I'm Pete from New Zealand.
My Toshiba 42inch LCD tv has no picture. The ccfl bulb is not turning on.
I've already replaced the four 35v 680uF caps on both the master and slave board.
I've read a couple of posts on here.
Refering to this thread here: https://www.badcaps.net/forum/showth...light=BD9897FS post number 13, I found 2 extra grounded pins. Pins number 27 and 28 of this datasheet https://cdn.badcaps-static.com/pdfs/...97ffe28ccf.pdf which is the db9897fs chip.
Is it possible the little smds connected to the chip are to blame for the ground or is it a chip problem?
Also the resistance of one of the FETs is not the 8.5k (or in my case 8.29-8.33) it's supposed to be.
I tested the FETs on the main board using this website http://www.sentex.ca/~mec1995/gadgets/mostest.htm and they all passed.
I used this thread https://www.badcaps.net/forum/showth...FS+8.5k&page=2 last post, to figure out the FET resistance.
The problem is on the master inverter board.
Any insight would be much appreciated.
Cheers
Pete
Cheers
Pete
