I finally got this unit to display a picture. I bought a used main board from an auction site. I've checked all power supply voltages and found them to be correct. I've also tried a different T-con board, But the picture still looks like this. I'm still thinking the main board is at fault. The picture also has a mirror effect, Like its taking the bottom of the screen and inverting it to the top. I would like to know what commonly fails on the mainboard and replace that particular component . Any help or ideas would be greatly appreciated.
Toshiba 42rv530u picture problem
Re: Toshiba 42rv530u picture problem
Do you have a bigger picture of the problem? It looks like a failed memory IC, does it affect the OSD/interface too?
If the board you bought wasn't taken from the same model, or the model it was taken from used a different LCD panel, it's possible it needs to be reconfigured using the service menu, if available.Last edited by tom66; 04-03-2012, 08:27 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Not sure why you have started a new thread? - we are still going to need
decent pictures of the main board front and back and a close up of the
eeprom so tom can point out the pins to short to reset it.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
All inputs do the same thing. The menu displays funny as well. When I checked the firmware version it said - 4.2.40.0. Xv540u 4-7-2008. Is that model listed the problem? How would I reconfigure it? Thanks for the help!Comment
The original picture I took was to large to upload. I have no program to reduce the pixels. I've also tried reseating the ribbon cables as well.Do you have a bigger picture of the problem? It looks like a failed memory IC, does it affect the OSD/interface too?
If the board you bought wasn't taken from the same model, or the model it was taken from used a different LCD panel, it's possible it needs to be reconfigured using the service menu, if available.Comment
That model number certainly could be causing the problem.
To enter service mode:
Set volume using RC to zero.
Press MUTE twice then release it.
Hold MUTE down.
While holding MUTE press MENU.
Important information from manual - probably relevant to your problem: "Whenever using new MAIN PC board to the set, set the SET-ID data according to panel option data."
Manual is here:
Wait 60 seconds for Get Manual link to appear.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Going into the service mode rendered my original mainboard useless, I mistakingly changed a setting in there and it the set would not turn on. I need to be absolutley sure what to change in there next time. Can you give a little more detail on what to do in that menu? Thanks.That model number certainly could be causing the problem.
Hold MUTE down.
Manual is here:
Wait 60 seconds for Get Manual link to appear.Comment
The service manual is your best bet.Going into the service mode rendered my original mainboard useless, I mistakingly changed a setting in there and it the set would not turn on. I need to be absolutley sure what to change in there next time. Can you give a little more detail on what to do in that menu? Thanks.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Here's a better picDo you have a bigger picture of the problem? It looks like a failed memory IC, does it affect the OSD/interface too?
If the board you bought wasn't taken from the same model, or the model it was taken from used a different LCD panel, it's possible it needs to be reconfigured using the service menu, if available.Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes, They say they will refund. Is finding a replacement at a reasonable price going to be a hassle? Thats why I'm trying to learn about component replacement for this particular board. Seems all the available boards are refurb or rebuilt, So that leads me to believe that components are available to correct the fault. Thanks Tom66Comment
There seems to be four EEPROM chips on the back of the board. 24c02wp is the number on them.Comment
Thanks Tom66! I followed the service manual to get the parameters set. The tv came to life for about fifteen minutes then started to do funny things again. The picture is no longer fuzzy though. Still getting the inverted image. I checked voltages on the power supply, They are all correct while unit is powered up. Any idea what component may be failing on the main board?That model number certainly could be causing the problem.
Hold MUTE down.
Manual is here:
Wait 60 seconds for Get Manual link to appear.Attached Filesif you find these attachements useful please consider making a small donation to the site
Did you get the inverted image when it was briefly working?Thanks Tom66! I followed the service manual to get the parameters set. The tv came to life for about fifteen minutes then started to do funny things again. The picture is no longer fuzzy though. Still getting the inverted image. I checked voltages on the power supply, They are all correct while unit is powered up. Any idea what component may be failing on the main board?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Have you tried with other sources - PC/ DVD - what source are you using.Please upload pictures using attachment function when ask for help on the repair
Reloaded picsThanks Tom66! I followed the service manual to get the parameters set. The tv came to life for about fifteen minutes then started to do funny things again. The picture is no longer fuzzy though. Still getting the inverted image. I checked voltages on the power supply, They are all correct while unit is powered up. Any idea what component may be failing on the main board?Attached Filesif you find these attachements useful please consider making a small donation to the site
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by PNI E.Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
by huj3rHi there!
I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
Photo of the situation after the black shadow dissipates:
After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
> This indicates HFR Communication error. [ HFR Communication... -
Assuming...7 Photos - Loading...
