Board DAOP5HMB8F REV F
Model OPSH
No bios battery on board
Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats.
Plugged in, battery out, charging port light solid white, fan spins momentarily, press power button, charging connector and power on light both blink white, not in sync.
Removed RAM, Memory, wifi card, touch pad, keyboard, daughter power on button assy. no effect.
No board shorts discovered, no burned components found on visual inspection.
19V rail present 3.3V rail present, I recall a 1V as well, 3.3V present at power button falls to zero when pressed and recovers when button released, pin on SIO chip receives the ground (wake up) command as it should, nothing happens.
No hot spots with thermal camera, cold board all over.
I am thinking a bad SIO chip (ITE IT5570e-128 CXA) but I don't know where to test past that and don't have a chip programmer.
Thanks Much.
					Model OPSH
Thanks Much.
