Samsung PN58C7000 wont power up
    Re: Samsung PN58C7000 wont power up
    That does seem very suspicious. It looks too low. It could be a problem with the main board. Is the +5.4V output on the connector doing anything?
    • noahc72
      • May 2012
      • 63
      Ok my mistake. Had the meter on ac. Bear with me, I haven't done much work with one.
      Ps on is 17.4 then drops to around 2.5 when it clicks then goes right back up to 17.5. Similar with the 5.4v.
        17.5V??? Is the battery good in your meter? Can you test an AA battery.
        But for now assuming "17.5V" means a logic high signal, this means the main board is telling the power supply to turn off. So it is probably a problem with the main board.
        • noahc72
          • May 2012
          • 63
          1.6v on a new AA battery
          • noahc72
            • May 2012
            • 63
            Any other tests I can do on the main board before I order one?
              17.5V is definitely wrong then. And your meter seems good. I can't figure out how the PSU would output 17.5V on the 5.4V output without blowing something up on the main board - are you definitely measuring the right pin? I know some Samsung TVs have 16-20V outputs for the audio amplifiers.
              • selldoor
                Slow Learner
                • 7870
                #27
                Hi - can you post a pic of the two connectors legends.
                One end looks like it says 1.8V but is it 18V in which case 17.5 is close.
                Also here is a samsung plasma training manual - not for your set but some of the tests might be valid. Unplug
                both sustain boards -tried that?
                http://dl.dropbox.com/u/35219914/SAM...G%20MANUAL.zip
                • noahc72
                  • May 2012
                  • 63
                  yeah, i just noticed it says 18v right on there
                  • noahc72
                    • May 2012
                    • 63
                    I did try unplugging the x and y boards earlier.
                    Is that not the main board in the lower right?
                    • noahc72
                      • May 2012
                      • 63
                      In that training manual troubleshooting page is AV the main board?
                        The main board is the board with the inputs on it and the multiple heatsinked processors.
                        I think you are checking 18V pin, not PSON - it might be on a different row (awkward if so) - maybe try using a small wire and poking it in the pin connector and checking with a meter using that wire?
                        • noahc72
                          • May 2012
                          • 63
                          Ok, I am dumb. Ps on is at 0.12 then goes to 3.24 right after the click then back to 0.12. Pin right under it is at 5.25 and stays there.
                          • noahc72
                            • May 2012
                            • 63
                            All of the 5.3 pins are at 5.25 and go to zero after the click then back to 5.25
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              Yes damn-it its a doublerow socket thats why he got 17.5 for pson and 5V.
                              I think a wire stuck in is the only way
                              EDIT
                              Re next post - yes I saw as soon as I pressed post - I was just annoyed with myself as I didnt spot the 18v earlier
                              • noahc72
                                • May 2012
                                • 63
                                No I was checking the wrong one. Got the right one, see above
                                • noahc72
                                  • May 2012
                                  • 63
                                  Ps on voltage is supposed to stay up right? Its not, so is it the power supply or main board that is the problem?
                                    Yes, the PS_ON should be steady at 3Vdc or more.
                                    • noahc72
                                      • May 2012
                                      • 63
                                      Always, or after it the tv turns on?
                                        This indicates the main board is shutting down the power supply, for some reason.
                                        • noahc72
                                          • May 2012
                                          • 63
                                          Ok, so a new main board should fix it then?
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • cheeky2
                                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                            by cheeky2
                                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                            06-15-2025, 05:12 AM
                                          • theflyingsquirrel
                                            Samsung Chromebook Pro missing 1.2V power rail and no boot
                                            by theflyingsquirrel
                                            I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
                                            When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
                                            06-11-2025, 08:11 AM
