Tv has no picture or sound. the backlight works. I have to unplug the tv from outlet to turn it off. I have another Tv that does the same thing. is this a common problem? I would like to fix it but not sure were to start.
vizio 42 gv421 no picture/sound
Re: vizio 42 gv421 no picture/sound
Go to search this forum and type in Vizio, or Vizio GV421 and look at other posts, i myself fixed two vizios recently one was a bad voltage regulator on the main board. the other set had a defective T-CON Board. searching other threads/posts will give you a chance to see what other people have found. but most likely someone else will post some troubleshooting steps to help you diagnose it. Good Luck! -
chip with " green " is that normal? the chips are by Amtel 710 24c028n su18 and Atmel 716 24c028n s018 I cant find any information on these.Attached Filesif you find these attachements useful please consider making a small donation to the site
I think those green and silver spots helped someone to denote pin 1 on the chip. They were replaced, or factory screwOP. You need better focused pictures. Front and back of the power supply board if possible. The whole main board. And a good picture of the whole back side of the TV so that the regular members can see how everything hooks up. I to had a bad voltage regulator on a 42" vizio. It sounds like a main board problem. But could be ccfls. Good luck.Comment
I wont mess with the chips! as i don't know what im doing
I cant see anything wrong.. the caps " look " fine. here are more pictures.. I am having a hard time with my camera. so excuse the pictures.
On those connectors on the power supply, do you see a pin marked 5V (or 5VS, or 5VSTBY), and a pin marked ON/OFF, PSON or STBY?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
OK, what is the voltage at 5VSB and PSON when the TV is showing the ORANGE (standby) logo?
Then press the power button. Do the voltages change?
The main board and inverters should be plugged in for this test.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
there 3.5.. funny i removed the ribbon cable to check then they were 3.0 then i put the cable back they were still 3.0 hopefully i am using the multimeter correctly. no change when i turen the tv off & on. better pictures of mainboard. is the powerboard ac and mainboard dc?Attached Filesif you find these attachements useful please consider making a small donation to the site
5VSB is just 3V? This is a problem. Can you just test a fresh AA battery just in case your meter isn't working right, you should get around 1.5-1.6V.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ah did you use DC volts or AC volts? You should use DC volts.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
"retested the pins all were 3.5v ac" AC?Never stop learning
I just tested it on the DC setting. I'll assume the power gets converted from AC to DC on the power board? 5VSB fluctuated between 1.44 to 1.55v PSON fluctuated between -0.08 to -0.16 and would jump to 0.78 to 0.86 when I turn the power on.Comment
by ggil44Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
Assuming...7 Photos -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... - Loading...
