42" Spectrincq no power
  • avaktech
    • Jan 2012
    • 68
    • US
    Re: 42" Spectrincq no power
    Bud m, c44 is an electrolytic on its side, small one, 25v 47uf. But I can see why you'd say otherwise, just a bad picture.
    • selldoor
      Slow Learner
      • 7870
      Ok - so its the RED or Reddish one. They dont often fail or else they fail dramatically. and split.
      It doesnt even look bulged - have you found/tested the Bridge Rectifier yet?
      They often fail and take out the fuse.
      • avaktech
        • Jan 2012
        • 68
        • US
        Can you please help me identify the bridge rectifier?
        • avaktech
          • Jan 2012
          • 68
          • US
          Maybe this one? It has 4 legs.
          • avaktech
            • Jan 2012
            • 68
            • US
            Bridge rectifier, if it is, tests bad, it reads in same in both directions which based on my very limited knowledge indicates its bad. What else would it take out when it went?
              Usually that's it, damage is limited to the bridge. They die from heat, age, and voltage spikes.
              • selldoor
                Slow Learner
                • 7870
                #27
                Did you not see post 11? where I asked you to test it told you where it was and how to test it?
                • avaktech
                  • Jan 2012
                  • 68
                  • US
                  #28
                  I may not be the sharpest, or most focused, but I am however very grateful! Thanks to all who contributed. I'll let you know how I make out when my kids get to sleep and I can pay attention to what I'm doing.
                  • avaktech
                    • Jan 2012
                    • 68
                    • US
                    #29
                    Ok so I replaced the bridge, replaced bulging caps, and popped a new fuse in. What did I get? Fireworks! Got some sparkage at the main switch and a glowing red light, at least its more than I had the first go around. When I push the power button it flashes 3 times and nothng. I pulled the board and had another look, noticed R1 burned up not sure what the value was cause I can't read it! Anyone wanna jump in?
                      Check for 5Vstby, then post a picture of the main board and check the two buck converters on it.
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        You might want to try and rig a light bulb in place of the fuse for further tests.
                        http://antiqueradio.org/dimbulb.htm
                        Has R1 totalled or can you clean it at all with isopropyl alcohol
                        -sometimes the color rings are still on the bottom side?
                        Can you post a pic showing where it was on the board?
                        • avaktech
                          • Jan 2012
                          • 68
                          • US
                          #32
                          R1 is a surface mount on the baskside. I'll mess about with it when I get some coffee in me.
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            If its smd that will be more difficult unless it was labeled on both sides
                            I have this, the source is reliable but will depend on whether I asked the
                            correct question so If we can get a second opinion from somewhere.
                            Charles Hyde & Son
                            Hi. If you need any assistance, please feel free to ask me a question.
                            ME
                            Any chance you could advise the vaule of R1 in the KT14 kit for the AD301M24-4N1
                            Charles Hyde & Son
                            We apologize for keeping you waiting. Our operators are busy at the moment, please leave us a message with your email address and we'll get back to you shortly.
                            You are currently being served by
                            xxx - CHS
                            xxx - CHS
                            wait
                            Hi, please wait, we are dealing with your request
                            dave
                            my email is xxx
                            XXX - CHS
                            R1 = 1.5k
                            ME
                            Thankyou very much
                            XXX - CHS
                            Thank you for using our on-line chat
                            • avaktech
                              • Jan 2012
                              • 68
                              • US
                              #34
                              Selldoor, you are a rockstar! I included a pic of the location of r1. What would cause it to go?
                              • selldoor
                                Slow Learner
                                • 7870
                                #35
                                Didnt really need the second opinion - this is one of the reasons we ask for
                                good clear pictures.
                                Will have to wait for Budm or some circuit wizard to make a guess as to why it might have blown.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  also double check the new capacitors are fitted the right way round mistakes can happen.
                                  • avaktech
                                    • Jan 2012
                                    • 68
                                    • US
                                    #37
                                    Caps are in the right way, I did not replace all of them, just the noticeably bad ones. Here's some more damage I just noticed, one of the 2 resistors I asked about originally popped. I can't tell if they are resistors or fusibles since they tested like fusibles.
                                    • avaktech
                                      • Jan 2012
                                      • 68
                                      • US
                                      #38
                                      I hope you guys haven't jumped ship on me! I also found this diode to be bad. Is this likely a symptom or a cause? Also can someone please tell me what these resistors are? Thanks
                                        What is the P/N of that IC by the bad resistor as shown in post34?
                                        • avaktech
                                          • Jan 2012
                                          • 68
                                          • US
                                          #40
                                          tny266pn, any easy tests for it? It had a tiny heatsink that popped off.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • survivalbloke
                                            Acer Predator PT516 - no power, drawing 2.8a lid closed, battery connected
                                            by survivalbloke
                                            This is a Predator PT516-51s laptop, serial number is rubbed off. Board is LA-L211P Rev 1A. Charging light is on, machine draws 2.8a lid closed. If I press the power button, I get a blue power light indicator about 5 seconds, then it goes back off. I pulled the board to discover that with battery and AC connected, battery mosfet 1 light up under thermal. I then verified a short to ground on battery mosfet 2 source. If I inject voltage there, my PSU goes to current limit, but nothing illuminates on the board - anywhere, either side. I removed mosfet 2 but still have the ground short at source....
                                            10-21-2025, 01:35 PM
