52PFL5704D/F7 dead except for click when power cord attached...
    Re: 52PFL5704D/F7 dead except for click when power cord attached...
    I need to get that Simson also, one bad thing about DMM is that if the circuits still have residue voltage on the board, we you try to do the resistance testing, reading will be way off.
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by Mel D.
      Went over to a friends house and missed it. But it turns out he knows somebody that has one......
      $24 winning bid was a good price.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        Going off topic somewhat, but how about a Tripplet?
        http://sfbay.craigslist.org/eby/tls/2966697082.html
        • Mel D.
          • Apr 2012
          • 23
          That is a real nice meter too. I used one for a while. I have one that is a hangar queen, nice to look at, not much good to use. Got me a 260 from the friend of a friend, now to tune it up a bit....
          Gave up and ordered an SSB. We'll see....
          • Mel D.
            • Apr 2012
            • 23
            Found the same problem checking a battery pack. The DMM would not catch a bad solder joint, but the Simpson would. It needs significantly more current to operate....
            • Mel D.
              • Apr 2012
              • 23
              Been out of town for a little while but while I was gone the SSB/main board came in. I installed it a couple days ago. Went through the setup/SSB configuration just as the parts place said (bought it from ShopJimmy's). It configured just fine. Pulled the power cord to load it and had a bad feeling. Before I sent it home with my son, just for grins I tried to power it up again. It went back to doing the exact same thing. Little blue light for about a second or two and then only a click. No power. I looked at the schematic for the power supply again but the parts I would replace (shotgun, really) would likely cost $15-$20 with shipping. The power supply board was only $28 with free shipping, so I ordered it. It should come Monday. I am hoping the SSB was not damaged so I can sell it on Ebay. (Or just keep it for a spare...) With my luck the SSB got fried again. Oh well, we will see. On the positive side, I have a Simpson 260 that works!
              • Hayneskr
                • Aug 2012
                • 9
                • US
                #27
                Did you ever fix the problem?
                I have the exact same model and it will not turn on.
                I disconnected the LVDS connector on the top left of the SSB and applied power and the set came on as well as the back light and all voltages are good.
                I wonder if the power supply could cause this problem?
                Hope you got yours fixed!
                • Mel D.
                  • Apr 2012
                  • 23
                  I replaced the SSB and the LVDS (left the new power supply in there, so I am not sure if it needed it or not, but I suspect not.) and it worked. Had to do some looking for a LVDS. Based on some help from a local TV guy who has been in the business in a while, if you pull the plug on the LVDS and the screen comes up, at least the LVDS is bad. My experience was the same as yours. That is why I replaced the LVDS. The SSB was definitely bad. I also suspect the LVDS killed the SSB.
                  My $.02. Also my $.02, ShopJimmy was very good to deal with. I will go back there when/if i need more parts.
                  later,
                  Mel D.
                  • Hayneskr
                    • Aug 2012
                    • 9
                    • US
                    #29
                    Thanks for the info. I am sure the T-Con board is bad. I am hoping the SSB is still good. I've been searching for the T-Con board but everyone seems to be out of stock. I will keep checking. When I get a T-Con board i will let you know if it fixes the problem or if I have to also purchase the SSB .
                    Later,
                    Kurt
                    • Hayneskr
                      • Aug 2012
                      • 9
                      • US
                      #30
                      Wow, I can not find a CPWBX4107TPZA to save my life! I've looked everywhere.
                      If you have any suggestions please let me know!
                      • kevinm34232
                        • May 2012
                        • 1884
                        I need one aswell as per this thread:
                        https://www.badcaps.net/forum/showthread.php?t=21850
                        but I've searched and found nothing...
                        • kevinm34232
                          • May 2012
                          • 1884
                          Did you buy the board from them? Let us know if it fixes it!
                          • Hayneskr
                            • Aug 2012
                            • 9
                            • US
                            #33
                            I did purchase the board and as soon as it arrives I will let you know
