Phillips / Magnavox-26MF605W/17 - bad PS
    Looking at a PS that came from a Magnavox 26MF605W/17. Not getting voltage at any of the outputs. Looked up the schematic and am trying to muster my way through it. Getting kind of lost though and hoping for pointers. With AC on, I get 165 VDC on the main capacitor which tells me that the primary is good. Looked next at the FET driving the transformer 7062. The drain has 165 VDC. Pin 1 (Vcc) on IC 7061 has 0.0 VDC. Pin 1 on the optoisolator 7074 has 70 VDC. Pin 2 also has 70 VDC. Pin 1 on the IC 7056 has 1 VDC, but pin 8 has 0.0 VDC.
    Any suggestions on what to check next?
    Re: Phillips / Magnavox-26MF605W/17 - bad PS
    Bump?
      How do those diodes check out?
        OK, lets check the snubber Diode D6055 to see if it is shorted.
        Then please take the resistance reading of the IC7061 (TEA1507P) all the pins with ref to the Ground pin of the IC.
        Then also check or replace the start-up cap C2067 (68uf 25v).
          Snubber diode D6055 checked out well (19 ohms and infinite ohms).
          IC7061 resistances wrt PIN 2 are as follows:
          1. 1 ohm
          3. 30 ohm
          4. 35 ohm
          5. 35 ohm
          6. 25 ohm
          7. infinite
          8. 35 ohm
          Startup cap checked out fine on ESR meter, but will replace as recommended.
            Budm, any suggestions?
              SYMBOL PIN DESCRIPTION
              VCC 1 supply voltage
              GND 2 ground
              CTRL 3 control input
              DEM 4 input from auxiliary winding for demagnetization timing, OVP and OPP
              Isense 5 programmable current sense input
              DRIVER 6 gate driver output
              HVS 7 high voltage safety spacer, not connected
              DRAIN 8 drain of external MOS switch, input for start-up current and valley sensing
              Your readings:
              1. 1 ohm
              3. 30 ohm
              4. 35 ohm
              5. 35 ohm
              6. 25 ohm
              7. infinite
              8. 35 ohm
              Your readigns do not look right. Are the reading shown with letter K, or M?
              Otherwise they are badly shorted out.
                Your readings:
                1. 0 ohm
                3. 0 ohm
                4. 343 K ohm
                5. 10 K ohm
                6. 308 K ohm
                7. infinite
                8. infinite
                Not at all sure why the DVM was off. May have to change out the battery.
                  Pin 1 is VCC pin, should not be reading 0 Ohm.
                  Pin3 also looks wrong.
                    Remove the IC and Pins 1 & 2 are shorted.
                      There you have your problem. Before replacing the controller IC, check the diode that supplies Vcc to it, it could be shot.
                      A working TV? How boring!
                        Will do. Just checked Mouser and Digikey for a replacement and see that this particular chip is not stocked. Suggestions on a replacement?
                          eBay or Mouser?
                          http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
                          May be a common failure....
                          http://www.ebay.com/itm/1PCS-TEA1507...item27c93218c8
                            Found one. Thanks.
                              Replaced the IC and she came up! Thanks to all.
                                Thanks for the repair feedback.
                                  Great to hear -- obviously a common failure, sellers say it is for "Philips/Magnavox"...
