Sharp Aquos LC-32D40U - no image
  • retiredcaps
    • Apr 2010
    • 9271
    #61
    Re: Sharp Aquos LC-32D40U - no image
    Originally posted by ahickman
    Pins 1, 2 and 3 are shorted to ground, but pins 4 and 5 are not. According to the datasheet you linked to, 4 and 5 should be GND?
    3 other datasheets from 3 different companies for 4422 all have the same pinouts.
    --- begin sig file ---
    --- end sig file ---
    • electronicsurplus
      • 210
      ahickman,
      Try doing this to put the television into service mode
      1) Unplug the television for a few minutes to let the capacitors drain
      2)hold down the volume - and the Input at the same time
      3) Plug the television in
      your television should turn on and display a "K" on the screen. if this works then you most likely have a failing inverter
      The television sometimes will remain working until you unplug the television
      This puts the television into service mode and, will allow you to test and monitor voltages to determine the actual problem
      Electronic surplus
      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
      Help keep these from the landfills
      • ahickman
        • Jan 2012
        • 233
        No "K" on screen. Tried input + vol(-) and vol(+).
        • ahickman
          • Jan 2012
          • 233
          Originally posted by momaka
          There's a few test points on the t-con that you should check the voltage on:
          VCC+5V, VDD, VGL, VGH, SDRAM_VDD, VLS, 3V, SSC_VDD, D-VDD, and S_VDD(?)
          Check with respect to ground. Let me know what voltages you get.
          I went ahead and orderd a replacement T-con from ShopJimmy. Plugged it up and all is good. Took the time to re-measure the voltages Momaka was interested in on the new card:
          Vcc = 4.92v
          VGL = -6.31 v
          SDRAM_VDD = 2.96 v
          VLS = 14.69 v
          3V = 2.99 v
          SSC_VDD = 2.96
          D_VDD = 2.95
          • retiredcaps
            • Apr 2010
            • 9271
            #65
            What about U300, pin 13, the one that was 5% out?
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #66
              Yes, now that we know that the old t-con was bad, it would indeed be interesting to troubleshoot the old t-con.
              Unfortunately, this t-con is very different from others I have seen, so I have a hard time telling what U300 does. Normally, a chip like that is used to generate VDD, VGL, and VGH on other t-cons (those 3 voltages are standard, although other t-cons may give them different names such as AVDD, VEE, and VGE or VDD, VOFF, and VON). Perhaps that chip is used to generate the other voltages as well - if that's the case, then replacing U300 may solve the problem. Before doing that, though, I would say check every ceramic capacitor in the power section of the t-con for short circuit. That would be everything in the upper-right corner above the "Etrontech" RAM chips in this picture:
              https://www.badcaps.net/forum/attach...4&d=1341582445
              If any of those capacitors read less than 50 Ohms, let me know which.
              Also, if you see any bumps, holes, or other irregularities on top of any of the MOSFETs, they are likely bad. Your pictures are excellent, but such irregularities are hard to notice even with very very high quality images.
              Sorry for the late reply.
              • diodo49
                • Dec 2012
                • 17
                Well to whom may still interested to fix this issue.
                NO PICTURE HAS SOUND
                CLEAN THE 3 RECTANGULAR COPPER CORNERS OF THE INVERTER.
                AND USE LOCKTITE WHEN INSTALL THE SCREWS.
                THESE SCREWS CAME LOOSE WITH THE TIME.
                • Nascar
                  • Sep 2010
                  • 10
                  #68
                  Thank you diodo49 your suggestion it worked perfectly for the (NO PICTURE HAS SOUND
                  ) I could see on the casing and the inverter board were the connection was bad buy the black spots although this did solve the no video issue I did not reuse any the original screws I seen where they had already had blue locktite on them (either from the original installer or from a previous repair)and only the three that you mention were actually lose (they are to the inside) I used some used screws that had small washers and lock washers already on them (they are made this way so that the washers and lock washers do not fall off the screws) so hopefully this issue should not return (I also used a file on the case side as to try and make the raised surface have more contact to the inverter board and some emery cloth on the inverter side) I had researched this issue before and seen another post on Google were someone had said a tech from best buy fixed this issue (no video) in a small amount of time but without your post I would not have known were to look thanks for your post
                  on another post in this same section ahickman has posted a inverter board mine looks similar but the copper area that diodo49 refers to and on mine is on the underside of the inverter board not the top
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • moltensolderlabs
                    Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
                    by moltensolderlabs
                    Hi everyone. [Sorry for the long, detailed post in advance].
                    I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
                    10-09-2020, 12:01 PM
                  • jason123
                    Hisense 65R6E3 double-image / horizontal strips - TCON?
                    by jason123
                    Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                    07-19-2025, 08:07 AM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
