Need Some Help
+ More Options
Posts
  • burner6999
    • Jun 2012
    • 89
    Re: Need Some Help
    I ended up getting it working. I ended up buying a power supply from a proscan tv and that had the same board but different pin headers. I took the pin headers off of my old board then had to move 2 zero ohm resistors that were used as jumpers for the backlight. As far as the other board goes I did replace all components that I knew were bad but nothing changed. So I gave up. I got the new board from a local tv shop a gave them a 40" dynex tv that I got for free and $25. So thanks for all the help guys and try to remember that some people are still just learning. I am trying to get better at all this. Sorry if I didnt do everything right when it comes to testing.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • CMCM
      Russound CA4 Power Supply Repair
      by CMCM
      Hello Everybody,
      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
      The outputs marked 12v and 20v are all measuring only 1v.
      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
      The capacitors physically look clean (no bludgesor leaks) and...
      07-03-2025, 01:12 PM
