Sharp Aquos
  • lapisto
    • 13
    Sharp Aquos
    I have a SHARP AQUOS TV, Model Number: LC-37D62U, which I purchased a few years ago. It is now no longer turning on.
    It clicks on, but then goes into a pattern of : (x=off) (0=on)
    ----(0) 2x---------(x)------------(0) 2x----
    (Power) (Sleep) (OPC)
    Over and over, I have researched this problem but for nearly all others the power led powers on again, since this is not the case for me, do you think I can fix it without having to get a new power or main (or other) board?
    I have searched and tried all the things I can do without opening it up and none worked. Called SHARP (and their affiliated repair shop) and they told me the pattern I have described requires service so basically it can't be fixed without opening it up, and they say it will probably cost a few hundred bucks.
    I couldn't find anything online about being able to repair it myself, I have never fixed a tv (hardware wise) before but I have done a few pcs, laptops and 2 ps3. Do you guys think I can do this? Or a TV is a whole different type of thing to try and fix yourself?
    Thank You.
  • randtek
    • Oct 2011
    • 280
    • US
    Re: Sharp Aquos
    I am not clear on your description of the error code being displayed. To make it simple, just count the blinks for each LED individually, ignoring the others. Each one represents a number. For example, 2 blinks (on) then a pause (LED OFF). So, just tell us the number of blinks for each LED.
    If it is POWER LED 2, OPC LED 5, that would represent a Panel 5 volt failure.
    Yes, I think you can probably fix the TV.
    • selldoor
      Slow Learner
      • 7870
      Re: Sharp Aquos
      Well here is a good start - found a service manual for you.
      Flash codes page 40
      http://www.scribd.com/kiotosong/d/72452455-LCSPMPWBCGDT
      Hours of reading as you cant watch tv
      • lapisto
        • 13
        Re: Sharp Aquos
        The problem is when I plug it in, I get the POWER and the OPC lights flash twice and then nothing, and then the same thing keeps on happening. If I try to power the tv on, it clicks on then goes off with another click. (BTW I don't know what I did but by general cleaning of the insides I managed to get the time between the two clicks to be longer, that lasted for 5 min however. It might be just the cool weather that hit it lol.)
        lol, I'll read through the manual thx.
        • lapisto
          • 13
          Re: Sharp Aquos
          BTW I got the TV to turn on by holding CH DOWN and VOL UP but nothing came on however I didn't even get a backlight coming on so its not a bad thing. ? The TV will just do that regardless ? Because I read that if the backlight came on and there was no picture or sound then it would not be repairable?
          • selldoor
            Slow Learner
            • 7870
            Re: Sharp Aquos
            Not sure what you mean by " got the tv to turn on"? do you mean you had sound? what did the leds do?
            What would be useful is if you can connect up a continous known source like a dvd and then "get the tv to turn on" report if the sound is ok and if you can see a very dark picture on the screen perhaps lookng very close up and using a flashlight. Can you adjust the volume in that state or change channels?
            • lapisto
              • 13
              Re: Sharp Aquos
              sorry what I mean is I got the power LED to go on and stay on, instead of just clicking and going back into the power and opc flashing twice pattern. But no I got nothing other then the power LED going on and staying on, no light, and not able to use any input, connection, or even see any menus or turn volume up or down.
                Re: Sharp Aquos
                So right now you are no longer getting flashing error codes?
                http://elektrotanya.com/?q=showresul...ia=tv&kat2=all
                • lapisto
                  • 13
                  Re: Sharp Aquos
                  I still am, I was just saying that if I were to hold the CH DOWN and VOL UP then press the Power button I would get a steady power LED on instead of the flashes, but it would be pointless because everything is the same and I couldn't even turn off the tv without unplugging it.
                    Re: Sharp Aquos
                    OK. I just download the service manual, need to do some studying first.
                    • lapisto
                      • 13
                      Re: Sharp Aquos
                      I have taken pictures of all the boards, nothing appears to be wrong with any of them from a visual point of view lol...(only the little thermal compound things that I have to put back.)
                      Here is the address so maybe you guys could take a look and maybe you might see something:
                      http://*************/f/814/024xb.jpg/
                        Re: Sharp Aquos
                        There looks to be two relays on the board - one bottom left and one top right - which one of these clicks?
                        Do you have a digital multimeter?
                        • lapisto
                          • 13
                          Re: Sharp Aquos
                          Its the one on the top right (near where the power cable goes in), I have a digital multimeter... but its been a few years since I used it
                          I did everything I can do, without doing anymore damage then I have already done, I really don't have any other ideas. I put the boards and everything back on and at least nothing is worse off then before lol.
                            Re: Sharp Aquos
                            Are there any labels near the connector which goes from the power supply to the main board?
                            • lapisto
                              • 13
                              Re: Sharp Aquos
                              there are two connectors on the power board, going to the main board.
                              1. PD CN5702
                              2. PH CN5701
                                Re: Sharp Aquos
                                But no labels indicating what the function of each pin is?
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Re: Sharp Aquos
                                  Tom- not sure what you want to know - I have pieced together a block diagram
                                  from the SM the leads go the Broadcom Tuner/Source.
                                    Re: Sharp Aquos
                                    Twice power and twice OPC indicates 3.3V power failure.
                                    I would suggest checking all the LDO regulators on the board - if you need help with locating these post back with a picture of your main board (HDMI, tuner etc on it.)
                                    • lapisto
                                      • 13
                                      Re: Sharp Aquos
                                      There are no labels. I put 6 pics in that link, I don't know if its working but you should be able to click onto the next picture.
                                      http://*************/f/17/029ooe.jpg/
                                      http://*************/f/411/028fcn.jpg/
                                      http://*************/f/138/027boy.jpg/
                                      (the only regulators I can ID are on the power board lol.)
                                        Re: Sharp Aquos
                                        Is there anything on the backside of the board?
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40ā€ 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
                                        • foxyUK
                                          Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                          by foxyUK
                                          Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                          The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                          There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                          10-22-2024, 10:27 AM
