Sharp LC-47SB57UT will not power on
+ More Options
Posts
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Sharp LC-47SB57UT will not power on
    Originally posted by selldoor
    Ok SMD means surface mounted device 8 pins - 8 legs- 8 solder contacts
    See pic - what is the part number SMD in the cream square
    According to the parts list, that is IC902 part# "IC LD7522PS SOP-8". I could just make out D7522PS. The other is IC901 part# "IC ICE2PCS02G PG-DSO-8". According to Google Images, it looks like it is supposed to have a crater in it.
    • selldoor
      Slow Learner
      • 7870
      #42
      Data sheet is here http://www.datasheetdir.com/LD7522PS+PWM-Controllers
      Crater probably signifies the position of pin1
      Pfc controller http://www.google.co.uk/url?sa=t&rct...,d.d2k&cad=rja
      • johnboy1313
        • Nov 2012
        • 1959
        Do you suspect one or both of these to be bad?
          Check fusible resistor R922, R938, R924 to see if they are open.
          • johnboy1313
            • Nov 2012
            • 1959
            None of those three resistors are open.
              Then I would try replacing those two startup caps we have mentions to see what happen.
              • johnboy1313
                • Nov 2012
                • 1959
                Will do, I have to look at my wife's van immediately after work while it's still light out, I'll post back with results after 6:00 central time. Thanks to everyone that has offered advice.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  By the way, the capacitor's that were suggested to be changed are
                  10uf 50V
                  100uf 50V
                  Locally, I can get
                  10uf 100V
                  220uf 50V
                  I was told that these would work. Is that true? If not, I can scavenge from a working power supply or order new and wait.
                    The 100V is fine but you should try to find a 100uF cap.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      ok
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Got the van taken care of early. I put the 10uf 100v cap in and swapped 100uf 50v caps from another working psu. The other psu still works. This one still does not. Same exact symptoms.
                          Wait, where did the second PSU come into it?
                          I'm really lost...
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            It came from an lg 37lg30 with a cracked screen.
                              They are compatible???
                              Since when has LG used Unihan parts???
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                I pulled a capacitor off of each psu with the same 100uf 50v rating and swapped them. I then put each psu back into their respective tvs. The lg still powers up, the sharp still doesn't.
                                  Oh, ok.
                                  Time to look elsewhere.
                                  You have fluctuating 5V standby?
                                  So, do you have other fluctuating rails?
                                  We had a 50" LG plasma here with fluctuating 5V, dead 12V. Turned out 12V diode was dead short.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    I'm not sure what fluctuating rails are, but no other pins fluctuate. If I knew what was driven from the PSU to the main and from the main to the PSU, I could probably temporarily retrofit a known good PSU with the same outputs/inputs (if one exists and happens to be in my basement) to the chassis, just to confirm/disprove a PSU fault.
                                    I've been looking though the service manual, trying to find the answer but I'm not experienced enough to be able to spot it right away. Any chance one of you could browse these?
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      In the attached picture called "flags", what do the circled flags represent?
                                        Nets... they indicate connections to each other (with the same name) done to make the schematic a little clearer.
                                        • johnboy1313
                                          • Nov 2012
                                          • 1959
                                          That's what I figured. Thanks
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • SONY_E-WASTER
                                            Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                            by SONY_E-WASTER
                                            Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                            The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                            then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                            does...
                                            12-26-2021, 05:46 PM
                                          • gavenb
                                            Sharp LC-80LE661U 80 inch
                                            by gavenb
                                            Hi folks!
                                            I have a LC-80LE661U that had some interesting issues.
                                            Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                            I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                            11-12-2023, 02:05 PM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
