52PFL5704D/F7 dead except for click when power cord attached...
  • Mel D.
    • Apr 2012
    • 23
    First thing, thanks for any help you can give. I have a Philips 52PFL5704D/F7 that clicks when the power cord is plugged in and has no other indication of power getting to the unit (no LEDs, etc.). The set is about 2 years old, has not led a hard life (only on 5 or 6 hours a day) and just did not power up one day. The manual ON/OFF switch does not do anything and the remote does not also. I downloaded what appears to be the relevant the service manual from the Elektrotanya.com site (It shows 52PFL3704d, but the boards in their pictures look identical to me…). Got the back off and I do not see anything out of order. All the caps look pristine, as do the chips. The SM says to check the 3.3V from the power supply at various points ending up at Pin 1 of the 1101 connector, which I did and it reads 3.4+ volts. Almost looks like the 3.3V is running unloaded. The SM says to replace the SSB if the 3.3V is there, the 3.3V is on the IR module, the ON/OFF switch is good and the set does not power up. As more info, I checked the various voltages at the power supply and they are all in the millivolt range except for the 12V supplies which are about .6 V. I have included pics of the boards including close-ups of the labeling of the boards and the set itself.
    Any thoughts? Do you think it really is the SSB and what is the worst case $$ to replace that? (It has a BIG FPGA on there and there is no way in heck I could replace that!! Discrete parts, yes….)
    Later,
    Mel D.
  • selldoor
    Slow Learner
    • 7870
    Re: 52PFL5704D/F7 dead except for click when power cord attached...
    Hi - Nice intro and good try with the pics. They are not really detailed enough when enlarged we cannot see clear enough - the ones of the boards need to be as near to 2mb as you can get and one of the total layout of the back of the set would be good.
    Please can you post the link to the service manual so we can all look at the same one.
    What is SSB - first time please put in full.
    EDIT
    Remembered - small signal board - not many people on here use that term.
    • Mel D.
      • Apr 2012
      • 23
      One more time!
      The link to the SM is here: http://elektrotanya.com/?q=showresul...oria=&kat2=all
      • cashkennedy
        • Aug 2011
        • 668
        When you plug it in you should test the DC voltages on 3.3, 12v and psOn. You want to have the black probe to a peice of metal on the frame of the tv or a screw that is holding the board down.
        You said you get 3.4 (that is perfectly fine, they almost never are 3.33000 or something perfect.
        psOn should be 0v till you press the power button, then tell use what voltage you see when the power button is pressed.
        And remeasure 12v if you werent using the right ground the first time.
        You might also want to attach a closer picture of the black power wires leaving the power supply, as i can barely read what the labels are.
        Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
        • selldoor
          Slow Learner
          • 7870
          Pictures are great - thankyou- labelling is particularly small. At some point you will have to take the boards off the frame and do similar pics of the backs of the board.
          That time could be soon. I think you have tested the glass fuse although as you have voltage it must be ok. However there is a small red box at the left hand side of the heatsink with 9 holes. This is another fuse and should be tested.
          • Mel D.
            • Apr 2012
            • 23
            Re-checked the 12V. They are indeed .6V with reference to the metal chassis structure. PSON is 0.0V and stays that way even when the power button is pushed. Took a pic of the board and the black wires. Getting the power supply board off to see the back side and check the red fuse will have to be tomorrow evening. 0500 comes early after a day of honey-dos....
            Thanks,
            Mel D.
            • infringer
              Badcaps Member
              • Sep 2009
              • 244
              • United Frickin States
              Did you check the connections to your IR board or Button board if so I will say that your main board is likely the culprit in this case but because if the main board is junk the standby power does not turn on when the processor goes on this unit I dunno what it is for sure but just from my own findings it appears I would go with the main board.
              Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                Here is the service for this chassis PL9.1:
                I would like to see the closed up pictures of the connectors on the power supply board so I can see how they are labeled.
                • selldoor
                  Slow Learner
                  • 7870
                  I have re done connectors pic and added in the other two connectors
                  from a pic of this board on a website.
                    Those orange bead/cylinder objects on your second last photo - they are fuses. Check both with your multimeter on the 200 ohm range. With power unplugged, measure from one side to the other. You should see close to zero. When your meter probes are not touching, it will probably show a single "1"; this does not indicate 1 ohm but a resistance in excess of 200 ohms.
                    • Mel D.
                      • Apr 2012
                      • 23
                      Yes I did. The voltages were as called out in the SM.....
                      • Mel D.
                        • Apr 2012
                        • 23
                        Both show close to zero. Time to pull the board off and measure the red fuse....
                        • Mel D.
                          • Apr 2012
                          • 23
                          Thanks!!!!
                          • Mel D.
                            • Apr 2012
                            • 23
                            Interesting contradiction here. The PL9 schematic posted above shows that it applies to the 52PFL5704D/F7, but the photos, cable designators and the troubleshooting info does not match. The one noted as applying to the 3704 appears to be a much better match.
                            In any case, I did get some pictures of the underside of teh power supply board, not very good ones I am afraid. The green is playing heck with my autofocus and I can't seem to do much better in manual focus. Just not enough light. I will play with putting a couple of desk lamps on the board later tonight. I will also take the SSB loose and get some pics of it. I did check the red box part and it shows zero ohms.
                            Sounds like I might be in for a SSB replacement....
                            • selldoor
                              Slow Learner
                              • 7870
                              Just to be certain - when you measure fuses and you say close to zero ohms is that the same as you get when you touch the probes together.
                              • Mel D.
                                • Apr 2012
                                • 23
                                Yes. No difference in reading. (Darn digital meter. I miss my Simpson 260....)
                                thank you,
                                Mel D.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  On ebay, the prices for Simpson 260s seem to be lower than what they should be? You can get working ones in the mid $20 range.
                                  http://reviews.ebay.com/Simpson-Mete...00000007543567
                                  --- begin sig file ---
                                  --- end sig file ---
                                  • Mel D.
                                    • Apr 2012
                                    • 23
                                    Excellent! Time to go prowling Ebay!
                                    THANKS,
                                    Mel D.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      THANKS,
                                      Mel D.
                                      $21.50 with 28 minutes left to go ...
                                      http://www.ebay.com/itm/221000517827
                                      I can't vouch for seller or that it will work.
                                      • Mel D.
                                        • Apr 2012
                                        • 23
                                        Went over to a friends house and missed it. But it turns out he knows somebody that has one......
                                        thx,
                                        Mel D.
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
