Philips 58PUS8545 t-con problem or something else ?
  • atkallu
    • Jan 2025
    • Finland
    Hello
    I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
    See the attached image.
    I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
    But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
    T-con two flex-cables have been changed to cross but nothing changed, so it is not due those flex-cables.
    T-con voltages from measurement points have been measured, all other voltages are correct but VGH voltage was 7V.
    I think it should be 12V~25V, am I right ?
    So, can it be faulty t-con or is it faulty LCD-panel ?
    If it is faulty t-con, can I replace the t-con board straight without any programming or software installations if the t-con board is brand new and it is not been any television before that ?
    Thanks for answers !
  • Nugzzy
    • Dec 2024
    • 9
    • Portugal
    Heres a Service Manual for that series TV - Hope it helps you or someone more technical with the repair! Best of luck - keep us posted with your progress as it may help others in the future!
    • atkallu
      • Jan 2025
      • Finland
      Thanks for your answer !
      I think it is LCD-panel issue, but I do not be 100% sure about this.​
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • Fly_Among_Stars
        VIZIO E70-E3 Half picture with half TCON
        by Fly_Among_Stars
        I have a VIZIO E70-E3.
        Symptoms: Black screen, no picture, but LED backlights are working.
        I probed the power board and voltages are as listed on the board.
        Main board appears fine, too.
        I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
        There are two separate ribbon cables feeding the LCD.
        If both are connected, the screen is black.
        If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
        04-24-2023, 08:20 PM
      • Wittie
        Philips 55OLED803/12 HDMI ports "half" defective
        by Wittie
        Hello everyone, Please excuse my poor English, but I'm using Google Translate ^^ I'm having a problem with the HDMI and USB ports on my 55OLED803/12. It's no longer possible to connect an HDMI device and see the picture. No matter which port I use, it only recognizes the device as an input source and displays it in the list (BD player, Fire TV, etc.). However, the actual picture doesn't appear in the same state. My home theater system also runs via the BD player - it still receives a signal and plays the sound correctly (e.g., from the TV program or an app like Netflix). This works with both HDMI...
        03-19-2025, 09:38 AM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Chris24
        LG OLED77C2PUA CUSQLJR Does not turn on - solid standby light with one blink.
        by Chris24
        Hello, been a while since posting and always appreciate this forum and the help.
        Picked up an LG OLED77C2PUA that does not turn on.
        The standby light does come on when plugged in. Pressing the on/off button on TV (or LG remote) the red light turns off for 1 second and comes back on steady. I took off the back panel and tested the power supply. When pressing the power button, the 20V and 12V to Mainboard spike to 19.9 and 11.9 for a few seconds then slowly drop back off. Can tell the supply is coming on for 2-3 seconds. The 12V to TCON also spikes to 11.9 then drops back...
        01-27-2026, 12:03 PM
