big one with 25v because i dont...
                                            08-25-2025, 01:04 AM
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • mattpd
                                            PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
                                            by mattpd
                                            PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
                                            No LM damage. UART gives a generic "APU not responding" error.
                                            Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
                                            I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
                                            So to those with experience, would you expect at least a little heat from the NAND during...
                                            09-02-2025, 09:42 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
                                          • zen
                                            Txl47e5b , panasonic nand chip advice
                                            by zen
                                            Hi all
                                            Issue with this set is that after a few minutes of working , the remote control & on board functions stop working .
                                            Current software version is 1267-10402 , which i assume is the latest available , as i cannot get set to take an upgrade.
                                            Managed to obtain a working main board , which has same software version .
                                            Transplanted the TSOP 48 NAND chip , IC8900 ( 29F4G08ABADA ) from the working board into the faulty board , which now is working .
                                            This proved NAND chip is the problem , in the form of corrupt data....
                                            02-02-2021, 11:51 AM
