Debug Card Error Code and Solution
  • pkslowk
    • Feb 2020
    • 13
    • India
    Sr. Motherboard Debug Error Code Solution
    1 Intel 845 E9 Bios Related Problem
    2 Intel 845 D4 CPU Socket Related problem
    3 Intel 845 37 Bios Related Problem
    4 Intel 845 7C Bios Related Problem
    5 Intel 945GCPE 34 Bios Related Problem
    6 Gigabyte 845 2 Ram Related Problem
    7 IBM Server A6 A7 Ram Mismatch Problem
    8 Asus 845 29 CPU Related Problem
    9 Lenovo I946 97 C-Mos Jumper related
    10 Gigabyte 845 A0 CPU Related Problem
    11 Asrock G31M-VS D7 Bios Related Problem
    12 Compaq 845 BD-70G B0 CPU Socket Related problem
    13 Compaq 845 BD-70G 8 CPU Socket Related problem
    14 Compaq 845 BD-70G A0 CPU Socket Related problem
    15 Intel 945GCPE 25 Ram Related Problem
    16 MSI 915 MS-7131 AF Ram Related Problem
    17 MSI 915 MS-7131 10 Ram Related Problem
    18 MSI 915 MS-7131 2 Ram Related Problem
    19 945GM-RH C3 North Bridge Related Problem
    20 945GM-RH C5 North Bridge Related Problem
    21 945GM-RH 3D North Bridge Related Problem
    22 945GM-RH 44 North Bridge Related Problem
    23 945GM-RH 45 North Bridge Related Problem
    24 ECS G31T-M7 E1 Ram Pin No 239 or 240 Related
    Problem
    25 Foxconn G31MX-46GMX E0 North Bridge or Ram Related
    Problem
    26 Foxconn G31MX-46GMX 81 North Bridge or Ram Related
    Problem
    27 Foxconn 915G7MH 1C North Bridge or Ram Related
    Problem
    28 Foxconn 915G7MH 25 North Bridge or Ram Related
    Problem
    29 Foxconn 915G7MH AF Ram Related Problem
    30 Foxconn 915G7MH 1 Ram Related Problem
    31 G31MXP C3 Bios Related Problem
    32 Compaq 845 5 CPU Socket Related problem
    33 MSI 7142 25 South Bridge VIA 8237 Related or
    Near Resistance Check
    34 Zebronics UG41 D2 then press reset button
    when coming ram beep South Bridge Related
    35 Asus P5GV-TMX/S C3 Ram Related Problem
    36 Intel 915GAG D4 CPU Socket Related problem
    37 Intel 915GAG D5 CPU Socket Related problem
    38 MSI MS-7101 AF Ram Related Problem
    39 Asus P5KPL-VM 39 CPU Supporting Problem
    40 Gigabyte 845GVM-RZ Data Line immediately in or
    out CPU Socket Related problem
    41 Mercury 845 D4 Ram or Ram Supply Related
    Problem
    42 IBM Thinkcentre A51 DDR2 6B Bios Related Problem
    43 Intel 845 GVSR 3 IO Related Problem
    44 Lenovo I946 Booting Time Hang CPU Socket Related problem
    45 Lenovo I946 2C Ram Related Problem
    46 Lenovo I946 38 Ram Related Problem
    47 Intel 915GAV 0D IO Related Problem
    48 845GVML B0 Ram Related Problem
    49 Gigabyte 915ME-RH 41 and Beep Bios Related Problem
    50 HCL IPM41-D3 D5 North Bridge Related Problem
    51 HCL IPM41-D3 D6 North Bridge Related Problem
    52 HCL IPM41-D3 C7 North Bridge Related Problem
    53 HCL IPM41-D3 E9 North Bridge Related Problem
    54 HCL IPM41-D3 3 North Bridge Related Problem
    55 HP TQ965MK 39 Bios Related Problem
    56 Mercury P4VM800M7 D2 CPU Socket Related problem
    57 Mercury 845GL NDSMX 91 CPU Related Problem
    58 Gigabyte GA-8IRML A7 and continuous beep Near Ram Slot Resistance Related Problem
    59 IBM BORA-RH 25 CPU Socket Related problem
    60 Gigabyte GA-8S661FXM- 775 25 CPU Socket Related problem
    61 HP DC5000 865 Chipset 47 North Bridge Related Problem
    62 Asrock P4I45GV One Time 90 and second time AD
    63 ECS G31T-M2 D4 Ram Related Problem
    64 ECS G31T-M2 C0 Ram Related Problem
    65 Dell Vostro 230 MIG41R 5 Beep C-Mos related Problem
