Samsung PN58C7000 wont power up
  • noahc72
    • May 2012
    • 63
    Re: Samsung PN58C7000 wont power up
    This is the chart I am talking about. Just trying to go back through and check everything again.
    • noahc72
      • May 2012
      • 63
      Ok, so new main board - tv powers on (doesn't cycle like earlier) but no picture and won't turn off. Checked ps_on and it's really low like 0.1 or so. My earlier post about this was wrong. I had the standyby pin, not ps_on.
      Logic board??
      • noahc72
        • May 2012
        • 63
        Originally posted by selldoor
        Do you have to set the new board up in the service menu - panel size/ make
        Missed this earlier. Does his need to be done? How do you get to the service menu?
        • noahc72
          • May 2012
          • 63
          Unless I'm measuring wrong, Vs and Va at the connections to x and y boards are way off. I put my meter on 200v dc. Is that the right setting? The readings are off by at least a factor of 10.
          I also noticed that since it will now go into standby (led on) after you plug it in that PS_ON is 3.25 in standby and goes to 0.12 after its switched on.
          Anyone know what this means?
            Maybe your multimeter battery is low - check a new unused AA battery, should measure about 1.6V.
            • noahc72
              • May 2012
              • 63
              Battery looks ok
                Battery looks ok
                Unplug both Y and Z and retest.
                • noahc72
                  • May 2012
                  • 63
                  Same reading either way - with meter on 200Vdc, Va is ~1.6 and Vs ~12.0
                    Hmm, way too low. Probably a problem with the PSU then - not sure what though. What is the VSON voltage?
                    • noahc72
                      • May 2012
                      • 63
                      Nothing on VSON.
                      I have 2 power boards. The original and one supposedly pulled from a new/screen damaged tv. All the readings are the same or close on both. Can the logic board cause this? It seems like it could if I'm reading that troubleshooting chart correctly. Otherwise I somehow got another defunct power board.
                        Nothing on VSON.
                        VSON is probably the problem - needs to be high to send a signal to turn the panel on - usually comes from control board did you replace this?
                        • noahc72
                          • May 2012
                          • 63
                          Control board = main or logic board? I did replace the main board.
                          VSON is from power to logic right? That's the only place I see it.
                            Logic board is the board next to the main board - controls Y and Z sus - from what I remember on the one Samsung plasma I repaired (same "C" series PDP but only 42") it was the board which gave the VSON voltage to turn everything on. However, it's unlikely that it's turning it off for no reason (unlikely to go faulty) - check power is good to the board, check the fuse on it (usually one on Samsung boards), check for loose connectors/cold joints etc. Do you still have the original board to compare with the board that makes the chime?
                            • noahc72
                              • May 2012
                              • 63
                              When you asked if I replaced the control board were you talking about the main board or logic board?
                              Right now I have 2 power boards and 2 main boards. I have tried all possible combos and the results are the same. I also have a replacement logic board on the way.
                              • noahc72
                                • May 2012
                                • 63
                                I don't see any fuses on the main boards. Also I mentioned before that the ps_on doesn't look right - 3.25 in standby and 0.12 on. Same with both main boards.
                                  3.25V is fine for PSON, and sometimes it's active low - must go low to turn PSU on. Don't ask me why, seems strange, but that's how they do it. If you have good 18V etc then main PSU is working, but if VSON is missing then something is up with whatever creates it. These fuses are tiny can you post a pic of your logic board? so I can point out any that may be there.
                                  • noahc72
                                    • May 2012
                                    • 63
                                    Ok, guess I misunderstood PSON. I thought it was supposed to stay at 3+.
                                    • noahc72
                                      • May 2012
                                      • 63
                                      pic attached
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #79
                                        Have you tested ANY fuses if so which.
                                        Thread is getting too long have you posted good clear pictures of the fronts
                                        and backs of all your boards.
                                        Post pics of All the connectors on the power supply other than the one we have.
                                          There's a fuse on that board with F5A on it and the board has a fuse marker next to it (in the triangle.)
                                          LEDs on control board, do they light up?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
                                            03-31-2024, 02:12 PM
                                          • cheeky2
                                            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                            by cheeky2
                                            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                            06-15-2025, 05:12 AM
                                          • theflyingsquirrel
                                            Samsung Chromebook Pro missing 1.2V power rail and no boot
                                            by theflyingsquirrel
                                            I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
                                            When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
                                            06-11-2025, 08:11 AM
