Olevia LT37HVS - power prolems, caps related?
  • GLDIVER
    • 4
    Greetings.
    I have an Olevia LCD HDTV model LT37HVS. Set turns on and works for 20 to 60 minutes then makes a bit of a crackling sound and goes dead. No sound, no picture, no blue logo light on front. If unplugged for 30 seconds, then plugged back in, it again works perfect for 20 to 60 minutes and the cycle repeats itself. Since it goes completely dead as opposed to just losing sound or picture I suspect the problem lies in the power supply. During my research I've found a lot of information that bad capacitors can cause nasty problems. I'm wondering if this sounds like it could be capacitors in the power supply (Arestech AEP001-24 REV:1)? To my completely untrained brain it seem to be something very early in the power supply like a transformer since when it goes out EVERYthing goes dead.
    Thank you in advance for your time, attention and insight. It is much appreciated.
    Jeff,
  • selldoor
    Slow Learner
    • 7870
    Re: Olevia LT37HVS - power prolems, caps related?
    You need to take the back off the set and establish where the crackle comes from.
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
    • GLDIVER
      • 4
      Hello selldoor and thank you for the quick reply.
      The crackle sound comes through the speakers. I have already tore into the set and pulled the power supply so I'm too late to listen if there is an actual crackle coming from a particular area of the set. I think it's just static from whatever it is that's knocking out the power. I can take photos of the power supply which I'm pretty sure is the culprit since everything goes dead at once. I'll do that after I finish with work
      While I do not have much experience with TV's, I have worked with computers (desk tops & laptops) since the 80's. Upgrading ram, modems, replacing LCD screens - who knew they cracked so easily - and such. Basically I'm 1/2 too cheap to pay someone else to do it, and 1/2 to interested in ripping it apart and seeing what makes it tick. I have a basement full of tools though my wife keeps "cleaning up" and I can't find them most of the time. I pretty much have no fear of ripping something apart. Which is both a blessing and a curse....
      Thanks again for the reply, your time is appreciated!
      Jeff,
      • GLDIVER
        • 4
        Ok... I've attempted to photograph the power supply board. Due to it's size I did the front in 3 sections. I've looked it over quite carefully on both sides and see nothing out of the ordinary. All the caps look good, no bloating or leaking. Nothing looks to have ever been hot. I don't see any "smoking" guns, at least to my untrained eye. Since everything goes dead it seems to me it's power supply related. I suppose there could be another board causing a problem that in turn kicks out the power supply, I just don't know. I can get a new power supply for $40 or change out the caps for $15. But I just don't have any confidence that either will cure the problem.
        Small Caps are: elite brand
        Mid size Caps are: Ltec brand
        If you see anything I didn't or have any suggestions I'd love to hear them.
        Thanks for your time!
        Jeff,
        Last edited by GLDIVER; 06-24-2012, 05:23 PM. Reason: Keyboard problem I'm sure....
        • infringer
          Badcaps Member
          • Sep 2009
          • 244
          • United Frickin States
          If anything I would say 40bux is not bad at all for a power supply and in this case it sounds like it is something on your power supply being that it is going completely dead...
          But if you want to save a few bux may want to wait for further advice.
          Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
          • mockingbird
            • Dec 2008
            • 5484
            Does the logic board have solid-state or electrolytic caps?
              This power supply has PFC circuits (in the third picture), 5v standby (picture #2 top section small transformer), switched 12 or18V power supply (middle section transformer), switched 24V power supply (bottom transformer).
              So right now you are not getting any indicator lights on the front of the TV at all, if that is the case, the standby power supply may be bad or the main board is completely dead.
              Check the DC voltage at that 450Vdc DC main filter cap (this is the Line voltage primary circuits so be real careful), it should have about 170Vdc (if the AC in put is 120Vac) WITHOUT the TV ON, if it does, then check and see you do have the 5Vdc from the 5V standby power supply section.
              Just make sure NOT TO TOUCH any parts of the Primary circuits, you should have this TV plugged into GFI outlet to protect yourself.
              • GLDIVER
                • 4
                Thanks for the quick replies gentlemen.
                infringer: I agree, $40 is a cheap power supply. Most want $60 to $80 for it, but I found a site that has it for $39.95 with free 2 day shipping.
                mockingbird: I'm not sure which is the logic board, or what a solid state cap looks like, sorry.
                budm, At last use before tearing it apart the set would power up and work perfect for between 20 and 60 minutes after that it would just go dead. No sound, picture or blue logo light at front. After unplugging it for 30 seconds it would again start up perfect for a while and the cycle would repeat. Can the power supply voltages you mentioned be tested with the power supply out of the set? I know some things don't like to be plugged in when there's no draw on them.
                I'm a little curious what exactly it is that gets "reset" when unplugged for 30 seconds. Is there some type of circuit breaker in there somewhere that resets? Or is it just something cooling during that short period of time? Or is just rebooting it enough to get it to work for a short while?