    66 HP 7800 3 Beep 5 Times CPU Related Problem
    67 HP 7800 4 Beep 5 Times CPU Core Related Problem
    68 Gigabyte 845 0C Ram Related Problem
    69 Gigabyte 845 B0 Ram Related Problem
    70 IBM 845 One Time 90 and second
    time AD Near Ram Slot Resistance Related Problem
    71 Intel 965GVHZ D0 CPU Related Problem
    72 Intel 965GVHZ D1 CPU Related Problem
    73 Intel 965GVHZ D2 CPU Related Problem
    74 Intel 965GVHZ D5 CPU Related Problem
    75 Asus P5KPL-VM/S Some Time
    13,55,30,98,D0,C2 Near South Bridge Capacitor Repeated
    76 Intel 865 45 CPU Socket Related problem
    77 Intel 865 47 CPU Socket Related problem
    78 IBM 845 49 with 1-1-3-3 Beep CPU Socket Related problem
    79 Asus Axper 845 25 Ram Related Problem
    80 Compaq MS-6541 E7,47 Near Ram Slot Resistance Related Problem
    81 Lenovo L-IG41M D0 CPU Related Problem
    82 MSI MS-7336 HP 29 CPU Related Problem
    83 MSI MS-7336 HP B6 CPU Related Problem
    84 Gigabyte 845GV 60 Check Ram Slot Pin No.180 2.5V
    85 M2A693-Plus-VP AMD AM2 14 Ram Related Problem
    86 Foxconn G31 60 or 68 Clock Replated
    87 Atom D410PT 15 Bios Related Problem
    88 Atom D410PT 49 Ram Related Problem
    89 Atom 945GCFL 25 Bios Related Problem
    90 IBM BARBADOS 915 E9 CPU Socket Related problem
    91 ASUS P5LD2-VM/S D1 error and smbclk or
    smbdata ok no ram beep South Bridge Related
    92 Gigabyte 945GZM-S2 38 North Bridge or Ram Related
    Problem
    93 Gigabyte 945GZM-S2 39 North Bridge or Ram Related
    Problem
    94 Intel DG41CN 45 Bios Related Problem
    95 Atom Intel D2500HN 50 Bios Related Problem
    96 Atom Intel D2500HN 33 Jumper Related
    97 IBM 775 Socket DDR2 16 CPU Socket Related problem
    98 IBM 775 Socket DDR2 18 CPU Socket Related problem
    99 IBM 775 Socket DDR2 DA CPU Socket Related problem
    100 HP 6200 SP#615114-001 45 Ram Related Problem
    101 Asrock 775I65GV D5 Ram Related Problem
    102 Asrock 775I65GV FE Ram Related Problem
    103 Lenovo L-IG31A E0 Ram Related Problem
    104 P4P800-VMS A4 Ram Related Problem
    105 IBM 915 2C CPU Socket Related problem
    106 IBM 915 E2 CPU Socket Related problem107 IBM 915 38 CPU Socket Related problem
    108 IBM 915 C6 CPU Socket Related problem
    109 Intel 945PLM 25 Bios Related Problem
    110 HP TG33MK E0 Ram Supported Problem
    111 HP TG33MK 26 CPU Related Problem
    112 945GCT-HM 39 Ram Related Problem
    113 IBM 775 Socket DDR2 8 Bios Related Problem
    114 DP DC5750 7 Ram Related Problem
    115 Lenovo IH61M 2 Short Beep Clear C-mos Jumper
    116 Intel DG31GL 60 Clear C-mos Jumper
    117 G31T-M5 D1 or Beep Clear C-mos Jumper
    118 G31T-M5 E0 Ram Related Problem
    119 Lenovo I946 8 Bios Related Problem
    120 Intel DG31PR 60 Bios Related Problem
    121 Zotac G31 60 CPU Socket Related problem
    122 Zotac G31 41 or continuous beep Bios Related Problem
    123 IBM 845 49 or Beep CPU Related Problem
    124 Compaq BD-70G B0 Near Ram Slot Resistance Related
    Problem
    125 Foxconn A76ML-K C7 Ram Related Problem
    126 Foxconn A76ML-K D0 No Beep Bios Related Problem
    127 HP PTGD1-LA E5 Ram Related Problem
    128 HP P5LP-LE 25 South Bridge Related
    129 Simmtronics G41D D0 Bios Related Problem
    130 Asus P5GZ-MX 2A CPU Socket Related problem
    131 Mercury 945GCM 39 Ram Related Problem
    132 Mercury 945GCM 45 Ram Related Problem
    133 Intel DG31PR 6 Bios Related Problem134 HP DX7400 29 CPU Related Problem
