55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    #301
    Re: 55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
    I haven't read through all 15 pages of this thread, and it is late, so for now this advice can be taken with a grain of salt
    However, I have a very similar model Panny , and I was having what seems to be similar troubles. I was diverted by a defect in the panel, but this was not the culprit. What finally fixed my set was getting a complete set of SU/SD and SC from a working set. Replacing buffers individually did not work. I was debugging here, and I don't think that's the end result the experts were concluding, but ultimately it is what fixed this particular set. Still working to this day , as it is "my" TV
    As TW said, I don't think the A board would be part of the problem.
    • pepsiaddict
      • Mar 2015
      No blinking death lights but my 55gt30 is being troublesome.
      Last week we were in the middle of watching a show and the tv shut off on it's own. Remote would not work, power button on the tv would not work. No clicks, buzzes or blinking lights.
      Unplugged for 10 minutes, air-canned all the holes on the back, still completely dead. Came back 40 minutes later and it turns on and works as it had for the last three years with no signs of anything amiss.
      That exact scenario happened again last night.
      Since no blinking happens and the tv ends up working perfectly after waiting I'm assuming it's overheating and self preserving as a failsafe? I haven't read anything suggesting anyone else has experienced this problem.
      Should I position a small fan to continuously blow air across the back?
      The tv is wall mounted, the middle about 8 inches away from the wall, the bottom is 18 inches above the components, nothing to the sides. It's mounted to the support wall of the house and there are not heating vents anywhere near it. Basically I'm saying there's no heat from anything else and this thing has PLENTY of breathing room.
      Suggestions/ideas?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        #303
        Suggestions/ideas?
        Best start your own thread on your specific issue and set.
        --This thread is rather more involved with repairing stuffed-up SC/SN boards of these sets....
        One thing I will say--It'll have to come down and the back removed for sure....
        TELEFIX
        • Sobotka
          • Oct 2015
          • 9
          My TC-P55GT30 has the 7 blinks now. I tried the Troubleshooting chart, unplugged tv, removed SC20 and C20, and then turned the tv back on. It clicked and went to 8 blinks. The chart says to take the voltage reading at pin 1 of connector SC2, but I wasn't sure how to do this. Do I leave SC2 plugged in and touch the positive lead to the connection on the SC board where the white wire plugs in and the black lead to the chassis and turn tv on?
          Also, since moduslink no longer repairs boards, is there another site?
          • kimokalihi
            • Nov 2015
            Hey guys I'm hoping you can steer me in the right direction. I also have a Panasonic p55gt30 that just died a few days ago. No standby light, no response. It was plugged into a cheap Belkin strip that my pc, router, home theatre, modem, cable box and ps3 are all plugged into. About a month ago we had a power outage and it fried my power supply in my pc. Replaced the power supply and all was well again. I don't know if that is what caused my tv to die a month later but it's worth mentioning.
            My tv has also always had this buzzing noise when the tv is displaying bright images like Google's home page. A tap or two on the back made it quiet down. Also, in the last few months when I turn it on, sometimes the colors are all messed up and fuzzy. Goes away shortly or again with a smack on the back of the tv.
            That's the background info. Today I took the back off the tv hoping to spot a swollen cap or something burnt. I don't see anything but I've got basically zero circuit board experience. I did find that most of the boards had loose screws which was probably the source of the buzzing sound. Pisses me off that from the factory it's got loose screws and then I found one of the fans is missing a screw and post so it's super loose. The other has two mounting plastic posts with screws and this one only has two and you can move the fan around a lot. It's probably buzzing as well. Not cool Panasonic. Also, why are there 4 fan shaped vents and 4 mounting locations for fans when there's only two fans?
            I found a service manual for this tv and it says what order to check the boards if there's no power and no standby light hut it doesn't say how to check them. So I'm stumped at this point. Don't want to damage anything by going any further without more guidance.
            I've googled like crazy and read several pages of this thread but all I find is people with the 7 blinks symptom and mine has no light so I think it's probably a different problem.
            Kimo
            • kopec69
              • Jan 2016
              Kimo
              Sounds like a very similar problem to what I am experiencing, I will begin a new thread.
              • kopec69
                • Jan 2016
                I am having a similar problem with my 2011 gt30, it started with the 7 blink issue, then I had replaced the SC board (bought a supposedly new board from a china supplier via ebay). when I replaced this board, the 7 blinks went away and the tv powered on - with picture issues. the TV is working to some extent, all inputs work, however, the colors are quite intense making for a bad picture, and when I select vivid mode, the TV will shut down and give an 8 blink SOS. I can reset and repeat this. One other note, it appears that the 3d picture is OK (however, I do not have 3d glasses to confirm), but the oversaturation goes away in 3d mode. Also, the general color tests in the service mode appear to be fine. Basic text appears fine as well. Please let me know if you have any ideas, or direction on this. I have not checked any TP's yet, rather taken the board swap approach. Thanks.
                • crt man
                  • Mar 2013
                  • 106
                  • England
                  #308
                  Originally posted by tw2005
                  bell out all the IGBT transistors and see if there are any dead shorts.
                  Hi All
                  Been asked to look at Panasonic TXP46GT30B with 7 blinks, the SC board has 7
                  shorted IGBT'S Question is replacing these is it likely to be just them, or other issues.
                  There is a listing on Ebay for a kit and it says if there is a short on Cap842 there
                  are other problems, on the board in this set there is no short.
                  Also, I have never removed any of these can they be removed with a conventional soldering iron or do they need hot air gear
                  Thanks for your time and expertise.
