Caps and num lock blink 4 times
  • AdrenalinTL
    • Apr 2024
    • 57
    • test
    I am sitting with a very similar issue.
    Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
    Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
    Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
    Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how to test if it's faulty? Haven't got that far in my very newly acquired studies as yet.
    Saw a youtube video (Very blurry) of a indian guy using copper wire to do something odd.
    https://www.youtube.com/watch?v=hOMoTpC8Nx4 <<< here. My HP is doing EXACTLY the same including the same lights when plugging the power in.
    Anyone got any other ideas?
    • 21986
    Whats the laptop model number and the motherboard model number ?
    • AdrenalinTL
      • Apr 2024
      • 57
      • test
      HP Probook 450G1
      Rampage 12241-1 - Same as the OP's.
      EDIT : I've also ordered a BIOS re-programmer, as that's what most people have done and it has come right. I honestly do not see how something works the 1 day, and then completely fails the next. The lady I gave it to must have tried to update the BIOS or something and turned it off half way through or something.
      • loopster
        • Sep 2020
        • 80
        I resurrected an HP 8570w with a corrupted BIOS just a few days ago which had failed to come out of standby.
        Device came on, no boot logo, fan ramping up, no sceen output, 5 blinks on caps lock and amber lights on wifi and volume button.
        All voltages checked okay, Bios recovery did not work, so I desoldered the chip and flashed a known good one with a programmer. UEFI BIOSes are weird sometimes,
        especially HP... :-)
        • esqmooo
          HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
          by esqmooo
          Hello everyone.
          This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
          Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
          Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
          I tried long pressing on the power button, after several seconds it would go off then when the button is released...
          03-11-2025, 03:57 PM
        • esqmooo
          HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
          by esqmooo
          I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
          03-07-2025, 05:55 AM
        • estabilito
          hp 15-ac126tu 3 times caps lock blink
          by estabilito
          I have hp 15-ac126tu And after turning on caps lock blink 3 times and repeat after a while. On hp website i can read that this is ram problem so i changed the ram modules for surely working ones and still no results - 3 blinks anyway.
          This laptop use ddr3l but i even checked the normal ddr3 and same result.
          All voltages are present, screen only goes black(polarization).
          I've tried to reprogram bios too, same result.
          Under the thermal cam i can see that the cpu have hot spot, should i be sure that this is problem with this hybrid cpu/pch?
          Cpu coil is around 16-20...
          08-18-2021, 01:44 PM
        • dclass-pro
          Hp DAOP5FMB6A0 blink caps/lock problem
          by dclass-pro
          Hi guys, I have an HP model 15s-eq1040nl main DAOP5FMB6A0 REV:A with a caps/lock 5 long 3 short led flashing problem, I tried to remove the battery and program a new bios and when I restarted it immediately worked correctly, the pc turned on and loaded the operating system.
          As soon as I turned off the pc and connected the battery, the problem reappeared... caps/lock 5 long 3 short led flashing again!
          the battery was dead, i charged it and it works fine, but the pc won't turn on again.
          What do you recommend me? Do I have to redo the bios or is there anything else to check?...
          05-08-2023, 12:46 PM
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
