Toshiba 42rv530u picture problem
  • kueberco
    • Mar 2012
    • 66
    • usa
    I finally got this unit to display a picture. I bought a used main board from an auction site. I've checked all power supply voltages and found them to be correct. I've also tried a different T-con board, But the picture still looks like this. I'm still thinking the main board is at fault. The picture also has a mirror effect, Like its taking the bottom of the screen and inverting it to the top. I would like to know what commonly fails on the mainboard and replace that particular component . Any help or ideas would be greatly appreciated.
    Re: Toshiba 42rv530u picture problem
    Do you have a bigger picture of the problem? It looks like a failed memory IC, does it affect the OSD/interface too?
    If the board you bought wasn't taken from the same model, or the model it was taken from used a different LCD panel, it's possible it needs to be reconfigured using the service menu, if available.
    • selldoor
      Slow Learner
      • 7870
      Not sure why you have started a new thread? - we are still going to need
      decent pictures of the main board front and back and a close up of the
      eeprom so tom can point out the pins to short to reset it.
      • kueberco
        • Mar 2012
        • 66
        • usa
        All inputs do the same thing. The menu displays funny as well. When I checked the firmware version it said - 4.2.40.0. Xv540u 4-7-2008. Is that model listed the problem? How would I reconfigure it? Thanks for the help!
        • kueberco
          • Mar 2012
          • 66
          • usa
          The original picture I took was to large to upload. I have no program to reduce the pixels. I've also tried reseating the ribbon cables as well.
            That model number certainly could be causing the problem.
            To enter service mode:
            Set volume using RC to zero.
            Press MUTE twice then release it.
            Hold MUTE down.
            While holding MUTE press MENU.
            Important information from manual - probably relevant to your problem: "Whenever using new MAIN PC board to the set, set the SET-ID data according to panel option data."
            Manual is here:
            Wait 60 seconds for Get Manual link to appear.
            • kueberco
              • Mar 2012
              • 66
              • usa
              Hold MUTE down.
              Manual is here:
              Going into the service mode rendered my original mainboard useless, I mistakingly changed a setting in there and it the set would not turn on. I need to be absolutley sure what to change in there next time. Can you give a little more detail on what to do in that menu? Thanks.
                The service manual is your best bet.
                • kueberco
                  • Mar 2012
                  • 66
                  • usa
                  Reloaded pic
                  • kueberco
                    • Mar 2012
                    • 66
                    • usa
                    Anyone have a good reliable source for toshiba mainboards that work when installed? Thanks!
                      Did the reseller state it was compatible with your model? If so, you should be entitled to a refund because clearly it isn't.
                      • kueberco
                        • Mar 2012
                        • 66
                        • usa
                        Here's a better pic
                        • kueberco
                          • Mar 2012
                          • 66
                          • usa
                          Yes, They say they will refund. Is finding a replacement at a reasonable price going to be a hassle? Thats why I'm trying to learn about component replacement for this particular board. Seems all the available boards are refurb or rebuilt, So that leads me to believe that components are available to correct the fault. Thanks Tom66
                          • kueberco
                            • Mar 2012
                            • 66
                            • usa
                            There seems to be four EEPROM chips on the back of the board. 24c02wp is the number on them.
                            • kueberco
                              • Mar 2012
                              • 66
                              • usa
                              Hold MUTE down.
                              Manual is here:
                              Thanks Tom66! I followed the service manual to get the parameters set. The tv came to life for about fifteen minutes then started to do funny things again. The picture is no longer fuzzy though. Still getting the inverted image. I checked voltages on the power supply, They are all correct while unit is powered up. Any idea what component may be failing on the main board?
                                Did you get the inverted image when it was briefly working?
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Have you tried with other sources - PC/ DVD - what source are you using.
                                  • kueberco
                                    • Mar 2012
                                    • 66
                                    • usa
                                    No. Picture was perfect for about twenty minutes.
                                    • kueberco
                                      • Mar 2012
                                      • 66
                                      • usa
                                      Tv and component inputs reveal same picture.
                                      • kueberco
                                        • Mar 2012
                                        • 66
                                        • usa
                                        Reloaded pics
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • PNI E.
                                          Dyson v15 problem with the dust detector board
                                          by PNI E.
                                          Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
                                          Today, 10:18 AM
                                          09-06-2024, 05:27 AM
                                        • huj3r
                                          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                                          by huj3r
                                          Hi there!
                                          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                                          Photo of the situation after the black shadow dissipates:
                                          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                                          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                                          > This indicates HFR Communication error. [ HFR Communication...
                                          08-15-2023, 10:55 AM
