Phillips OLED TV 55P0S9002/05 715G8886-P01-000-004Y Schematic
    • 115474
    Brand: Philips
    MPN: 55POS900255
    GTIN: 8718863012352​
  • francesco65
    • Nov 2025
    • italy
    thanks
    • skapidoul
      • Nov 2025
      • France
      Thank you very much
      • Diah
        Guide : Philips OLED TVs how to remove the protection mode NVM.EED
        by Diah
        OLED Cells over all OLED brands are easily its drooping more currents will be increase which it trick the SOS signal which T-CON driver boards will send to the Mainboards... the NVM software on the Mainboards will shutdown the PSU..
        not all fault at OLED are bad-- some issue can remain working with minimal issue at displaying generate
        Philips OLED TVs. we can switch the protection code to off via binary.
        - ropy it on empty usb stick and insert it while the tv off at USB 1
        -turn on the Tv it will restart 2 or 3 time then plug out the stick and turn on the...
        04-21-2024, 03:21 PM
      • djordje
        Philips 55 oled 804/12 red light blink
        by djordje
        Hello all,
        I have Philips Oled 55 (804/12) with black screen and red light blink.
        I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
        Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
        When i power only psb and tcon with 4 ribbons for panel i only get black screen.
        My questions is what should i do next...
        01-03-2025, 04:00 PM
        Philips TV Power Supply LED Driver MSD3463-T8C2 Schematic
        Philips TV Power Supply LED Driver MSD3463-T8C2 Schematic...
        11-06-2024, 03:47 AM
      • Hillybilly
        philips HTS3530/05 sound system Schematic
        by Hillybilly
        Hi I've been trying to test for a fault on a pcb code 40-S351OA-PWB1G and ha ving tested a certain component with multimeter and atlas dca55 which came up with faulty component also the multimeter set to a diode mode couldn't get a reading.on board i'ts zd501,could anyone tell me if this component would make the pcb drop 42v which supplies to amp side of philips HTS3530/05 sound system please.A schematic with codes for parts would be much appreciated.Thanks
        07-24-2023, 08:13 AM
      • Scarfycake
        ProArt Studiobook 16 OLED (H7600ZW, 12th Gen Intel) Schematic Request
        by Scarfycake
        Hey all,
        I hope anyone can help me get a hold of the motherboard schematics for this system! Struggling with a really strange and tough repair.
        Thank you!
        05-21-2024, 07:07 AM
