SONY KDL-52S4100 Half screen dead.
    I think I have my problem narrowed down a little more. I have a SONY KDL-52S4100 and I put in a new Video board and a new T-con. When I have the TV on I have a Black screen/no picture but have great sound with back lighting. however If I disconnect both ribbon cables from the T-con to the screen IC boards when OFF. then reconnect the right one and leave the left disconnected, I turn on the TV and have great picture on that half of the screen. Then, with the TV on I plug in the other ribbon cable to the t-con and the whole screen goes dark. I have not opened the TV more then getting to the boards on this TV, but others I have torn all the way down. I believe from this that my problem is the LEFT IC board, at lest I think it is called that. any more Ideas would be great.
    Re: SONY KDL-52S4100 Half screen dead.
    What happens when you only have the left connected?
    Does this happen with the older TCON?
    -Probably wouldn't connect/disconnect while on to reduce shorting possibilities.
    Picture of the TCON (or what you mean by left IC board) may be helpful too by using the manage attachments feature.
      Ok I got it fixed. If I just had the left T-con cable in Still no Picture, So I took the TV apart down to just the screen and found nothing. So I put it back together but half way I decided to put it together where I can test it. "test it without most of the screws back in. And then I got great picture. so I put pressure on the screen edges and the left side like 75% up from the bottom would kill the whole picture if like something grounded out. so I pop out that part of the screen and reset the tv. "reset by just turning it off then back on" and I would have the picture again. so I put a spacer there and put it back together. so far seems to be working. If I knew then what I know now I could have saved alot of money getting parts that where most likely not bad. But I saved this TV from the trash pile it was in.
        I'm guessing a bad panel? I had a 46" sony with this no picture backlight on problem also. Sometimes the screen would go black especially if I put pressure on both ends of the tv. (Like twisting it as if it was on a swivel stand) The picture would turn off immediately after and it only comes back on when I turn it off and back on. Sometimes double pictures would come up also.
          My is still running, famous bad tab bonding problem.
          http://s807.photobucket.com/albums/y...20KDL-52VL150/
            Bud looks like you are putting pressure on the left most tab, was that causing the right side picture to go out??
              That section affect left half of the screen, there are more tabs on the right side of the screen also.
