phillips lcd keeps blowing fuse
  • TimT
    • Nov 2012
    • 268
    • us
    Re: phillips lcd keeps blowing fuse
    2 diodes beep at both ends.. and 2 read about 5 to 6 and 0.. some go up to 19??? I have some 1n914 diodes they look about the same?
    • TimT
      • Nov 2012
      • 268
      • us
      all on board.. should i desolder one leg?
      • Mr Bill
        • Nov 2011
        • 648
        If it's the larger diodes there could be a part number printed on it. I would desolder one leg of the suspected diodes, lift it out of the board, and then recheck to make sure it is bad.
        The "1" on your meter is infinity. SO a good diode with your meter would read .450 one way and "1" with the probes reversed. The .450 is just an example it could vary depending on if there are other components on that same trace.
        • TimT
          • Nov 2012
          • 268
          • us
          now im confused? " suspected diodes " very few have a "1" on one end most have a reading of 5.0 to 7.0 then reverse probes 7.0 to 8.0... would this be a suspected diode? ...
          ok i just used a new diode " opened a new pack of 50 " and tested you are correct Mr Bill I got .667 then reverse probes got the 1 ..so looks like i still got a bunch of bad diodes..
          • TimT
            • Nov 2012
            • 268
            • us
            there is no " . " on my meter so its not 5.0 but. 500 not many diodes with 1 so about 90% are bad i would think?
            • Mr Bill
              • Nov 2011
              • 648
              If your getting a reading in both directions in circuit then it's going to have to be removed and rechecked out of circuit. I would say if 90% are really bad you are going to have way more time and $$ in the power supply than a working one off ebay would cost.
              • TimT
                • Nov 2012
                • 268
                • us
                #27
                I will remove one of them in the morning and post back. Thank you for your help!
                • TimT
                  • Nov 2012
                  • 268
                  • us
                  #28
                  I tested a diode at .677 And .766 then removed the leg from the board. it test it out good! 1 on one side. could there be something on the board that would cause it to read incorrectly when mounted?
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Yes, thats why it is always good to take the diode off the board and double-check
                    Muh-soggy-knee
                    • TimT
                      • Nov 2012
                      • 268
                      • us
                      #30
                      I would have to pull about 50 of them out lol... shouldn't they test good mounted? or at least most of them if they're in fact good
                      • TimT
                        • Nov 2012
                        • 268
                        • us
                        #31
                        ok, after testing many small diodes ( they all were good) i took a break and started testing some larger ones. 2 of the larger ones are " beeping " on both ends reading on meter is 0..pulled them off the board same thing.. the rest were ok. so I will order these.
                        I would like to test the bridge rectifiers. do i test these the same way? ignoring the middle pin? i guess there attached to the heat sink?
                        • Mr Bill
                          • Nov 2011
                          • 648
                          Here is a youtube video on testing the bridge. Your meter will need to be on the diode mode.
                          http://www.youtube.com/watch?v=dqkT6hF0O3E
                            Those diodes are the bridge rectifier. It's marginally cheaper but less reliable to do it as four diodes.
                            • TimT
                              • Nov 2012
                              • 268
                              • us
                              #34
                              Thanks! I was looking for a chip with 4 pins " rectifier ".. none on the power board.. I will order the new diodes and go from there! how do i find the correct diodes? there marked LT 0342 IN5406 But this turns up nothing is a search..
                              • Mr Bill
                                • Nov 2011
                                • 648
                                That I is probably a 1 (1N5406)
                                http://www.digikey.com/product-detai...TPCT-ND/950583
                                • Mark369
                                  • Jul 2009
                                  • 163
                                  #36
                                  here are the drawings for that board just check the number on the top corner of the board if it is BA01P0F0103 3. the same board that i have in my
                                  emerson lc401em2f.
                                  I have the full pdf ver. just to big to upload on here. that power suply look the same as the one im working on.
                                  • Mark369
                                    • Jul 2009
                                    • 163
                                    #37
                                    I found the link of the manual and the part number for you is on page 74.
                                    http://www.scribd.com/doc/80791100/40PFL3705D-F7
                                    have a good one.
                                    • TimT
                                      • Nov 2012
                                      • 268
                                      • us
                                      #38
                                      thanks everyone I'm just about to order the parts :-). I will report back when I get them installed
                                      • Mark369
                                        • Jul 2009
                                        • 163
                                        #39
                                        Thanks i hope you let us know
                                        • TimT
                                          • Nov 2012
                                          • 268
                                          • us
                                          #40
                                          after installing the new diodes. it's still blowing fuses any suggestions on what I should try next?
                                          • Dannyx
                                            UC3842 Power Adapter Blowing Fuse
                                            by Dannyx
                                            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                            12-05-2023, 12:06 PM
                                          • Tips
                                            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                            by Tips
                                            Looking for some assistance please.
                                            Trying to repair a PD27AOQ samsung power board.
                                            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                            Testing it the fuse blows immediately power is turned on.
                                            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                            any assistance, guidance would be appreciated.
                                            04-11-2024, 11:24 AM
                                          • RogerH58
                                            Samsung 46" TV LE46B530 blowing fuse
                                            by RogerH58
                                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                            06-10-2023, 10:27 AM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • Bootleg1
                                            Samsung UN65KS9800FXZA T-con fuse blowing
                                            by Bootleg1
                                            Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
                                            02-04-2020, 01:05 AM
