Sharp Aquos LC-32D40U - no image
--- begin sig file ---
--- end sig file --- -
Re: Sharp Aquos LC-32D40U - no image
ahickman,
Try doing this to put the television into service mode
1) Unplug the television for a few minutes to let the capacitors drain
2)hold down the volume - and the Input at the same time
3) Plug the television in
your television should turn on and display a "K" on the screen. if this works then you most likely have a failing inverter
The television sometimes will remain working until you unplug the television
This puts the television into service mode and, will allow you to test and monitor voltages to determine the actual problem
Electronic surplusThis Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
Help keep these from the landfillsComment
Vcc = 4.92v
VGL = -6.31 v
SDRAM_VDD = 2.96 v
VLS = 14.69 v
3V = 2.99 v
SSC_VDD = 2.96
D_VDD = 2.95Comment
What about U300, pin 13, the one that was 5% out?--- begin sig file ---
--- end sig file ---Comment
Yes, now that we know that the old t-con was bad, it would indeed be interesting to troubleshoot the old t-con.
Unfortunately, this t-con is very different from others I have seen, so I have a hard time telling what U300 does. Normally, a chip like that is used to generate VDD, VGL, and VGH on other t-cons (those 3 voltages are standard, although other t-cons may give them different names such as AVDD, VEE, and VGE or VDD, VOFF, and VON). Perhaps that chip is used to generate the other voltages as well - if that's the case, then replacing U300 may solve the problem. Before doing that, though, I would say check every ceramic capacitor in the power section of the t-con for short circuit. That would be everything in the upper-right corner above the "Etrontech" RAM chips in this picture:
https://www.badcaps.net/forum/attach...4&d=1341582445
If any of those capacitors read less than 50 Ohms, let me know which.
Also, if you see any bumps, holes, or other irregularities on top of any of the MOSFETs, they are likely bad. Your pictures are excellent, but such irregularities are hard to notice even with very very high quality images.
Sorry for the late reply.Last edited by momaka; 07-14-2012, 06:44 PM.Comment
Thank you diodo49 your suggestion it worked perfectly for the (NO PICTURE HAS SOUND
) I could see on the casing and the inverter board were the connection was bad buy the black spots although this did solve the no video issue I did not reuse any the original screws I seen where they had already had blue locktite on them (either from the original installer or from a previous repair)and only the three that you mention were actually lose (they are to the inside) I used some used screws that had small washers and lock washers already on them (they are made this way so that the washers and lock washers do not fall off the screws) so hopefully this issue should not return (I also used a file on the case side as to try and make the raised surface have more contact to the inverter board and some emery cloth on the inverter side) I had researched this issue before and seen another post on Google were someone had said a tech from best buy fixed this issue (no video) in a small amount of time but without your post I would not have known were to look thanks for your post
on another post in this same section ahickman has posted a inverter board mine looks similar but the copper area that diodo49 refers to and on mine is on the underside of the inverter board not the topLast edited by Nascar; 05-26-2015, 01:29 AM.Comment
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
by klassicHi community,
I will describe my problem with a TV in those short following terms to be the most precise :
What i have :
Sharp Aquos LC-60LE635E
power board DPS-162KP-1
main logic board QPWBXF733WJN2
symptoms :
white led light logo at startup,
after 2 minutes, blinking 3 times a row, repeating
no backlight (and apparently no picture, checked panel with flashlight)
no startup sound
powerboard investigations :
1-2 PNL : 0v
3-4 GND
5-6-7-8 UR : 13.15v
9-10-11-12... -
This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...09-06-2024, 10:56 AM
This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 10:56 AM
- Loading...
