52PFL5704D/F7 dead except for click when power cord attached...
    Re: 52PFL5704D/F7 dead except for click when power cord attached...
    I need to get that Simson also, one bad thing about DMM is that if the circuits still have residue voltage on the board, we you try to do the resistance testing, reading will be way off.
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by Mel D.
      Went over to a friends house and missed it. But it turns out he knows somebody that has one......
      $24 winning bid was a good price.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        Going off topic somewhat, but how about a Tripplet?
        http://sfbay.craigslist.org/eby/tls/2966697082.html
        • Mel D.
          • Apr 2012
          • 23
          That is a real nice meter too. I used one for a while. I have one that is a hangar queen, nice to look at, not much good to use. Got me a 260 from the friend of a friend, now to tune it up a bit....
          Gave up and ordered an SSB. We'll see....
          • Mel D.
            • Apr 2012
            • 23
            Found the same problem checking a battery pack. The DMM would not catch a bad solder joint, but the Simpson would. It needs significantly more current to operate....
            • Mel D.
              • Apr 2012
              • 23
              Been out of town for a little while but while I was gone the SSB/main board came in. I installed it a couple days ago. Went through the setup/SSB configuration just as the parts place said (bought it from ShopJimmy's). It configured just fine. Pulled the power cord to load it and had a bad feeling. Before I sent it home with my son, just for grins I tried to power it up again. It went back to doing the exact same thing. Little blue light for about a second or two and then only a click. No power. I looked at the schematic for the power supply again but the parts I would replace (shotgun, really) would likely cost $15-$20 with shipping. The power supply board was only $28 with free shipping, so I ordered it. It should come Monday. I am hoping the SSB was not damaged so I can sell it on Ebay. (Or just keep it for a spare...) With my luck the SSB got fried again. Oh well, we will see. On the positive side, I have a Simpson 260 that works!
              • Hayneskr
                • Aug 2012
                • 9
                • US
                #27
                Did you ever fix the problem?
                I have the exact same model and it will not turn on.
                I disconnected the LVDS connector on the top left of the SSB and applied power and the set came on as well as the back light and all voltages are good.
                I wonder if the power supply could cause this problem?
                Hope you got yours fixed!
                • Mel D.
                  • Apr 2012
                  • 23
                  I replaced the SSB and the LVDS (left the new power supply in there, so I am not sure if it needed it or not, but I suspect not.) and it worked. Had to do some looking for a LVDS. Based on some help from a local TV guy who has been in the business in a while, if you pull the plug on the LVDS and the screen comes up, at least the LVDS is bad. My experience was the same as yours. That is why I replaced the LVDS. The SSB was definitely bad. I also suspect the LVDS killed the SSB.
                  My $.02. Also my $.02, ShopJimmy was very good to deal with. I will go back there when/if i need more parts.
                  later,
                  Mel D.
                  • Hayneskr
                    • Aug 2012
                    • 9
                    • US
                    #29
                    Thanks for the info. I am sure the T-Con board is bad. I am hoping the SSB is still good. I've been searching for the T-Con board but everyone seems to be out of stock. I will keep checking. When I get a T-Con board i will let you know if it fixes the problem or if I have to also purchase the SSB .
                    Later,
                    Kurt
                    • Hayneskr
                      • Aug 2012
                      • 9
                      • US
                      #30
                      Wow, I can not find a CPWBX4107TPZA to save my life! I've looked everywhere.
                      If you have any suggestions please let me know!
                      • kevinm34232
                        • May 2012
                        • 1884
                        I need one aswell as per this thread:
                        https://www.badcaps.net/forum/showthread.php?t=21850
                        but I've searched and found nothing...
                        • kevinm34232
                          • May 2012
                          • 1884
                          Did you buy the board from them? Let us know if it fixes it!
                          • Hayneskr
                            • Aug 2012
                            • 9
                            • US
                            #33
                            I did purchase the board and as soon as it arrives I will let you know
                            • double_DD
                              How can I be sure that my EC chip is dead?
                              by double_DD
                              As the title suggests, how can I be sure that my EC chip is really dead?
                              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                              03-12-2025, 07:47 AM
                            • tvguy12012012120
                              by tvguy12012012120
                              02-07-2025, 05:13 PM
                            • disorder
                              ps5 edm-033 dead after hdmi/usb ports destroyed
                              by disorder
                              hello guys,
                              i need help to repair a edm-033 ps2
                              history : as always hdmi port and usb ports destroyed after unplugged
                              after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                              so i changed it
                              now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                              but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                              i don't see any projection of liquid metal on pcb.
                              01-14-2025, 12:48 PM
                            • Beton
                              Finding a dead short component
                              by Beton
                              Hi guys!
                              I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                              So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                              I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                              I have a bench PSU and if I try to inject voltage the voltage...
                              12-10-2021, 01:05 PM
                            • zunasthegreat
                              Chieftec GPS-450-AA with dead 20N60C3
                              by zunasthegreat
                              Hello everyone hope all doing well!
                              I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                              09-01-2024, 07:12 PM