                Thanks again for the help. It is much appreciated!
                Jeff,
                • mockingbird
                  • Dec 2008
                  • 5484
                  The logic board is the board with the lcd driver chip and whatnot. LCD TVs should have four boards if I'm not mistaken. PSU, Logic, Inverter (Which should be part of the screen), and tuner.
                  Since it's an Olevia, which is considered an off-brand, you should check to see if you also need to change the caps on the logic board. Can you post another pic?
                  • selldoor
                    Slow Learner
                    • 7870
                    I would try the hairdryer test. While the set is on warm firstly the power board with a hairdryer to try and get it to go off quicker. If that doesnt make ant difference try on other boards. Then if you establish a board try and narrow it down to a section.
                    • bmc763
                      • Sep 2012
                      • US
                      Jeff,
                      How did you make out with the new power supply , did it do the trick? I am having the same problem, unit has been great for 6 years and bang dead after a couple of weeks of erratic shutting off, wouldn't turn back on until I unplugged it and then it just wouldn't power up one time !
                      Where did you find the supply for $39.99 with 2 day free ship? I may need to buy one from the sounds of it !
                      • azdave35
                        • Oct 2012
                        • 12
                        • usa
                        i have the same tv and had similar problems...i replaced the caps on the power supply and it didnt help..i used a hair dryer on the main board and found the bad caps..i replaced them and it fixed the problem....before you replace the power supply check the caps on the main board
                        • bmc763
                          • Sep 2012
                          • US
                          Replaced the power supply for about $45 and TV is brand new..
                          • Taterbug
                            • Dec 2013
                            • 114
                            Which caps were replaced on the main board?
                            • selldoor
                              Slow Learner
                              • 7870
                              Man, this is some old thread! Post pictures of your boards and also try the hairdryer trick.
                              • pkslowk
                                Debug Card Error Code and Solution
                                by pkslowk
                                Sr. Motherboard Debug Error Code Solution
                                1 Intel 845 E9 Bios Related Problem
                                2 Intel 845 D4 CPU Socket Related problem
                                3 Intel 845 37 Bios Related Problem
                                4 Intel 845 7C Bios Related Problem
                                5 Intel 945GCPE 34 Bios Related Problem
                                6 Gigabyte 845 2 Ram Related Problem
                                7 IBM Server A6 A7 Ram Mismatch Problem
                                8 Asus 845 29 CPU Related Problem
                                9 Lenovo I946 97 C-Mos Jumper related
                                10 Gigabyte 845 A0 CPU Related Problem
                                11 Asrock G31M-VS D7 Bios Related Problem
                                12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                                01-28-2021, 12:51 PM
                              • Stephen
                                MacBook Pro 14" M1 Pro Battery related question.
                                by Stephen
                                Board was just repaired, great thing for us since the DATA was recovered, however the battery was just replaced with a brand new OEM battery and holds the charge well, I plug it in and the charge icon comes on (lightning bolt) then it goes off and comes back again and repeats itself, The MagSafe 3 Amber light is turning off and on constantly, which is telling me something else is going on, before I pull this board out again I was wondering if anyone has come across this issue since its a little new to me on this model. Battery is holding the charge well at 52% but it won't charge further, I checked...
                                02-12-2025, 04:41 PM
                              • spleenharvester
                                Weirdly specific reboots on a TrigKey S5 that seem to be power supply related.
                                by spleenharvester
                                I have two of these mini PCs: TrigKey S5 with Ryzen 5700U, 32GB RAM, 1TB NVMe SSD, Win11 Pro. They work very well for most uses. They are powered by a HuntKey 19V 4.74A brick with a standard DC5525 tip, which feels decently heavy.
                                When the brick is connected to the system through a 1 meter DC female-male extension cord (18AWG so decently thick), the system will black screen and reboot when multiple objects are sliced simultaneously in PrusaSlicer. One object is OK. Literally any other activity on the PC is OK. It is just this one specific thing that causes a reboot. I tried running...
                                09-15-2025, 08:43 AM
                              • badboyzzz
                                A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                                by badboyzzz
                                I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                                12-28-2024, 02:11 PM
                              • Sephir0th
                                HP ZBook 15v G5 - Weird behaviour/issue related to USB-C/TBT
                                by Sephir0th
                                Hello community,
                                This will be the device of your nightmares. I can't count how many hours I spend to fix it, but it was already way to much...
                                However, I really hope for some insight from experience because I have this nice HP ZBook 15v G5 here which came in completely dead, even +VREG3 not working although it wasn't shorted. Previous repair attempt by a somehow professional repair shop, since I noticed action around the controller responsible for +3VALW and +VREG3 without it making worse. Way later I noticed the PCH was replaced and even later I realized +3VALW...
                                10-05-2022, 04:09 PM
