Philips 42PFL7662d/12 problem: backlight?
  • koektrommeltje
    • Mar 2009
    • 15
    Hi
    I'm in need for some help to repair a Philips LCD TV which isnt functioning like it should: no video, no backlight. The only thing i can do is switch the tv on and off..
    The television:
    LC420wu5
    The problem:
    Well, the only thing i see is a black screen. No backlight, not even one second
    What have i done allready?
    I googled, found out that this particular tv has bad inverterboards. Swapped the BD9897FS chip on the masterboard, checked the fuse on it, checked the SK4075 mosfet's but no result.
    I ony swapped the BD9897 chip, even though there was no visible damage to be seen. Someone told me that the LED on the masterboard inverter should ligten up when that IC is ok but even with a new BD9897 IC mounted that wasn't the case. No LED visible on the inverterboard
    No backlight visible, not even a single flash
    When disconnecting the slave, i also get no result. Still defective the inverter masterboard?
    What do i want?
    Save this television from the junkyard. And therefore, i can use your help!
    Anyone any idea what the solution is to this problem?
    And, how i can be sure that it's the inverterboard that cause theses problems? Maybe it's something else?
    (The PSU isnt the problem i think. It's all rubycon caps that are on it. I measured the fuses, diodes and all OK.
    Anyone any idea how i can solve this problem?
    Thanks in advance!
  • drpj23
    • May 2012
    • 528
    Re: Philips 42PFL7662d/12 problem: backlight?
    Pictures are nice (using manage attachments feature).
    Caps and the HV transformers can also go out on the inverter board (or are at least common)
    I suppose you can verify that all voltages from psu are correct. There is probably a BL_ON pin on the inverter, if so, what's the voltage on that pin?
    So you you can't even see an image (such as a menu) with a flashlight?
      Yep, good clear pictures of the all the boards will be big help.
      • koektrommeltje
        • Mar 2009
        • 15
        I will take some pictures of the televisions inside later this day and put them here.
        I can't see any video. Using u flashlight isn't showing anything on the screen as far as i can see.
        From the master inverter i swapped one capacitor, but the other one is ok. I'll swap that also later on. That's not the problem.
        No.. the only visible thing i can do is putting the tv on and off with the standby button. And then i can see the red LED on the front of the tv.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Please can you update your profile with at least country and mains voltage.
          Did you test with a source - dvd player or something -was the sound working?
          There is arepair kit for the inverter board - a bad sign as it suggests it is a common failure- it includes an ic with lots of legs - so not easy to remove/replace.
          • koektrommeltje
            • Mar 2009
            • 15
            https://cdn.badcaps-static.com/pdfs/...43f0f20fec.pdf
            > The link for the modification for the specific inverterboard as advised bij Philips.
            Im from the Netherlands and here the electricity is 230V.
            Anyway, problem is solved at the moment. Only thing to do is the modification from the link here above so that it won't come back.
            I only replaced the BD9897FS driver IC and programmed my logitech harmony for this device and pushed some power on/of buttons (after i swapped the bd9897fs chip. That made the blue led appear at the front of the tv.. the backlight lighted up and...it worked again.
            Later this day, i'll upload some pic from the inside of this television.
            I replaced the BD9897FS quite simpel. With a sharp Stanley knive i cutted the pins. Then removed the body, put some flux on the pins and removed these pins on the board with a soldering iron with a little bit of solder on it. Then resoldered the IC. Again with a lot of flux and with a little bit of solder on the tip gently touching the pin with the corner of the tip from. No problem
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              I dont follow - what happened between
              "What have i done allready?
              I ony swapped the BD9897 chip, even though there was no visible damage to be seen. Someone told me that the LED on the masterboard inverter should ligten up when that IC is ok but even with a new BD9897 IC mounted that wasn't the case. No LED visible on the inverterboard "
              And it working?
              • koektrommeltje
                • Mar 2009
                • 15
                And it working?
                What i did between? Nothing, except that i programmed my logitech harmony remote control for this television and pushed some buttons and then there was power: the blue led on the front of the tv lightened up, the backlight went on.
                Obviously there are two ways to power on/off the television. One standby (red LED), one compleet no voltage i think? It wasn't mine tv, so i didn't know that and ik didnt have the remote for it. But, i powered it on.. which wasn't the case earlyer obvious :X
                Looking at the repair: I've only swapped the bd9897fs on the MASTER INVERTER (and unsoldered en resoldererd the sk4075 mosfet. Didn't swap them.
                Later i'll add pics. I made them, but can't find the cable to upload them.
                • koektrommeltje
                  • Mar 2009
                  • 15
                  And it failed again... worked some week or so
                  What could that be? I only swapped the BD9897FS and made the modification as listed in the link from Philips.
