Sharp LC-80LE661U 80 inch
  • gavenb
    • Nov 2023
    Hi folks!
    I have a LC-80LE661U that had some interesting issues.
    Initially, it would come on and show the sharp logo and would show normal static before shutting off.
    I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it just powers up the back lights and shuts off without even showing the sharp logo.
    Any advice, or should I just shove this thing off a cliff?
    • 12330
    • U.S.
    Re: Sharp LC-80LE661U 80 inch
    Post clear straight on pictures of all the boards and one of the whole back as to see how everything is connected.
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      Maybe you have bad LEDs, symptom like this can happen. Your backlights are shutting off with the TV right? Or is the picture just going real dim. You have a LED tester to check them? But pictures also help us here too. I have personally had tvs turn on, backlight comes on, see logo and shuts down. The cause has been backlights, sometimes cause was main board, but you've replaced everything. So i would check there.
      • weelsofsteel
        toshiba 32l3753db with start up logo replaced by bob dylan
        by weelsofsteel
        hi
        recently acquired a toshiba 32l3753 smart from ebay as faulty (backlight) replaced said backlight , but on switching on instead of the normal "toshiba logo" i was greeted with a pic of bob dylan !
        as far as i know did not know you could remove a makers logo , tried to contact the seller to see if he could throw some light on the "problem" but no reply
        every thing else with the tv is as norm
        anybody any ideas ?
        01-04-2024, 08:49 AM
      • Teban1306
        [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
        by Teban1306
        Hello everyone!
        I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
        System Information:
        • Model: Lenovo ThinkPad T14 Gen 1
        • Machine Type: 20S1S4E600 (Intel i7 variant)
        • Current BIOS: N2XET42W (1.33) - Latest version
        • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
        What I'm trying to achieve:
        Replace the default "LENOVO" boot logo with a custom image during POST.
        🔧 What I've tried:
        09-14-2025, 11:49 AM
      • Verlengsnoer
        Bios splash/logo change
        by Verlengsnoer
        at firs, i hope this is the right place to post my question.
        Im looking for a tool to change the bios logo.
        everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
        i know that HP has a build in option to change the splash logo.
        but i want to change the manufacturer logo to an own logo.
        I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
        10-28-2022, 09:52 AM
      • superdota2
        Hp 15-ef1081nr it take 1-3 mins to show hp logo
        by superdota2
        Hp 15-ef1081nr
        DA0P5MB26A0 rev A.
        Amd athlon silver
        SN# 5cd10526zy
        possible bios issue?...
        02-29-2024, 10:51 PM
        by momaka
        03-15-2023, 10:17 PM
