PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
    how to fix it thanks
  • Diah
    • Feb 2013
    • 6499
    yours TV very old. no server update connection.
    the service as i know support till 2009 series XXPFLxxx4
    • William1967
      • Nov 2017
      • 217
      • Netherlands
      Update is possible via USB, search for 32PFL3403/D firmware with Google or similar searchengine.
      If you want to switch of the shop mode Press MENU on the remote control and select TV Menu > Installation > Preferences > Location.​
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        Hi i did it several times switching from shop mode to home mode nothing happened . same for initial factory stage the set stay always on shop mode.
        honestly i have no idea the meaning and the resold of the update i just try it in hope to fix it
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          yes it is but it must be a way to get it back to action everything is ok with this set just that shop mode
          • Diah
            • Feb 2013
            • 6499
            this because it switched to shop mode at service menu.. need to turn off from there
            • bohaboha
              • Nov 2012
              • 1017
              • sweden
              How to get in to the service menu on this old model if you have any idea
              • Diah
                • Feb 2013
                • 6499
                try all code of Philips... as i know they have over all didn't change the code
                Old model they have contact points on MB need to jumper.. take alook on MB
                • bohaboha
                  • Nov 2012
                  • 1017
                  • sweden
                  thank you i ll try all of them and se inside on MB
                  • Diah
                    • Feb 2013
                    • 6499
                    you should find points on MB SDM and CSM,​
                    • William1967
                      • Nov 2017
                      • 217
                      • Netherlands
                      Type 062596 MENU(HOME) or 062596 OK on your remote to enter the service menu.
                      • akwky
                        by akwky
                        Hi!
                        04-14-2025, 01:56 PM
                      • ahmedtou
                        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                        by ahmedtou
                        help me please
                        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                        I will share all the details with you, including the disc information.
                        Code:
                        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                        Current Profile: BD-R
                        Disc Information:
                        Status: Empty
                        State of Last Session: Empty
                        Erasable: No
                        Free Sectors: 12,219,392
                        Free Space: 25,025,314,816 bytes
                        Free Time: 2715:27:17 (MM:SS:FF)
                        Next
                        08-27-2025, 08:49 AM
                      • TheUser
                        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                        by TheUser
                        Hello to everyone ,
                        This is my first post here, and i would like to share with you a small story in case you can help me.
                        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                        02-10-2024, 02:07 PM
                      • lordgeny
                        z490-f gaming bricked after bios update
                        by lordgeny
                        I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
                        11-02-2023, 09:03 AM
                      • iMuhtaseb
                        A1706 2017 critical update
                        by iMuhtaseb
                        this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                        we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                        One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                        I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                        08-13-2024, 08:41 AM
