Sony XBR-52HX909 No Power -Red LED blinks 5 times
  • nomoresonys
    • 12083
    • U.S.
    Re: Sony XBR-52HX909 No Power -Red LED blinks 5 times
    There are two connectors going to tcon, one going to mainboard and one going to powerboard, looks like one of those signals is missing?
      Originally posted by tvfixer007
      I checked the fuse on the LED board meter reads 000.1
      Tested voltage across each end of fuse and meter reads 12.68
      Can you please clarify as to how you perform the test?
      Did you put meter probes on each end of the fuse and it shows 12V, or you keep one probe on the chassis at all time and then probe each end of the fuse one at a time and it shows 12V on each end?
      • tvfixer007
        • Feb 2015
        • 86
        I'll check the fuses today and report back.
        • nomoresonys
          • 12083
          • U.S.
          So two weeks then?
          • tvfixer007
            • Feb 2015
            • 86
            Sorry I had to take a break and do tons of house work. I got back to the TV. On the LED drive board I used Ohm to test the fuses.
            On the t-con board I tested voltage with one probe on chassis I get 12.56v on each side of every fuse. Before the red light sequence.
            • renee
              • Jun 2010
              • 21
              #26
              please help me to find volts PRI_VCC on C6206 sony G6 power supply
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • magneh
                TX-65FZ800E - blinks 2 times red led no power
                by magneh
                Hi there
                I have this set with no power, blinks power led twice.
                This seems to point out to D board issue
                My first question is which one is the D board?
                The main board?
                Or one of the power boards?
                Are they labeled with this? (did not checked the boards yet)
                Thanks for any inputs...
                08-23-2023, 09:02 AM
              • Mcologist
                Sony KDL-52Z5100 power relay clicks 4 times then standby blinks 10 times
                by Mcologist
                Troubleshooting a Sony KDL-52Z5100 and when you plug it in the power relay clicks on and off 4 times and then stays off and the standby light blinks in groups of 10 repeatedly.
                I checked the standby voltage going to the main board and it stays consistent at 3.3v the whole time.
                The other voltages coming from the main power board all match their written values.
                The "power on" connection coming from the main board to the power board changes between 3.3v and 0v while the relay is clicking.
                The issue also occurs when only...
                04-08-2019, 03:30 PM
