Sanyo dp42848. No picture no sound?has anyone found the problem
  • tomstr
    Tommy
    • Jun 2010
    • 147
    • Usa
    #201
    Re: Sanyo dp42848. No picture no sound?has anyone found the problem
    He had the same power supply lying around and grabbed some parts from it..and its not a story. LOOK WATCH YOUR MOUTH BUDDY.WHY DO YOU HAVE SUCH A SMART MOUTH?YOU MAY BE FAR AWAY BUT .....
      Trollolololololololololl
      Come get me, I dare you. You can find me at the University of Leeds.
      • tomstr
        Tommy
        • Jun 2010
        • 147
        • Usa
        #203
        We are done punk
          • tomstr
            Tommy
            • Jun 2010
            • 147
            • Usa
            #205
            UPDATE POWER SUPPLY IS GOING TO BE REPLACED WITH NEW ONE THE 24v WINDINGS WERE NOT GETTING 24 VOLTS THE REPAIRMAN REPLACED A DIOD OR SWITCH THAT TURNS ON THE 24vSIDE OF THE BOARD.SORRY DONT UNDERSTAND LINGO HE USED.BUT IT FAILED AND HE BOUGHT ME A REBUILT POWER SUPPLY.SO WHEN HE GETS IT I WILL INSTALL IT AND LET YOU GUYS KNOW IF ITS FIXED?SORRY ABOUT THE CAPS.STUCK KEYBOARD..HE ALSO SAID THAT THE POWER SUPPLY IN SANYO TVS LIKE MY MODEL GO OUT ALOT,THEY SELL OUT THE PART FREQUENTLY.I WILL POST LATER.THANKS AGAIN FOR EVERYBODYS HELP
            • tomstr
              Tommy
              • Jun 2010
              • 147
              • Usa
              #206
              Ok update found SMd fuse on on the master inverter black fuse with a 20 stamped on it..checked for continuity found to be open...so used a wire to cross fuse and BACKLIGHT ON...so thanks everyone for the help CAN'T WE ALL JUST GET ALONG!,,,,,
              • SgtRock
                • Feb 2012
                • 175
                Greetings BadCappers:
                --Does anyone know how to report this troll to the moderator on this forum. Calling people punks and making threats is way over the line. As an American and a former resident of Texas, I would like to apologize to SellDoor, Tom66 and anyone else who had to read these scabrous evacuations. I will have to admit though, I have never seen such good knuckle typing.
                "He was born ignorant, and has been losing ground ever since."
                Fred Allen 1894 - 1956
                Best Regards
                Clear Ether
                • tomstr
                  Tommy
                  • Jun 2010
                  • 147
                  • Usa
                  #208
                  Well you need to read the thread too see how he was talking to me very rude and un called for if you were in my shoes i think you whould have done the same
                  • tomstr
                    Tommy
                    • Jun 2010
                    • 147
                    • Usa
                    #209
                    Also im man enough to tell everyone how i fixed the problem. I also in a small way said i was sorry!and told everyone thank you
                    • doorzon
                      AOC AGON AG273QCG refresh problem picture shifts
                      by doorzon
                      hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
                      The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
                      See attached picture.
                      I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
                      However, this could also be related...
                      08-12-2023, 02:36 AM
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • retrorepair
                      SONY KDL-40P3600 Picture Problem
                      by retrorepair
                      Hello gurus, hope you can assist me...
                      I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                      I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                      Thanks in advance.
                      10-11-2024, 05:12 PM
                    • KYBOSH
                      Samsung UN55MU8000 - Backlight But No Picture Problem
                      by KYBOSH
                      Hello all
                      I pick this up free as a repair project for the holidays.
                      The original symptom was power cycling after 3-4 seconds with a single red light flash.
                      To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
                      I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side...
                      12-21-2022, 12:42 AM
                    • Rusenga
                      Samsung PS43E450A1R Picture Problem
                      by Rusenga
                      Hie techs, I have a samsung plasma TV which when plugged in shows a very dull reddish image. Tested some voltages and below is what I get:
                      Note the green light on the tcon flashes every second.
                      Power supply board:
                      PS on 0v
                      Stby 5v
                      VS CON 1.72v
                      VS ON 3.2v
                      VS 208v
                      VA. 57v
                      X buffer :
                      Svt vs 209v
                      Svt xout>flactuating between 280 to 900v
                      Y main board:
                      Svt vs. 208v
                      Svt ve. more than 1000v
                      Svt yg c More than 1000v
                      Svt yout flactuating between 400v and 1900v
                      Svt...
                      11-24-2023, 09:26 AM
