Toshiba TV wont power up after new power supply
  • tborgers
    • 5
    I have a Toshiba 55G310U that one day I powered on and the picture came up but the sound was screaching like crazy. It wouldnt allow me to turn it off at all so i unplugged it. I figured it was the power supply so I ordered a new one and installed it. Now I still cannot get it to power up. Could it be the motherboard? Please help!! (it wouldnt power up before the new powersupply)
  • drpj23
    • May 2012
    • 528
    Re: Toshiba TV wont power up after new power supply
    So, the TV screached and then you unplugged it only to have it not cut on anymore?
    It could be a main board problem but do you have 5v always present at the connector going to the main board? (Do you have a meter?)
    • tborgers
      • 5
      Yeah I have 5V constantly on the power supply. It appears that it doesnt output a constant 12V or 24V until the main board powers up?
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Can you locate and test all fuses - we are in the dark here
        Welcome to the forum-
        We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
        Examples of what is needed
        https://www.badcaps.net/forum/attach...7&d=1280167246
        https://www.badcaps.net/forum/attach...6&d=1280167246
        https://www.badcaps.net/forum/attach...4&d=1280167246
        It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
          What happen if you put the old power supply board back in?
          Understand how LCD TV works.
          https://www.badcaps.net/forum/showthread.php?t=25810
          • randtek
            • Oct 2011
            • 280
            • US
            32C110U1, 40E210U1 are related models, and use very similar main boards. I have repaired both of those models for dead main boards by replacing EEPROMs. I would bet this model is susceptible to the same failure.
            • tborgers
              • 5
              I checked all the fuses on the board and they tested good. If I put the old power supply in, it still does nothing. :/
              • drpj23
                • May 2012
                • 528
                Then you probably are looking at the main then.
                Do the 12 and 24v rails cut on when you hit the power button?
                • Techstar
                  Tv Restoration
                  • Dec 2012
                  • 122
                  • United Kingdom.
                  Could be corrupted flash memory , common with toshiba on a lot of models.
                  • tborgers
                    • 5
                    Got a new main board today, plugged it in, and no picture or green light. Is there a reset on it somewhere? I feel heat coming off the main board now where as with the old one i didnt. Is there any other thing that could have gone out?
                    • tborgers
                      • 5
                      I also noticed the board has a cap that wasn't making connection and the board appears to be used. I am returning it to the company. Is there any other boards that could make this happen
                      • randtek
                        • Oct 2011
                        • 280
                        • US
                        If the power supply is putting out the proper 5 volts, and the green light never comes on after pressing the power button, that has always been a main board issue on a Toshiba, in my experience.
                        • randtek
                          • Oct 2011
                          • 280
                          • US
                          FYI, unless you purchase it directly from the manufacturer, most boards you order are used. Even boards purchased from the manufacturer are often repaired boards. They only manufacture a limited number of replacement boards for a given model. They rely on recycling boards to provide enough for repairs.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                            03-31-2024, 02:12 PM
                            07-01-2024, 06:34 AM
                          • JimBanville
                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                            by JimBanville
                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                            09-13-2023, 07:21 AM
                          • CMCM
                            Russound CA4 Power Supply Repair
                            by CMCM
                            Hello Everybody,
                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                            The outputs marked 12v and 20v are all measuring only 1v.
                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                            The capacitors physically look clean (no bludgesor leaks) and...
                            07-03-2025, 01:12 PM
