Panasonic TX-37LX85P blink 3 times
    Re: Panasonic TX-37LX85P blink 3 times
    Is there an error output on the inverter; are the pins marked at all?
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      #102
      should i check voltages on output in the picture?? I think this is high voltage, just to be sure? i see someone replaced the 3 capacitor
      ...the quieter you become the more you are able to hear...
        Don't attempt to measure the high voltage output with meter - over 3000V present on some LCD TVs.
        How is the soldering on those caps? Try cleaning up flux.
        I see at least one missing - little SMD C6?
        I am trying to understand how the inverter is wired up to the main board. Looks like it goes through A13 perhaps?
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          #104
          the solder is OK, i now cleaned it. Yes i see that someone is try to "repair" TV.
          Yes it is wired with the A board with A13, and with the power board with the P5
            On A13, there is a pin #4 called "INV_SOS". What does this measure? I think it should be low if OK, high if bad. Also, check INV_ON and INV_VCC; pins 2 and 1 respectively.
            Looking at the design of the board, it sends a 5V/12V power rail to the inverter for its logic power, alongside the 24V for the main power supply. I'm working right now on the assumption the power supply failed and sent 17V down the 9V line... this might have damaged the A board (causing your original 3 blinks)... then I think it may have reached the inverter VCC hopefully it's something simple like a blown fuse.
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              #106
              #4 = 3.27V
              #1 goes to 12V but when clicks then 0V, then again 12V -> click -> 0V
              #2 = 0V
                OK, Vcc is OK, but the SOS signal should be a LOW. If you force it low (to pin 6 is fine) using 100~470 ohm resistor, does the TV do a blink code with inverter installed?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  #108
                  I used 100oHm resistor, but no change. Still blinking green LED, and clicking sound. I notice that #1 is not used (there is no wire)
                    What does INV_SOS measure on the A board side when you do this?
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      #110
                      is there difference if i connect resistor on A board or wire or inverter board. I think it is only important to get LOW signal. And what is LOW? is it ok if there is 1V or should be lower?
                        At either end is fine, we are trying to make it less than 0.8V which is the guaranteed low threshold of the 3.3V logic.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Your current LED indication sounds similar to this little LCD I fixed.
                          https://www.badcaps.net/forum/showthread.php?t=23136
                          The PSU/inverter was all one unit and it had a shorted P channel H-FET which was situated on my set right before the inverters. On that one disconnecting the backlight allowed the green LED go solid for a moment then SOS1. The TV had already been tuned in so when an antenna was coinnected I did momentarily get sound from a channel.
                          You mentioned TPC8105 which is a P-channel H-FET. That's what they look like (8pins)
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            #113
                            i got 0V on #4 pin when i use the 100ohm resistor, should i try with lower resistor?
                              0V is fine, but since you've now disabled the error signal and you still get the blinking green I'd have a look at tw2005's advice.
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                #115
                                i measured the voltages, please have a look at them. I think that something is wrong here.
                                  The 3~5V readings do not look good to me, something may be wrong there. With the board powered off, what resistance do you measure between the tab and each of the two pins? It should be >10kohm.
                                  • rtstorm
                                    • Feb 2012
                                    • 971
                                    • Croatia
                                    #117
                                    by the tab you mean the plate? (screw) I measured, on one side is 29kOhm and other is 124kOhm (i measure the regulator pins that is 3.62V on picture)
                                      What is the part # on it?
                                      Yes tab = metal fin/plate at top of device.
                                      • rtstorm
                                        • Feb 2012
                                        • 971
                                        • Croatia
                                        #119
                                        1h45sf
                                        fdd
                                        8447l
                                          All of them?
                                          https://cdn.badcaps-static.com/pdfs/...5f51094b3a.pdf
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • Vebririon
                                            panasonic TX-P50V10E 6 blink led problem
                                            by Vebririon
                                            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                            05-17-2025, 10:16 AM
                                          • BachPhi
                                            Probook 450 G6 Blink 5 times - No boot - NEED HELP!
                                            by BachPhi
                                            • Issue:
                                              Notebook blinks 5 times on power-up and does not boot.
                                              Actions Taken:
                                              • Tried multiple reset key combinations: V, B, Win, Win+V, Win+B.
                                              • Removed and inspected all components on the mainboard (Part No. DA0X8JMB8E0).
                                              • Replaced the RTC battery (CR2016W).
                                              • Swapped in a different RAM module.
                                              • Checked the BIOS chip (Winbond 25Q128JVSQ):
                                                • Measured Vcc = 3V
                                                • /CS signal stays high after power-on (no activity).
                                            08-24-2025, 07:10 PM
                                          • AdrenalinTL
                                            Caps and num lock blink 4 times
                                            by AdrenalinTL
                                            I am sitting with a very similar issue.
                                            Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
                                            Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
                                            Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
                                            Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
                                            04-09-2024, 10:34 AM
                                          • SentraDude
                                            (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                            by SentraDude
                                            Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                            I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                            Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                            04-04-2023, 04:24 PM