                  How come this driver IC fails again? Is that because of bad mosfets?
                  • koektrommeltje
                    • Mar 2009
                    • 15
                    The master inverterboard. I swapped the BD9897FS driver IC and then it worked. And failed some week later or so.
                    The modifications with the resistor, capacitor and the 33v zener diode 33 are also visible on it.
                    The 33v is a normal zener diode.. although it should have been a 33V TVS Zener. That shouldn't be a problem i was told. Is this true?
                    The slave inverterboard at the right side.
                    And a picture with the master inverterboard left.
                    The slave inverter isn't updated by the way. If this one fails and the master is OK. I suspect to halve a half screen? Correct?
                      "The slave inverter isn't updated by the way. If this one fails and the master is OK. I suspect to halve a half screen? Correct?" Is that what you see before the screen goes black. The MASTER/SLAVE work like push-pull so both of them have to work, otherwise it will go into shutdown. I use 33V 5W Zener on my mod, so that is not the problem. I modded both of my boards.
                      • koektrommeltje
                        • Mar 2009
                        • 15
                        Well, at the moment i don't see a thing on the screen. I repaired only the master. Some days later, the TV was giving the same problems. At the master inverterboard i only swapped the db9897fs chip and unsoldered and resoldered the sk4075 mosfets after having them checked. It worked then... for some days.
                        I've order new parts; going to replace the BD9897fs again on the master and also go change all the sk4075 mosfets. After that i'll mod the slave board completely.
                        I'm not sure, but i think i used 1.3W 33V zeners. Can't tell you if these failed after repairing but it has worked afterwards.
                        • koektrommeltje
                          • Mar 2009
                          • 15
                          Today i replaced all the MOSFETS and the BD9897FS again on the master. After that it played again.
                          I assume the MOSFET were faulty on the masterboard. Again: no visible damage to the bd9897fs
                          I also replaced the MOSFET on the slave, just in case. Want to do the other modification on the slave, but i forgot to buy the 4.7ohm resistors :X so i can't complete modify it.
                          Question:
                          -will that be enough, or do i really modify the slave complete?
                          -if it start up again, is there any necessary to swap the slave bd9897fs on the SLAVE?
                            I would mod the slave board also, you also should replace those two lytics caps on both boards. The IC is usually damaged by the shorted out MOSFET between the Gate and Source pin. My TV is still running and I hope Philips is correct about this mod ii that tehy released since mod i dd not fix the blow up problem. The Zener is to Clamp down the 24V feeding it since when power supply is turn on, it does put on high voltage spike, that is why they want to clamp it down to around 33V. I believe the max VCC for the IC is around 35~40V.
                            • koektrommeltje
                              • Mar 2009
                              • 15
                              So it's not necessary to swap the bd9897fs IC, since i've swapped the slave mosfet even though it was working well.
                              I'll modify it further more; will buy the resistors so i can complete the modification on both boards.
                              • Schorsch87
                                • Feb 2013
                                • 55
                                I had the same problem with mit 42PFL7662 TV. I changed out the ICs, checked the mosfets and did the modification. Now the TV starts, backlight turns on but only for 1-2 seconds. While the backlight is running I hear a high/shrill noise from the inverter transformers. What could cause this symptome?
                                • MatBov
                                  • Jun 2015
                                  • France
                                  Hi, I've the same problem. The backlight turns on during few seconds. During this time, I've also this noise.
                                  Do you find a solution ?
                                  • janos6662000
                                    Philips 47PFS7509/12 LCD TV problem
                                    by janos6662000
                                    Hi
                                    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                    When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                    I downloaded original firmware and applied the update, but the problem remained.
                                    From a colleague i received a "factory package software" which is a lot bigger.
                                    I made another firmware update, but still did not solve the problem.
                                    Somewhere on the way the error got worse, because at the moment the...
                                    08-12-2025, 12:54 PM
                                  • courtcircuit
                                    Philips HTS8000 home cinema noise problem
                                    by courtcircuit
                                    Hello
                                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                    Removed each of tyhe boards
                                    02-08-2025, 08:22 AM
                                  • theone111
                                    by theone111
                                    3. Problem: TV shuts down
                                    07-22-2024, 10:36 AM
                                  • bohaboha
                                    PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                                    by bohaboha
                                    Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                                    how to fix it thanks
                                    02-05-2025, 09:23 PM
                                  • atkallu
                                    Philips 58PUS8545 t-con problem or something else ?
                                    by atkallu
                                    Hello
                                    I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
                                    See the attached image.
                                    I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
                                    But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
                                    T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
                                    01-13-2025, 11:23 AM
