Sharp Aquos LC-32D40U - no image
--- begin sig file ---
--- end sig file --- -
Re: Sharp Aquos LC-32D40U - no image
ahickman,
Try doing this to put the television into service mode
1) Unplug the television for a few minutes to let the capacitors drain
2)hold down the volume - and the Input at the same time
3) Plug the television in
your television should turn on and display a "K" on the screen. if this works then you most likely have a failing inverter
The television sometimes will remain working until you unplug the television
This puts the television into service mode and, will allow you to test and monitor voltages to determine the actual problem
Electronic surplusThis Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
Help keep these from the landfillsComment
I went ahead and orderd a replacement T-con from ShopJimmy. Plugged it up and all is good. Took the time to re-measure the voltages Momaka was interested in on the new card:
Vcc = 4.92v
VGL = -6.31 v
SDRAM_VDD = 2.96 v
VLS = 14.69 v
3V = 2.99 v
SSC_VDD = 2.96
D_VDD = 2.95Comment
What about U300, pin 13, the one that was 5% out?--- begin sig file ---
--- end sig file ---Comment
Yes, now that we know that the old t-con was bad, it would indeed be interesting to troubleshoot the old t-con.
Unfortunately, this t-con is very different from others I have seen, so I have a hard time telling what U300 does. Normally, a chip like that is used to generate VDD, VGL, and VGH on other t-cons (those 3 voltages are standard, although other t-cons may give them different names such as AVDD, VEE, and VGE or VDD, VOFF, and VON). Perhaps that chip is used to generate the other voltages as well - if that's the case, then replacing U300 may solve the problem. Before doing that, though, I would say check every ceramic capacitor in the power section of the t-con for short circuit. That would be everything in the upper-right corner above the "Etrontech" RAM chips in this picture:
https://www.badcaps.net/forum/attach...4&d=1341582445
If any of those capacitors read less than 50 Ohms, let me know which.
Also, if you see any bumps, holes, or other irregularities on top of any of the MOSFETs, they are likely bad. Your pictures are excellent, but such irregularities are hard to notice even with very very high quality images.
Sorry for the late reply.Last edited by momaka; 07-14-2012, 06:44 PM.Comment
Thank you diodo49 your suggestion it worked perfectly for the (NO PICTURE HAS SOUND
) I could see on the casing and the inverter board were the connection was bad buy the black spots although this did solve the no video issue I did not reuse any the original screws I seen where they had already had blue locktite on them (either from the original installer or from a previous repair)and only the three that you mention were actually lose (they are to the inside) I used some used screws that had small washers and lock washers already on them (they are made this way so that the washers and lock washers do not fall off the screws) so hopefully this issue should not return (I also used a file on the case side as to try and make the raised surface have more contact to the inverter board and some emery cloth on the inverter side) I had researched this issue before and seen another post on Google were someone had said a tech from best buy fixed this issue (no video) in a small amount of time but without your post I would not have known were to look thanks for your post
on another post in this same section ahickman has posted a inverter board mine looks similar but the copper area that diodo49 refers to and on mine is on the underside of the inverter board not the topLast edited by Nascar; 05-26-2015, 01:29 AM.Comment
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by rimwallThis TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or... -
Hi everyone. [Sorry for the long, detailed post in advance].
I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard.... -
by jason123Hi there,
My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
It does this even with the monitor not connected to a computer / graphics card....-
by jason123Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
- Loading...
