Sony KDL46S4100 backlight not working
  • horn1991
    • Jul 2012
    • 12
    This TV was given to me by my brother. It quit working on him one day, and he just went and bought a new one.
    I've searched and researched quite a bit so far. I decided to go for it and try a new main A board.
    With it all hooked up, still no picture. I turn the TV on, and the green power light is solid.
    If I unplug CN303 with the power on, the TV cycles through a green screen, a blue screen, a red screen, and then a striped screen. The striped screen is one quarter red horizontally, one quarter blue, one quarter green, and one quarter gray.
    When I plut the connector in, the backlight goes off.
    Any advice, thanks.
    Dave
  • anmol
    • Mar 2012
    • 73
    • India
    Re: Sony KDL46S4100 backlight not working
    check inverter board
    • tibimakai
      • Jan 2012
      • 3680
      No blinking LED?
      • horn1991
        • Jul 2012
        • 12
        nope, no blinking LED.
        Not sure how to check the inverter board. I'll need to look that up.
        • Mr Bill
          • Nov 2011
          • 648
          If you get everything hooked up where it will turn on (solid led), take a flashlight and shine it directly on the screen in a very dark room and see if you can find "no signal". I usually shine the light towards the bottom of the screen and hit the volume key in the keyboard.
            The inverter is working, otherwise you will not see it cycles through the RED/BLUE/GREEN screen.
            It sounds like it's stucked in the test mode.
            • horn1991
              • Jul 2012
              • 12
              yeah...it can definitely create a picture of some sort. The main board was damaged from a small water leak. just a few drops, but enough to foul several components.
              I bought a new main board online...TSM electronics or something. Anyway, the cycling RGB occurred with the new board. But upon further inspection, I think they sent me the wrong part.
              I've since sent it back, and hope to have the correct board sometime next week. Hopefully that will get it back to working.
                With the old board, does it cycle test patterns as well? Accessing the service manual may give an option for turning off the test mode, or you can try resetting the EEPROM, a similar trick done on Samsung LCD TVs.
                • horn1991
                  • Jul 2012
                  • 12
                  no...the old board did not cycle anything. With the CN303 plugged in, the screen was dark. Unplugging CN303 on the old board would bring up the backlight, but not any color cycling.
                  • Silviyius
                    • Jun 2012
                    • 29
                    • US
                    You might be able to program the board if its the wrong one. might be a pain but you could do it. assuming you have the tools. What board is it?
                    • horn1991
                      • Jul 2012
                      • 12
                      appreciate the offer...but I already sent it back. Found the correct board somewhere else (hopefully, if they send what I ordered). Cheaper, too.
                      I am a firm believer that the simplest explanation is the solution. I have a damaged Main Board from a water. No other damage is apparent. The correct main board should heal the TV. :-)
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • Chrissygizmo
                        Sony KD-55XG9505 lines on screen problem
                        by Chrissygizmo
                        Hello again everyone,
                        This is my latest mission, to try getting this Sony tv back to normal working order…
                        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                        02-19-2025, 11:31 AM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Adam Russ
                        Black screen on Sony 65x90ch (65x900h from Costco)
                        by Adam Russ
                        Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                        09-15-2024, 05:46 PM
