Vizio E321VL
Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most." -
Re: Vizio E321VL
You mean this post?
https://www.badcaps.net/forum/showth...490#post244490
You may be in the same boat.Never stop learning
Re: Vizio E321VL
You mean this post?
By the way I read your article and it is pretty much what I had gathered from reading all the post's on this problem. You did a good job explaining the process that goes on inside these LCD TV's.Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."Comment
Re: Vizio E321VL
I add the comment on that post about putting details instruction on how to do it, it looks like it is going to be common problem with these newer VIZIO.
I wonder if the IC is bad and it just need to be reprogrammed, and it looks like they are keeping secret on how to actually doing the programming and where to get the firmware from.
If I know how I would have put out free instruction in details, it will help out a lot of people here.Never stop learning
Re: Vizio E321VL
If I know how I would have put out free instruction in details, it will help out a lot of people here.Have you ever stopped to think and then forget to start thinking again?
aLast edited by killian6pk; 06-13-2012, 02:43 PM.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
If anyone has the hex file, I'm quite willing to program some EEPROMs (SMD or DIP) for the cost of the chip and postage. I have my own home made EEPROM programmer here based on a PICkit 2.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: Vizio E321VL
http://www.ehow.com/how_8535412_upgr...elevision.htmlHave you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
New here just poking around the forums and read this thread and was checking out the pics posted. Might have already been mentioned and addressed or dismissed, but I noticed something that looks a bit suspicious to me and thought I'd point it out just in case. The foil trace at one end of what looks to be C613 seems kindof odd to me (see pic).Comment
Re: Vizio E321VL
Yes Jeetyet I agree - I have asked for traces to be checked several times there appear to be lots of problem areas and have been assured they are ok. OP has not provided any better pics so I have given up on this thread.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Re: Vizio E321VL
I do appreciate all the help. So don't give up on me yet.Last edited by killian6pk; 06-16-2012, 01:02 PM.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
Re: Vizio E321VL
So the new chip is programmed?Never stop learning
Re: Vizio E321VL
Well, I ran out of suggestions.Never stop learning
Re: Vizio E321VL
May be Miguel can chime in to see if he runs into this problem.Never stop learning
Re: Vizio E321VL
He has offered to let me ship my Power and Main Board to him and he will go through them and give me a price to repair them. I am contemplating this. My only problem is this is a free tv and I am not sure I want to spend a couple hundred bucks to fix it. I may poke around for the next few days and see if anything else turns up on the boards, before I consider sending the boards to him.Have you ever stopped to think and then forget to start thinking again?
Re: Vizio E321VL
Make sure the chip polarity is correct. There is a small recessed dot on the corner of the chip. It should correspond to the dot showing on the circuit board drawing where the chip is installed. Also be careful of static charges when handling the chip.
Re: Vizio E321VL
Thanks to JHOFFMAN, here is the BIN file for Vizio E371E. I suspect it will be the same for the E321VL version.
http://www.tgohome.com/ServiceManual...20BIN%20files/
Given its 8MB size, it is likely a FLASH chip, not an EEPROM. I am not sure if I can program these, I will need to check.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