    135 Lenovo IH61M Ver4.2 Keyboard Hang or display
    Beep ok but no display Bios Related Problem
    136 Asus P4BP-MX B0 Near Ram Slot Resistance Related
    Problem
    137 Asus P4BP-MX 26 CPU Related Problem
    138 Asus P5GD2-TVMS 18 Lan IC
    139 945GCM3 45 North Bridge Related Problem
    140 945GCM3 39 North Bridge Related Problem
    141 945GCM3 C3 North Bridge Related Problem
    142 MSI MS-7133 EA Ram Related Problem
    143 MSI MS-7133 D4 Ram Related Problem
    144 HP 865 47 or 5 Beep CPU Socket Related problem
    145 Intel DG31PR 10 Bios Related Problem
    146 Asus P5GD1-TMLS EA Ram Related Problem
    147 HP 8300 Some time display ok and
    some time 32 error Bios Related Problem
    148 Gigabyte 945GCM-S2L 50 Bios Related Problem
    149 Foxconn G41 D1 Clock IC Related
    150 Acer B75H2-AM 55 Ram Related Problem
    151 Lenovo L-IG41M2 9B Bios Related Problem
    152 Acer B75H2-AM 4F with 6 Beep + D0 Bios Related Problem
    153 HP 945GM-RH 25 Lan or South Bridge Related
    Problem
    154 Lenovo IS7Xm rev 1.0 60 or Display Hang Bios Related Problem
    155 Intel DQ67OW 2E Ram Related Problem
    156 Intel DQ67OW E4 then off CPU Core Related Problem
    157 HP TG33MK C5 with Ram beep and 41
    with 9 Beep Bios Related Problem
    158 Gigabyte GA-H55M-S2V
    rev1.4 11 Main Bios Problem
    159 HP 400 G1 HECI Error During Bios Related Problem
    160 Dell Optiplex 9010 04 No Beep Both Bios reprogram161 Dell Optiplex 9010 one time display ok second
    time on off on off Both Bios reprogram
    162 HP TQ965MK 26 CPU Related Problem
    163 HP TQ965MK C1 CPU or North Bridge Related
    164 HP TQ965MK 66 CPU Related Problem
  • zipu
    • Apr 2023
    • Bangladesh
    Re: Debug Card Error Code and Solution
    acer g41 motheboard 0000 code problem solution
    • badboyzzz
      A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
      by badboyzzz
      I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
      12-28-2024, 02:11 PM
    • insomniacno1
      Thinkpad L540, won't turn on unless I switch ram
      by insomniacno1
      This is a very weird problem and super annoying, so if someone who has experience with this, can explain why this is happening, then I will be grateful😁
      This happen usually when the laptop has been moved. from one room to another OFF charger for some hours, but has also happened when laptop has been shut down and left ON charger over night, and not moved :
      I turn on the laptop normally by pressing the power button briefly, then power comes on and Power LED and Fn LED turn ON/OFF constantly (no post and no beep codes)
      If I(and this is my only option at this point),...
      09-29-2025, 05:58 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • Ross Kohler
      Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
      by Ross Kohler
      I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
      - There's no sign of any attempt to power on when pushing the power button.
      - No PSON signal is reaching the 24-pin ATX connector.
      - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
      - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
      - If I pull the Super IO S_SLPS#_R pin...
      04-16-2024, 09:36 AM
    • lazaro.089
      Asus Zephyrus M16 / GU603ZW problem
      by lazaro.089
      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
      CPU: Core i9-12900H
      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
      08-26-2025, 06:33 PM
