Sanyo dp46848!!
    Re: Sanyo dp46848!!
    Originally posted by aaronpass
    I must have cooked a few capacitors in my head lol, I misread them you are 100% right they are 47uf 35v caps! im gonna try to change out the caps that have the marks on top of them that look like leaks and see if that changes anything!!
    Did you check the output voltages on the PSU to see if they are in reason? Do you have a multimeter?
    • aaronpass
      • Jul 2011
      • 33
      Re: Sanyo dp46848!!
      I tested the DC voltage on the output side o the power supply board with the tv plugged in and on, this is i came up with
      P/on 4.82V
      +5 4.84V
      4.83V
      +5 usb 4.87V
      +12 11.69V
      11.69V
      11.69V
      Dim 1.36V
      • aaronpass
        • Jul 2011
        • 33
        Re: Sanyo dp46848!!
        Bump
          Re: Sanyo dp46848!!
          To me, they seem a little low, but okay.
          Next check, regulators on main board. Post a pic of the main board.
          • aaronpass
            • Jul 2011
            • 33
            Re: Sanyo dp46848!!
            Not sure if these will be good enough pictures
            • selldoor
              Slow Learner
              • 7870
              #26
              Re: Sanyo dp46848!!
              No they are not good enough - the pictures are the only chance of us being to help you fix this. They need to be as near 2mb as you can get and should look like this
              https://www.badcaps.net/forum/attach...1&d=1290283049
              Please also update your profile with the country you live in
              • uberplasma
                • Oct 2011
                • 85
                Re: Sanyo dp46848!!
                those caps don't look like they were marked, look like they are venting drive plasma scotty(lol), hit them with a magnifying glass or usb microscope and look for a fracture in the metal cap, then trace down the culprit that blew them
                • aaronpass
                  • Jul 2011
                  • 33
                  #28
                  Re: Sanyo dp46848!!
                  https://www.youtube.com/watch?v=wIdY...e_gdata_player
                  Here is another video this time connected to cable tv. Picture bleeds in on the right side when first turned on . Then looks like the middle to the right are dark on screen . You can get a better idea on whats going on with this tv... with the tv on..
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    Re: Sanyo dp46848!!
                    Cant say for others, but i'd have preferred decent pictures of the boards straight on front and back and confirmation that you have checked the regulators and re inspected the suspect caps or replaced them.
                    • aaronpass
                      • Jul 2011
                      • 33
                      #30
                      Re: Sanyo dp46848!!
                      I took some time away from this tv and started playing around with it again. I tore it all apart again a looked for a bad connection to the lcd screen. I put it all back together and turned it on no change. So a gave it a few swift wacks on the right side where im having the problem and it started working fine. Here is what is going on with the tv, when it first turns on the screen is not right from the mid point to the right. once it warms up about 25 mins the tv works fine. So is this a connection issue or could it still be something on the board that is bad?? One other thing i noticed that when i do a channel scan in the menu and it sets all the digital channels if i turn it back on in the morning they didn't stay so i don't know if this is related...
                      • cashkennedy
                        • Aug 2011
                        • 668
                        Re: Sanyo dp46848!!
                        Might want to try proding parts on the power supply and mainboard with a non conductive object (wood / plastic), and seeing if any of them cause / or removes the problem.
                        Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • reformatt
                          by reformatt
                          07-31-2025, 08:37 PM
                        • smic717394
                          by smic717394
                          07-25-2024, 10:16 AM
                        • toddw65
                          Sanyo DP5834 - Gray Screen
                          by toddw65
                          Hey All,
                          I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                          Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                          Thanks,...
                          10-31-2024, 10:37 AM
                        • Chrissygizmo
                          by Chrissygizmo
                          02-10-2025, 12:33 AM
