lg 32lg3000 white screen faint picture
  • flocko
    • Nov 2012
    • 1121
    #41
    Re: lg 32lg3000 white screen faint picture
    test 2 all pins to ground ic1105 p1 0v p2 3.30v p3 5.10v ic1102 p1 0v p2 1.25v p3 3.29v ic1106 p1 0v p2 3.30v p3 5.70v ic1107 p1 0v p2 2.49v p3 5.07 ic1108 p1 0v p2 1.8v p3 3.30v
    • selldoor
      Slow Learner
      • 7870
      #42
      This is no use - apart from the fact that its hard work reading a long list of numbers set out like that, we need the part number off the regulator. Like it says in the link eg:
      ic1105
      AZ10975
      -3.3E1 ****
      717K24
      Pin 1= 0.00v
      Pin 2= 3.30v ****
      Pin 3= 5.10v
      Then we can tell at a glance it is ok ****
      • flocko
        • Nov 2012
        • 1121
        #43
        ic1105
        AZ10853
        -33E1
        727k24
        pin1 0v
        pin2 3.30v
        pin3 5.10v
        ic1102
        AZ1085S
        -AOJE1
        833J53
        pin1 ov
        pin2 1.25v
        pin3 5.10v
        ic1106
        AZ117d
        -33E1
        838J48
        pin1 0v
        pin2 3.30v
        pin3 5.70v
        ic1107
        AZ1117D
        -25E1
        826N56
        pin1 0v
        pin2 2.49v
        pin3 5.07
        ic1108
        AZ1117D
        -18E1
        838J25
        pin1 0v
        pin2 1.80v
        pin3 3.30v
          All appear to be functional.
          • selldoor
            Slow Learner
            • 7870
            #45
            Sorry if I missed it but can we go back to the OSD - Tom asked if you could see the menus clear and bright or something and you came back and said no -washed out.
            Now - Presumbly you can see the menus as you have adjusted colour/brightness?
            So when you tried the button press for the SERVICE menu could you see that at all?
            • flocko
              • Nov 2012
              • 1121
              #46
              Hi selldoor thanks for the reply after Tom said the regulators looked ok i then pulled it apart and listed the parts on ebay as it looked more and more like the panel had gone? not all bad news though power board has sold already if the two t-cons sell i will be out of the woods thanks again to you and Tom for your time and patience Yours Flocko
              • vign
                • Oct 2013
                • 3
                I have a 32 inch LG 32LG3000 LCD TV. I changed the t-con board but I do still see only solid multi coloured vertical lines. As usual, the sound works fine but no picture at all. And, How to remove the metal frame on this model please. There is no screws on the top or side. I want to see tab bonds on this TV but there is no way I can remove metal frame on it!! Any solution please?! Much appreciated in advance.
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • EazyBone
                  Sharp LC-65Q620U White Screen
                  by EazyBone
                  Another TV topic!!
                  I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                  The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                  Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                  08-21-2024, 12:56 PM
                • hcinne
                  Dell G15 ryzen edition black screen 2 amber 1 white
                  by hcinne
                  I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                  07-23-2024, 07:56 AM
                • arbitarytwist
                  Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                  by arbitarytwist
                  Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                  Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                  03-01-2025, 01:16 PM
