Sharp LC-40LE810UN question
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up last night this TV which seems completely dead, no LED light at all.
    The TV has some metal parts rusted and the back cover has a lot of white mess on it. By the way the back it's metal(!).
    This TV is an LED thin TV.
    I had very little time to look at it, I have just checked a couple of components, like fuses, rectifier, main capacitors and such. They all seem fine.
    I have found a component which I can't identify, it looks like a glass fuse, but I'm not sure, I can't get continuity on it.
    What do you think, what is it?
    This picture is from shopjimmy, it's not mine.
    Later today I will take some pictures.
    I have a feeling that it's a water damaged TV.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sharp LC-40LE810UN question
    It's going to the chassy ground through that gold circle capacitor.
      Surge suppressor, spark gap type. Very nice, those are expensive parts, good to see that Sharp/Delta include one.
      • tibimakai
        • Jan 2012
        • 3680
        Thank you.
        How can I check it out if it's good or not?
          It will almost never fail. If it does, it will have exploded.
          Check all fuses that you can see & check for approx 165V across the large caps on the right hand side of the power board.
            Any sign of corrosion on the backside of the board? You should have continuity from each one of the fuse to each one of the bridge with the '~' on it (one fuse will go to the ~, and another fuse will go to another ~ if one fuse is for HOT, and another fuse for Neutral ). Is there a main power switch somewhere since I do not see relay on the board.
            • tibimakai
              • Jan 2012
              • 3680
              It's only a sensor style switch. The rest I will have to check when I'm actually in front of the TV. I'm "working" now.
                I am "working" now also!
                • tibimakai
                  • Jan 2012
                  • 3680
                  This type of PS should have 165V/398V-when on?
                    Are the two large caps laying on their sides rated at 450VDC, if it is, this set has PFC circuit, there is a large transformer on the top right of the board, that may be the PFC choke.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Yes, they are rated at 450V.
                        Then yes, they should have around 400V on them when TV is on. The TV without PFC in the US will use 250~350V cap since they are cheaper.
                          And how many voltages do you get across them?
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Right now nothing, the board it's on my night stand and the TV it's in the garage. I just had a late lunch.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I had a couple minutes and I have measured the voltage across the two capacitors and there is a 161.5V. On the PD connector all pins measure 0V.
                              Tomorrow I will take some pictures with my board.
                                OK, this is good, the problem is probably on the PSU. Check for 5VSTBY.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I will, but since none of the LEDs is turning on, then I assume that there is no 5V.
                                    Bad assumption. I've had a Toshiba TV with a perfectly functional power supply, but it was still dead (no LED, no sign of life at all) - it turned out to be a failed 2.5V regulator on the video board.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      My bad.
                                      Which one do you think it is? The LB-8 STB?
                                      I haven't had time to measure the LB connector, but on the PD there is no voltage present on any of the pins.
                                        You need to check all pins for any voltage. It looks like this TV doesn't use a standby supply, just one main supply. So, if the main supply is dead, you need to look there for the fault.
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:10 PM
