I have a VO42L when you plug in the AC plug Vizio on front goes Orange then turns White. Can not turn off, no sound or Picture. Have checked PS have 12v and 24v and have 3.4 volts for turn on. No Back lights. Have looked at caps on all boards none look bad. No burns chips. Could main board be bad, as it looks like it controls on/off and sound. Have 5v & 12v to Main board fuses.
Vizio VO42L Turns on by self NO Pic or Sound
Re: Vizio VO42L Turns on by self NO Pic or Sound
have you read this
https://www.badcaps.net/forum/showth...ht=Vizio+VO42L
The power supply looks to be working as I have the 5volts, 12 & 24 volts po on is 3.4. As the tv when plugged in goes from orange to white by is self, I think is a main board problem. I think the main board controls the turn on for Backlights as the 24 volts are present at J1 pin 1 of inverter pcb.
Sir. would you try to Re-solder the Power supply. or can you check at Ohm-miter (tester) the Capacitor.
You can't use an ohm-meter to check a capacitor, except for leakage, which usually isn't a concern.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I would check the voltage regulators on the main baord first since we at least know that the 5V STBY is working.
Please upload the GOOD, CLEAR pictures of the main board using managed attachment.Never stop learning
Originally posted by budm View PostI would check the voltage regulators on the main baord first since we at least know that the 5V STBY is working.
We really cannot help much without photos of the board, can you not borrow a camera?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Do you see the manage attachments option under the reply to thread area?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Good pictures, thanks.
I have highlighted the voltage regulators.
To check each regulator post the voltage on each pin relative to ground (chassis of TV) with TV in the malfunctioning state. Note the part number on each regulator e.g. UM1117-3.3, include the reference code near by e.g. U33.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can you make sure that L032 is not actually "1117" instead, as that is a common part #.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
