Panasonic TX-37LX85P blink 3 times
+ More Options
Posts
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    #41
    Re: Panasonic TX-37LX85P blink 3 times
    I check whole IC, wrote voltages into picture.
    ...the quieter you become the more you are able to hear...
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      #42
      is it possible that transistor switch is bad? like Q5609 or Q5605 or Q5606 ?
        OK, so the device is not being turned on. The VGS is 0V.
        The power on signal disappears into the main processor IC1100.
        Right now I would be considering replacing the main board unless something else faulty can be determined.
        Did I miss something, or you get no +17V when power comes up (relay clicks?)
        Using a resistor we could try forcing on power to PSU to see if it works.
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          #44
          Yes you are true there is no 17V, what do you think shoud i try to force it up with resistor?
            OK, this is the connection I suggest:
            Pin (1 or 2) to 5, connect a wire between them (no resistor.)
            Pin (1 or 2) to 6, also a wire (board has built in 1k resistor, no need to use one externally.)
            Pin (1 or 2) to 15, connect a 470~4.7k ohm resistor.
            PSU should power up, +9V, +17V, +24V should all work, along with standby rail +5.6V.
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              #46
              i try connected as you sad, but nothing happen. The same 3 red blink.
                Sorry if I wasn't clear but you need to disconnect the connector from the A board and see if you can get the PSU to work this way.
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  #48
                  Sorry my mistake, i tested it and it worked, but i don't have 9V on #11 and #12. All other voltages are OK (+24, +5.6,) And i can hear some strange sound like electric breaking, it is not loud, but you can hear that something is wrong. I think it is coming from reley or coil. and when i plug it out, i hear short whimpering.
                  I use 1.15kOhm resistor.
                    Is +17V good?
                    The +9V is generated from a sub DC-DC converter so this is likely the cause of the fault.
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      #50
                      What pin shud be +17V? I cant find i scheme. I have only 24V and 5V
                        Two pins from the last, I think.
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          #52
                          I dont have that voltage, i check but i think there is also +24V not 17V
                            OK, see the image. If anything in the image disagrees with what you measure, say so.
                            A voltage "when on" in this case indicates the jumper connections have been made, you can measure the standby 5.6V with the jumper in place.
                            The ground should be chassis of TV with PSU board installed and all screws fastened.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              #54
                              i tested it, and i get 18V on #21 adn #22, but on #11 and #12 i have 24V, should be 9V, right? All other voltages are ok.
                                Ok, if there were 24V on the 9V I would say the main board would be damaged quickly, I guess it must be going into over-voltage protection (good idea from Panasonic, I guess.) I hope it hasn't been damaged but it is likely OK.
                                The +9V is generated from the +24V by IC854. What is the part # on IC854?
                                Does capacitor C850 get very hot when it is jumpered across?
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  #56
                                  IC854: MPD7S002
                                  R84
                                  08
                                  C850 and C875 are hotter then other Capacitor, i tested it with thermometer probe it's around 50Celsius
                                    Hmm, no result for that part number "MPD7S002".
                                    Can you please double check it, if you cannot get hold of it you will need to find a way to give TV the +9V it needs (possibly by substituting in an additional supply, e.g. this one on ebay http://www.ebay.co.uk/itm/New-LM2596...item231ed973f5) or by replacing the power supply.
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      #58
                                      I take a picture, you might recognize the image.
                                        Ugh, yeah, I've seen those before. Ugly hybrid modules you can't buy from anywhere which Panasonic likes to use a lot. I don't know why they use them. Must be a good reason for it.
                                        • rtstorm
                                          • Feb 2012
                                          • 971
                                          • Croatia
                                          #60
                                          http://www.chsinteractive.co.uk/elec...-panasonic.htm
                                          i think this is it, i found it by PART NO.
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • Vebririon
                                            panasonic TX-P50V10E 6 blink led problem
                                            by Vebririon
                                            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                            05-17-2025, 10:16 AM
                                          • AdrenalinTL
                                            Caps and num lock blink 4 times
                                            by AdrenalinTL
                                            I am sitting with a very similar issue.
                                            Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
                                            Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
                                            Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
                                            Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
                                            04-09-2024, 10:34 AM
                                          • SentraDude
                                            (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                            by SentraDude
                                            Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                            I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                            Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                            04-04-2023, 04:24 PM
                                          • Smartec82
                                            Sony KDL-55W802A - Red led blink 8 times
                                            by Smartec82
                                            I have this tv that works for about 15 to 20 minutes and then turns off, leaving the led to blink 8 times, this via HDMI, because I can't get into the tuning menu, it says Function unavailable.
                                            Through the manual, I was able to verify that it could be a software problem, but unfortunately the tv already has the latest software and that's why it won't let me update.
                                            Does anyone know of a way to reinstall the software?
                                            02-24-2023, 05:02 PM
