Need Some Help
+ More Options
Posts
  • burner6999
    • 89
    Need Some Help
    I have a Nuvision NVU53FX that I am trying to trouble shoot. It has no power. It has no lights or anything on. When I plug it in with the back off the relay doesnt even click. I have 2 of the same models and switched the power supply with the other and it worked. Meaning this tv worked with the other tvs power supply. I have taken a picture of the board and Circled the relay that clicks when plugged in on the working tv. Could this relay be bad? Is there anything else between the incoming power and that relay. Besides the fuse that is. Is there a way to test the relay on board? Also the relay is a JZC-36F 005-HSLT
    Can you give me a link to one that will work from digkey?
  • PowerAmpFreak
    • 977
    • Sweden
    Re: Need Some Help
    You could short the relay contacts temporary to check if there is a problem with the relay.
    Probably the relay doesn't recieve a proper coil drive voltage, which you should confirm first.
    Probably there is some kind of standby supply that needs to be up and running to supply the relay circuit and other auxilliary stuff. You have to find this supply and confirm that it's outputting proper voltages.
    • selldoor
      Slow Learner
      • 7870
      Re: Need Some Help
      Did you check the fuse and did you check for voltage at both ends of the fuse?
      Do you get any voltage at the BIG Cap -With it plugged in and switched on, Meter on volts 600 DC put red lead on positive leg and black lead on negative leg - polarity is important CARE high voltage & do not touch any heatsinks.
      • burner6999
        • 89
        Re: Need Some Help
        Thanks for the response guys. Now it is doing something different. Not sure what changed but now if I plug it in I get nothing, but if I let it sit for a couple minutes then unplug and plug back in relays click but wont turn on but the light on the front changes colors like it does when it comes on. Also when it does this the light doesnt flash like it normally does when it comes on. Normally the light goes from red to blue then blinks 4 times, then turns on. Then if I unplug and plug it back in again the relays click and then it turns on and will stay on. But if I turn it off and let it sit, it wont turn back on. The light on the front changes like it is coming on but it doesnt blink and the tv doesnt come on. Then if I unplug and plug it back in it will work like normal again. I think it is only the power supply cause it does the same thing in both tvs. But the working power supply makes both tvs function like normal. I am so confused. What could be causing this now?
          Re: Need Some Help
          Classic bad startup cap or bad main caps issue.
          • selldoor
            Slow Learner
            • 7870
            Re: Need Some Help
            Still do the test on the BIG cap - do it in each fault state.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              Re: Need Some Help
              check these caps marked in red
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • burner6999
                • 89
                Re: Need Some Help
                ok so I tested the caps. The main cap (Big one) gave me 400V. The other ones I marked the readings on the picture. The best I can tell the are all 50V caps
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  Re: Need Some Help
                  what readings are these?,capacitance,voltage,esr?
                  • burner6999
                    • 89
                    Re: Need Some Help
                    Voltage.
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      Re: Need Some Help
                      you need to test them for esr,do you have a esr meter?
                      • burner6999
                        • 89
                        Re: Need Some Help
                        No I do not.
                        • multimeter
                          • Jan 2011
                          • 739
                          • united kingdom
                          Re: Need Some Help
                          it does sound like you have a startup cap problem,but could be other things though,do you have a hot air gun/hairdrier?
                          • burner6999
                            • 89
                            Re: Need Some Help
                            I have a hair dryer.
                            • multimeter
                              • Jan 2011
                              • 739
                              • united kingdom
                              Re: Need Some Help
                              put the power supply back in the tv,connect all the cables back up,make sure the psu is grounded by fixing it back with its screws,leave the back cover off,use the hair drier on the hot setting.switch the tv on at the mains and its standby,heat the circled caps up ,if these caps have gone high esr,the heat usually will lower the esr enough to get the cap working for a while,.if this dosent work,it still dosent mean that the caps are good and will need to be eliminated by further testing
                              • burner6999
                                • 89
                                Re: Need Some Help
                                Ok I will let you know.
                                • multimeter
                                  • Jan 2011
                                  • 739
                                  • united kingdom
                                  Re: Need Some Help
                                  i forgot to add,as you heat the caps,make sure you cycle the standby switch on the tv or the remote standby,as some tvs need it to turn on
                                  • burner6999
                                    • 89
                                    Re: Need Some Help
                                    Ok I did that and now it is doing nothing again. I did notice that when it isnt working I get no power to the circled area. From the plugs I only get 5v and 3v Nothing on the 24v, 14, or 12v pins.
                                      Re: Need Some Help
                                      You are getting the standby voltages OK, but to have the 24/12V power supply running, it needs to get PS_ON signal from the main board, you need look for the pin on the power supply or on the main board that is labeled with PS_ON, P_ON, etc.
                                      Closed up pictures of the connectors will help.
                                      • burner6999
                                        • 89
                                        Re: Need Some Help
                                        Having trouble with the up close picture but the only thing I saw on there was on/off pin. On it I have power but it keeps jumping from 3.5 to2.9v Back and forth. Edit: Got the pic. The ones circled have the connectors and the big one on the left has the on/off and goes to the main board.
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