                  Alan
                  • michael dranfield
                    • Jan 2016
                    • 232
                    • England
                    #309
                    Originally posted by crt man
                    Hi All
                    Alan
                    You can repair these with just a soldering iron but to avoid any damage to the board or the new IGBT s when fitting I would recommend pre heating the board to about 120 degrees c before removal and at replacement. My ERSA IR500A has a bottom pre heater built in but you can get stand alone ones on e bay now for not a lot of money, essential for reworking SMD s .
                    • tw2005
                      • Oct 2011
                      • 6458
                      Hi All
                      Alan
                      Decent iron with a good tip should do it. That's all I've used. I either snip the legs, then tin the tab on the IGBT, run the iron back and forth and eventually it will start bubbling down the sides and just lift off. No force required, you'll know when it's free. Alternative is to heat each leg and lift it up gently, bit of wick , then free the body as before.
                      So what are we looking at? 3 x 30F131, 3x RJP30H2 & a RJP63G4?
                      I've had one success and 1 fail replacing just IGBTs.
                      I suspect looking at the cct, a short across C842 may indicate buffer board shorts. You should be checking these first given their scarcity and cost if shorted
                      • crt man
                        • Mar 2013
                        • 106
                        • England
                        #311
                        There is no short across C842, also checked buffer board cannot find any short
                        on them.
                        Alan.
                        • crt man
                          • Mar 2013
                          • 106
                          • England
                          #312
                          Hi.
                          It's worse than I thought just checked again and there is,
                          30F131 X 3 RFN20 X 3 RJP30H2 X 3 DAF30A, RF1501, RPN10.
                          Ouch. don't know to repair or another board.
                          Alan.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Hi.
                            Alan.
                            Ok. So which of those is the 7th IGBT?
                            The RPN10 will be RFN10NS3S. The tail end is significant as it tells us it's a 300V, single diode configuration,common cathode, the beginning suggests 10A rating.
                            After reading the datasheet, It's actually 350V.
                            same deal with RFN20, will be RFN20NS3S. 20Amp version
                            I'd remove or just desolder and lift the legs up of those 6 IGBTs, go back and retest those diodes.
                            I think you'll find they're ok.
                            This may not be the best advice and it's a gamble you'll have to way up but there's a chance replacing just those 30F131 & RJP30H2 could get this going if nothing else is bad like Q661 RJP63G4, Q600 C08N25 FET, & the gate resistors on those blown IGBTs,
                            • crt man
                              • Mar 2013
                              • 106
                              • England
                              #314
                              Hi
                              Thanks, I will lift the IGBT's and will report back when done.
                              Alan.
                              • crt man
                                • Mar 2013
                                • 106
                                • England
                                #315
                                Right
                                After another look it seems like 30F131 X 3 Q401-3 and RJP30H2A X 3 Q421-3
                                nothing else so a lot better.
                                Alan
                                • crt man
                                  • Mar 2013
                                  • 106
                                  • England
                                  #316
                                  Right
                                  Alan
                                  Success replacing Q401-3 and Q421-3 on this set has it working again.
                                  Thanks TW2005 for your help, I was worried about doing it as this is the
                                  first time I have tried to do one.
                                  Alan.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Alan.
                                    Nice, yeah, I know what you mean because there's a degree of luck the drivers were ok. My ST30 is running pretty good with the same replaced and did not even use the OEM parts.
                                    FGD4536TM x 6 but they're quite a bit smaller but it's achievable DPAK where the 30F131 are D2PAK.
                                    lucky to get away with it as it was my error but turned out pretty good.
                                    In another TV they've done 13 months work
                                    360V 50A, 220A pulsed and designed with PDP applications in mind going by the datasheet.
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      #318
                                      TW2005 , Do you know if these IGBT's in these VT/GT/ST models are also found in other SC boards? For example 2009/2010 models?
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Not that I know of, 2011 onwards as they went SMD
                                        • Moreno83
                                          • Jun 2014
                                          • 2008
                                          • The Netherlands
                                          #320
                                          Checked a 2009 panasonic that i use for testing and it does not have these IGBT's. Ordered them all from eBay........bad thing , need to wait a week/2 weeks!
                                          • bialag
                                            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                            by bialag
                                            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                            03-25-2025, 05:56 PM
                                          • Audeze
                                            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                            by Audeze
                                            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                            Does...
                                            10-06-2024, 08:54 PM
                                          • badcappo
                                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                                            by badcappo
                                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                            Diode type G972s6 - D101 with a short
                                            Mosfet 06N90E - Q301 shorted
                                            Fuse T5AH 250V - F103 blown
                                            Diode D301 shorted
                                            Relay DG1U-17VDC II - RL001 blown
                                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                                            11-24-2024, 11:27 AM
                                          • domix
                                            43pus6401/12 - no picture, blinking ambi lights
                                            by domix
                                            Hello i have 43pus6401/12.
                                            After turn on red light slowly blinking and ambilight blinking randomly, different colors fadein/out, etc
                                            Screen is black, no backlight. Caps look normal. I didnt measure it, I forgot my multimeter in another car.
                                            Any common issue?
                                            Thanks...
                                            05-17-2022, 04:35 AM
                                          • crewdog
                                            Hp 15-dy2087nr white lights blinking
                                            by crewdog
                                            Board DAOP5HMB8F REV F
                                            Model OPSH
                                            No bios battery on board
                                            Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
                                            Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
                                            and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
                                            Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
                                            10-25-2023, 03:08 PM
